Question about RCA HD52W58 52" TV
Color problem I recently moved, and now the blue color on my tv is off, it is about an inch off diagonally to the rest of the picture.  Auto convergence does not work.  How do I manually adjust the color? Thank you so much for your time, Happy Holidays.
  • brihyanna Dec 22, 2007
    How do I adjust the horizontal and vertical frequency?
    Sniper:
  • 108 Answers
You can adjust horizontal and vertical frequency to get the proper picture. else there is some problem with your deflection circuits. if everything is ok. Check Colour chroma decoder. measure R_G_B voltages. Contact service centre for further rectification
Posted on Dec 22, 2007
JVC Hd56fn97 56-inch 1080p Hdila Rear Projection Tv with all blue color green
Talk to JVC as I have suggested and this is likely a known problem: loss of any color, picture upside down etc requires a upgrade to correct and I have seen about twenty sets with their name like this with this kind of problem.
Dec 11, 2012 | JVC Hd56fn97 56-inch 1080p Hdila Rear...
53 inch projection tv...seems like the color red and color blue have shifted giving me a picture with red and blue shadows
For CRT projection TV's, this indicates that the Green picture tube is burned (warn out). The less green that strikes the screen, the more redish the image will look. You will need to find an old school TV repair shop that knows how to replace picture tubes.
In the case of a DLP style TV, the color wheel needs replacing.
Dec 29, 2009 | Hitachi Televison & Video
Westinghouse SK-26H520S LCD TV has blue screen on the side
Vertical color scan has an open or short..............it could also be a ground problem with in the V-color scan circuits...
If you tap the tv and the color bar is gone then its a ground problem with in those circuits above. Needs a solder re-flow and check the condition of ribbon cables.
CWR
Oct 29, 2009 | Westinghouse Televison & Video
Color blue will not adjust on crt color conergence adjustment , picture on tv is double with blue on right side, auto/manual mode , the color blue will not adjust on right or middle side from side to side,...
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 27, 2009 | JVC AV-56WP74 56" Rear Projection...
My Hitachi 52 inch Projection TV video goes one
hitachi 52' tv...the blue color is off...you can put magic focus on and it still want move the blue back where it needs to be
Sep 10, 2009 | Hitachi 51F500 51" Rear Projection...
My blue color is off...HCN4226W.
If the blue is shifted away from the rest of the picture and maybe bowed then try the manual convergence adjustment. My guess is the red will move but the blue won't. If I'm correct call a tech unless you are a skilled solderer, then replace the large STK amps in the Convergence circuit and check all of the resistors in the circuit. Good Luck.
Dec 28, 2007 | Samsung HCN4226W 42" Rear Projection...
Hitachi inspire projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Dec 02, 2007 | Televison & Video
Blue Color spots on all pictures
Call a technician, sounds like an Integrated Circuit problem and would cost you about $250.
May 07, 2007 | Philips 60PP9202 60" Rear Projection...
Hitachi 52 projection tv
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
RCA HD52W58 52" TV Logo
63 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
