Question about Cameras
How to build a custom program and save it to say B C or D
Custom build PC shuts down by itself
you are overheating.did you use enough termic paste ? your computer shuts down for so it not breaks the processor.se to at allways as few startup programs as possible.and invest in a new PSU.
May 28, 2013 | Abit KT7A Motherboard
Tip
Tips to create an iPod Application for All types of iPods
<p><span>To create application for your own iPod, you have to register for an Apple Developer connection account and need to download application building software onto your operating system. For this use Apple's X-code Tools software to create and download an application that can be approved and downloaded for all versions of iPhone and iPod.</span><br /> <p><span> </span><br /> <p><span>These are some steps that will provide the way to create such application for iPod:</span><br /> <p><span> </span><br /> <p><span>First: Sign up for an ADC (Apple Developer Connection) account of the iPhone Development Center website. These accounts are available free.</span><br /> <p><span><span> </span></span><br /> <p><span>Second: Now download and install the X-code programs, which also available at the iPhone development center website, onto your operating system. But it is only available for Mac computers at this time.</span><br /> <p><span> </span><br /> <p><span>Third: Now create an X-code project. When you open X-code it will automatically create a document for you.</span><br /> <p><span> </span><br /> <p><span>Fourth: Then go to the "File" menu and choose "Save as" command to give documents name and save the program to your hard disk drive.</span><br /> <p><span> </span><br /> <p><span>Fifth: Now open "Interface Builder" module and create your design. Interface builder works like as graphics programs.</span><br /> <p><span> </span><br /> <p><span>Sixth: Now start a new document by clicking on "File" menu and select "New" for each of your application. then add your application code as you build your interface.</span><br /> <p><span> </span><br /> <p><span>Seventh: Finally save your application documents regularly to save any changes of your project.</span><br />
on Dec 24, 2010 | Computers & Internet
Tip
Tips to create an iPod Application for all Versions
<p><span> </span><span>To create your own iPod application you should register an Apple developer connection account and also download application building software onto your Mac operating system. Use Apple's X-code tools software to create and build an application that can be approved and downloaded for all versions of iPhone and iPod.</span><br /> <p><span>These are some simple steps that will help you.</span><br /> <p><span> </span><br /> <p><span>1. Sign up for an Apple Developer Connection (ADC) account at the iPhone Development Center website. ADC accounts are available free.</span><br /> <p><span> </span><br /> <p><span>2. Now download and install the X-code programs. This software also available free and can be used to build any iPhone or iPod application, but it is only available for Mac operating system at this time.</span><br /> <p><span> </span><br /> <p><span>3. After creating an X-code program now create X-code project. When you open X-code it will automatically create a set of blank "documents" for you.</span><br /> <p><span> </span><br /> <p><span>4. Now go to the "File" menu and choose "Save As" to give project name and save the project in your hard disk.</span><br /> <p><span> </span><br /> <p><span>5. Now open the "Interface Builder" module and create your design. It works similarly to graphics program.</span><br /> <p><span> </span><br /> <p><span>6. Then start a new document by clicking on "File" and "New" for each of your application screens. And add your application code as you build your interface.</span><br /> <p><span> </span><br /> <p><span>7. Save your application document regularly to prevent losing any changes.</span><br />
on Dec 24, 2010 | iPhone Apps
I need to scan a document and save as a word doc.
As long as you just 'scan' - using the scanner only then its driver will open the program that came with it. To save it to either a MS document imaging, Word, Powerpoint, Clip Organizer, another photo program, etc, these have to be opened and you do it from any of these.
Your web building program probbly have this function too.
Jun 30, 2009 | HP PSC 2210 All-In-One InkJet Printer
Tip
Overcome tazti's (speech recognition software)custom speech command limitation.
you can open more programs in tazti . do this: 1.open notepad and type start "" "here type the path of any program you like"
you can include the programs like this;
start "" "C:\WINDOWS\Prefetch " start "" "C:\DOCUME~1\MYPC~1\LOCALS~1\Temp" start "" "C:\WINDOWS\Temp"
Then save this text file with "bat" extension .ex:(filename.bat)
then you can add this file to tazti .
run the file (filename.bat) using tazti .
*save your tazti's custom command memory*
on Aug 30, 2010 | Computers & Internet
We use Windows XP home edition. When we start the computer, the little screen comes up with the Windows XP logo and the scrolling progress bar, then the progress bar stops moving and sits there. We have to...
You may have other issues going on other than spyware or viruses that are infecting your computer. You might wish to try to save everything that you want to save to an external hard drive, and try re-installing XP onto your computer. You can also remove the motherboard HUB battery, located directly on the motherboard, leave it out for about 15 minutes or so, thereby erasing all of the motherboard settings and then putting it back in. Sometimes a computer may have too many programs that are starting up when XP starts, such as office, Adobe, or even your internet service. Try doing a disk clean-up, defragging the computer, removing programs that you do not use, and making sure that you are not infected by any malicious programs such as spyware or viruses, also. I myself like to save everything to my Western Digital 80GB external, and reinstal XP once a year. Gives my custom-build a nice clean system to start from, like a breath of fresh air. It does help. Make sure that everything is saved to an external hard drive first, then unplugging it to ensure that your computer cannot access it before you do these tasks. I hope that this helps. Good luck!!    yuva
Mar 23, 2009 | Computers & Internet
Driver to HP1050C ...
Friend,
All drivers for the 1050-series printers can be found HERE:
Hope you sort it out.
If not, could another solution be to save the file as a .pdf and send it to your customer?
//Al
Jan 12, 2009 | HP DesignJet 1050c InkJet Printer
Office home and student 2007 stop woorking when try to save file
Did you activate your Office?
If you didn't activate then it would go into reduced functionality mode.
Dec 01, 2007 | Microsoft Office Professional 2007 Full...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
