Question about OEM Systems Car Audio & Video
How to remove a radio from 1996 chevy lumina ls. I dont know how the molding comes off
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
This is a very simple procedure...all you do is pull on it. The trim piece which goes around the stereo and instrument cluster is one piece and is held in by snaps. it will be easier if you take the drivers under dash panel off before pushing the dash bezel Be careful when you are removing it around the steering wheel-it can be stubborn, but moving the shift lever all the way into 1st gear and tilting the steering will all the way down will help.
i have attached a link to metra onlines website
http://documents.victorytechnologies.com//documents/product/866.pdf
hope this helps
Posted on Oct 05, 2009
1996 chevy lumina key broke in ignition I dont know if it has a chip or not
Too old for chip, but use a jig sawblade to catch onto the broken key
Jan 18, 2014 | 1999 Chevrolet Lumina
1996 Chevy Lumina temperature gauge rising
the drop- electric fan is coming on to cool the overheat- the heat- sounds like thermostat is bad-replace
May 21, 2010 | 1996 Chevrolet Lumina Mini
How can i remove an airbage when the steering 1996 chevy lumina
The airbags that i have removed in chevy steering wheels is easy, there are holes,one on each side of the steering wheel,you push something small and stiff in the hole and pull out ,do one side at a time. It shouldnt matter if the steering wheel is locked .
Apr 11, 2010 | 1996 Chevrolet Lumina Mini
Where is the fuel filter located on a 1996 chevy lumina
Hello there
itsalmos identical location of the '93 Lumina it's almost dead center of the underneath of the car. It is a rather simple change out.
first spray the nut with WD40, then holding one side firm just unloosen the other side. Be careful under a little bit of pressure and fuel will come out. Next you have to remove the cover thing on the other side by sliding it back. Push down on those two tabs and pull, should come right apart. Hope this helps.
Best regards Mike
Feb 14, 2010 | 1996 Chevrolet Lumina Mini
I have a 1996 chevy lumina. the motor wont turn
You need to check for power at the purple wire going to the solonoid while key is in the start position, if no juice then check starter relay-under hood- fuse ,and ignition switch
Feb 01, 2010 | 1996 Chevrolet Lumina Mini
No dash lights when headlights come on
Have you tried turning up the dash light dimmer switch as bright as it can go? I will dim slightly but will still be alluminated
Sep 11, 2009 | 1996 Chevrolet Lumina Mini
Car radio
ignition on, LOC appears
press MN and OOO will appear in display
press MN again to make the the last two digits agree with your code.
press HR to make the first one or two digits agree
with your code.
Press AM/FM after you have confirmed that the code matches the code you have written down.
The display should show SEC which indicates
the radio is now operable and secure.
'rock on'
Mar 13, 2009 | 1996 Chevrolet Lumina Mini
1995 Chevrolet Lumina tyre pressure to maintain????
Most tires come with the recommended air pressure imprinted on the tire. Just follow what it says on the tire, many tires differ in size and air pressure.
Jun 24, 2008 | 1995 Chevrolet Lumina
My radio
could be a short across your speaker terinals.are u using a seperate amp.got to be more specific on set up
some times in trunk metal from something might bre touching the terminal on speakers ,this will cause a muted affect also check to make sure you didnt mute the radio.
Jan 21, 2008 | Car Audio & Video
Car Audio & Video Logo
824 people viewed this question
Top OEM Systems Car Audio & Video Experts
xxxxxx xxx
miles
miles
SuperN0va
SuperN0va
Are you an OEM Systems Car Audio and Video Expert? Answer questions, earn points and help others
