Televison & Video Logo
Anonymous Posted on Oct 04, 2009
My sony tv displays the screen on three differen colors almost like 3d picture already tried to do the self adjustment in front of the tv by the menu button what can i do now
Anonymous
Level 2:
  • Expert 83 Answers
  • Posted on Oct 04, 2009
Anonymous
Expert
Level 2:
Answers
83
Questions
Helped
27614
Points
207
Pls. this problum is convesouns Adjesment on Remot cantrol
PRESS MENU button and menu on the screen
DOUN Arow to bottom and Adjest converson left to right and top to bottam the cross line maching 3 colour line and cross line is total white is ok see the pictur is ok
Testimonial: "thanks "
1helpful
2answers
Everything looks out of focus and the color hue is really bad. how can i fix this
Tv have a problems known as a convergence problems.The tv convergence board it is dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board must be replaced to fixed the tv convergence board to solved the tv convergence picture problems.U have all the tools and also can do ICS chips soldering?Yes,than tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a tv convergence kit that belong to ur tv make and model and repair it ur self.Or the shop will cost u like $300-350 for parts and labors.
My colors are not blending correctly anymore. My green is giving me a double picture. I have tried to blend them on the front and back but not luck. I need help
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Picture looks like 3d i have ajusted screen but keeps going back to 3d and picture is bowed
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
1helpful
Seeing double with the picture - a lot of shadows with the picture?
•Screen looks 3D
Picture looks 3d and a little blurry
•Screen looks 3D
Picture red and blue shadowing
•Screen looks 3D
Picture appears to be 3d
•Screen looks 3D
1helpful
Getting a 3d image picture and a bow at the top and bottom of screen what is it?
•Screen looks 3D
The picture looks 3D
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
Mitsubishi 290p080020 big screen tv
•Screen looks 3D
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
