Question about Freud FT1000EK Plunge Router/Laminate Trimmer Kit
Need to find new base screws sstripped on tightening of old base. Where can I buy replasement.
    Problem Solver:
  • 14 Answers
Go to FREUDTOOLS.com buy from them I have several times good folks 1 800 334 4107. don't try a substitute until you talk with them.
good luck!
Posted on Nov 21, 2009
How do you replace radio antanna
What kind of car is it? If it is a fixed antenna you just unscrew the old one and screw on the new one. If it is an automatic antenna, you can buy either the motor or the mast. Assuming you just need to replace the mast, it comes with the plastic piece with the teeth on it. You need to remove the old broken plastic piece from the antenna motor. You might need to disassemble the antenna motor from the car to get enough of the plastic to grab onto with pliers. While you are pulling on it have someone turn on the radio to activate the antenna up motion and pull the old plastic piece completely out. With the old plastic runner out, the motor installed on the car, and the radio on, run the new plastic runner first through the doughnut screw that holds the mast to the car. Then cram the new plastic runner as far as you can into the hole that leads to the antenna motor. Then hold the very end of the mast (the tip), align the base to the opening as best you can and have someone turn off the radio to activate the down antenna motion. It goes quick so don't have your fingers where they can get pinched as the motor sucks in the plastic and the mast down into the hole. With the mast retracted, tighten the doughnut screw to that the mast won't flop out when you turn the radio back on.
Mar 12, 2015 | Cars & Trucks
The Faucet handle and it's base are loose and need tightening.
Try removing that Allen screw completely. There may be a second screw behind it, deeper in, that you can tighten. I see that from time to time - the inner screw does all the tightening, the outer screw just locks the inner one in place.
Jul 31, 2014 | Moen Plumbing
Trying to fix philips iron 1830
you must go to www. repairclinic.com and buy it or go to the supplier from the electrical iron. or you can go to some home depot and proove it some screws and buy it for fix it.
God bless you
Oct 01, 2012 | Irons
How to tighten mown faucet. Wobbles at base on countertop
There are screws that come up through the bottom. You may have to remove the faucet to tighten it. While you have it out, throw it away and buy a new one.
Feb 04, 2018 | Moen 7840 Camerist Single-Handle Kitchen...
How to fit belt on flymo tc380
Too replace the belt you need to remove the motor and base plate assembly, remove the box, remove the front cover over the motor, pull the two wires off the motor terminals, turn the mower upside down,remove the blade bolt and blade, remove the impellor, remove the four cross head screws underneath, there are two more screws toward the front of the machine, once all out the motor and base plate will come out as an assenbly, slacken the four motor screws and push the motor forward, remove the old belt and fit the new one, wedge a screw driver between the motor housing and base plate force the motot forward to tention the belt at the same time re tighten the motor screws, re assemble in the reverse order.
Jun 16, 2012 | Garden
How to replace a bulb
Hello
To replace bulb in RCA rear projection TVs follow this.
Turn the lamp assembly so that the front of the bulb faces downward
Locate two clips approximately three inches apart along the back edge of the rear lamp cover. Depress the clips with your thumbs and pull upward on the rear lamp cover to disengage it. Move the rear lamp cover so that you can see the head of the bulb. Note that the rear lamp cover still connects to the base of the bulb by a cable.
Locate the three hex screws around the head of the bulb that, in a triangle formation, secure the bulb to the assembly. Remove the screws with a hex screwdriver.
Pull the bulb and rear lamp cover upward to remove them.
Remove the nut that connects the cable from the rear lamp cover to the base of the bulb with a wrench. Disconnect the cable from the old bulb and discard the old bulb.
Reattach the cable from the rear lamp cover to the base of a new bulb and install the nut. Tighten the nut with a wrench
Install the bulb face down into the lamp assembly. Install the three hex screws into the tabs along the edge of the bulb and tighten with a hex screwdriver.
Reinstall the rear lamp cover onto the lamp assembly and line up the tabs with the holes along the side of the assembly. Press downward until the cover snaps into place.
Reinstall the lamp assembly into the back of the television, facing the bulb towards the center of the TV set. Tighten the screws securing the assembly and reinstall the lamp access door. Tighten the screw on the lamp access door.
Mar 22, 2011 | RCA D61W20 61" Rear Projection Television
A 1997 ford falcon station wagon that cuts out some times
Problems can be the ignition module on the side of the distributor. (very common) or the ignition coil under the inlet manifold. Both a little hard to access but can be done. The module fault usually kills the motor completely, often wont start cold. the coil often causes missing. Id reccoment changing the module first. Mark the base to engine block with whiteout. loosen the locking bolt on the distributor and rotate it so as you can get at the screws on the module with a stubby screwdriver. Disconnect the multiplug remove the screws and module.replace the module putting the silicon grease on it as per the old one. (grease usually supplied with the new module. Replase the module and multiplug. Turn the distributor back to its marked position and tighten the bolt . Done Usually fixes the problem.
If this has been helpful Please Vote Jeff
Mar 13, 2011 | Ford Econoline Wagon Cars & Trucks
Where can i get a replacement antenna for my ge portable super radio? also, how about info on installation.bthanks,norm.
Radio shack has replacment attennas. There is a scew in the back of the radio below the attenna. Loosen it. the lower part of this and the attenna will come out. at the top of the base part is a screw where the attenna bends back and forth. remove this screw and take off the top of the attenna (the telescoping part of the attena) get a replacment attenna thiis length (of top part). The bottom of new attena will have a screw toward the base where it bends back and forth. Take this screw out and replace the new attenna base with the old attenna base (the new attenna base won't fit in the radio correctly) Now insert the fixed attenna back in t he super radio and tighten the screw on back of radio. Hope this helps.
Feb 26, 2010 | Audio Players & Recorders
I broke the Stand that my 42''LG sits in. I need to buy a new one
You can find a new stand/base assembly for this model at the following link (Please note: the screws used for the base assembly are not supplied, so you would have to reuse the old screws):
LG 42LC2D Replacement Part Stand / Base Assembly
Dec 30, 2008 | LG 42LC2D 42 in. LCD HDTV
Freud FT1000EK Plunge Router/Laminate Trimmer Kit  Logo
49 people viewed this question
Top Freud Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
jairo sanchez
Are you a Freud Tool and Hardware - Other Expert? Answer questions, earn points and help others
