Question about Nikon COOLPIX P90 Digital Camera
Most of the pictures are hazy and AF problem
I have a p90. most of the pictures are hazy and there is a AF problem in low light conditions
What does it mean.when the AF button light on the dryer stays on
www.fixya.com/.../t26056154-mean_when_af_button_light_dryer_stays
20 mins ago - Low air flow. Means that your vent is blocked or crushed and check your lint trap also ... Hi Terry, AF flashes if a restricted airflow condition exists.
Jan 16, 2016 | Dryers
Why is my led screen blurry in low light before I take a picture?
It sounds like your camera settings have the( AF Assist Beam) on Off? That is the Amber Color light you see when you half press the shutter button. If that setting is set to OFF, then the camera can not focus in low light giving you blurry pictures as it can not see any light to assist the camera on focusing. If you turn on the (AF Assist Beam) to on, they when you press the shutter button half ways down you will see a Reddish/ Amber light, that light helps the camera find a focus point, giving you a slightly better low light photo.
Jun 09, 2014 | Canon PowerShot SD1400 IS IXUS 130...
I try to take a picture in AF mode while the confirmation light in the viewfinder blinks, a picture cannot be taken, but in MF mode picture taken correctly what is the problem?..
It's attempting to tell you that AF has failed. I'd expect low light, low contrast, reflective subject like a mirror or chrome. A solid colour wall with no contrast will also cause a AF failure. Auto Focus relies on contrast. Switching to manual mode shuts off the system and you can take a picture with nothing in focus.
Nov 24, 2010 | Canon Rebel XT / EOS 350D Digital Camera
My camera canon powershot A430 is giving hazy pictures
This may sound silly, but have you checked the front lens element on the camera, a thick layer of fingerprints will give you hazy photos and what can look like over exposure in bright conditions.
Oct 27, 2010 | Canon Cameras
Each time I press the shutter button to take a picture the flash keeps flashing fast on and off 3 bursts of about 10 flashed then it takes a pic ??? help
The built-in flash can function as an autofocus illuminator. This helps with focusing in low-light conditions in the AF mode.
To disable this function, press the menu button, then select service1 menuitem, then AF illuminat., and finally, select OFF.
Aug 20, 2010 | Olympus EVOLT E-410 Digital Camera
Low light no focus
The Nikon D100 custom settings option 22 - AF Assist, controls the AF Assist light.
Check if this has been turned off.
This option controls whether the auto-focus assist light comes on in low light to help autofocus
latch onto the subject.
Jul 15, 2009 | Nikon D100 Digital Camera
Af assist on canon flash 580exii not working
check Custom Functions of Camera and Flash it can be turned off in both locations
Jun 13, 2009 | Canon Speedlite 580EX II TTL Flash
I lightly dropped my camera on a carpeted floor and now my AF light (the orange light) on my cybershot camera doesnt work. How do I fix it? Do I really need it? Everything else works fine.
As far as I know, the autofocus (AF) light is needed only in lower light conditions to illuminate the subject. You may not be able to rely on it working without having good light available so you should try some shots in poorer light to see if it is really not working before depending on having in-focus snaps.
If you don't use it in low light conditions, you may not miss it.
Dec 09, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Canon powershot a520
You probably changed a setting or were taking photos in low light. If you take a photo in the middle of the day, in full-automatic mode, is it still hazy? Maybe you got something on your lens?
Apr 27, 2008 | Canon PowerShot A520 Digital Camera
Nikon COOLPIX P90 Digital Camera Logo
344 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
