Question about AT&T Blackberry Curve 8300 Smartphone
During an update, the hour glass just sat there spinning. Now, even after removing the battery, the hour glass just spins and nothing comes on
    Brigadier General:
  • 7,752 Answers
You need to reflash the OS on the phone you should take the battery out first then connect it via the usb cable to the laptop/pc you are using then open the blackberry desktop manager,click on the apploader, then install the OS.
pls not that when u click on the apploader the pin should be PIN:UNKNOWN you make need to do this like 4x before the pc sees the pin:unknown but it will work once it see the pin:unknown you can re-insert the battery and continue with reflashing the phone
Posted on Jan 30, 2010
Electrolux ew910t
Are your loads spinning even if off balance it will cause the drum to spin off balance and water will come out of the bottom
Jul 10, 2013 | Vacuums
"2007 Whirlpool Cabrio HE top loader with glass lid" sat for 3 months, now it does everything except agitate, and flashes
The OL error code indicates that the washer is overloaded. If the washer is not overloaded, this would indicate either a drag on the drive system or the control board is failing. Be sure nothing is on the floor under the washer that could be causing a problem. Raise the lid & manually spin the basket, it should spin freely. If not, you may have an item stuck between the spin basket and the washer tub. The image below shows how to remove the spin basket. If you unplug the washer and follow that procedure, you may find the cause of your problem.
Here is the document to help you.
Oct 14, 2012 | Whirlpool Cabrio Washing Machines
Windows 7 installing updates 1 of 2 1 stopped at 14 but hour glass is still spinning
Turn it off and let it try the updates again. It will pick up the updates the next time.
May 12, 2012 | Computers & Internet
I have a 1988 honda shadow vt1100 and i started to crank it and it spun over about 2 seconds and then nothing i put the trickle charger on it for 8 hours and still want even spin over everything else...
unhook your batttery for positive side . let it set. take a heavy screwdriver and tap on starter .
do not crank . let it set over night . in themorning hook pos cable back on battery. let me know
what happens..........
Oct 20, 2010 | 1988 Honda VT 1100 C Shadow
Spin/rinse cycle quits
it may be an intermittent door lock switch. i believe on your model when you remove the front access panel you will find a pair of wires in a plug with nothing attached to them on the r/h side where the wire harness runs. when you are in the spin cycle, check with a multimeter for 0 volts across the 2 wires. if you are showing 120 volts, then your door lock is bad. if yours has never been changed it actually has been updated to a new style. costs about $120.00 for the part. instructions should come with revised part
Aug 20, 2009 | Washing Machines
Bluetooth problem on sgh-j700v.
Try removing the battery from the cell phone and removing the SIM while the phone is powered on. Reinstall the battery and SIM, power the phone on, and try to reactivate the bluetooth.
If that doesn't work, turn the bluetooth off and delete the device from the phone. Turn the bluetooth on and put in to pairing mode and re-pair the device with the phone.
If that doesnt work, one or the other is defective. If I've missed anything I've written an article that may help: http://yourmonstersofmobile.com/how_to_for_cell_phones/pairing_your_bluetooth.html
Aug 09, 2009 | Samsung J700 Cellular Phone
Blackberry 7290 device error:373 reset
Hi Anand
Practically speaking i spent 3 hours looking for your solution but nothing much even the BB intelectuals failed .Try these steps out it may resolve the issue and lets hope for the best .
This error : 373 : Device Error means that the Timers are corroupted
1. Remove the battery for at least 5 minute.
2. Make sure u have working SIM card, other wise remove the old SIM.
3.You should receive an Hour glass spinning. Give a few minutes, after that u will see a 507 message on the bb screen, (which means there is no app loaded on the bb)
4.If this dosent work
Use application loader to wipe handheld clean and reinstall base software but do backup your data
And please let me know .
Apr 04, 2009 | RIM BlackBerry 7290
Toshiba Satellite A105-S2141 Lockup
Have you checked the heat of CPU? It might be cause of CPU overheating.
Nov 20, 2007 | Toshiba Satellite A105 Notebook
AT&T Blackberry Curve 8300 Smartphone Logo
46 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
