Where would i find a liteon ps5221-06 power supply
    Sergeant:
    Novelist:
  • 191 Answers
The PS-5221 is currently OUT OF STOCK. Please do not add this item to the cart if you click the link above. If you have any questions, please contact us.
Thanks,
COMPUTER PARTS OUTLET
Posted on Feb 17, 2010
Blows fuse
If your Liteon 32276 power supply board is causing blown fuses, there are a number of things to try.
Try plugging into a different outlet in your house to see if the result is the same.If the result is the same, you may need to replace your liteon 32276 power supply board as it may be defective.
Apr 16, 2012 | Computers & Internet
Rh11@gmail.comdoes not fire up green power light on but cooling fans dont run and multi meter does not register any power through
Remove power supply from PC, connect it to AC power, then connect green wire with any black wire.
If it starts - check 12V AC, 5V AC.
If it doesn't - there are no user serviceable parts inside, just replace power supply
May 19, 2011 | Lite On LiteOn 204Watt PA-4022-6B Power...
GERICOM laptop power charger - Liteon model PA-1900-005
yes this is common rating for laptop any laptop adapter can be replaced see the output voltage and current of another adapter matching . if connector is not matching then solder the matching connector
Mar 03, 2010 | Computers & Internet
Cannot locate the fuse in the liteon power supply
The fuse is internal, and soldered to the circuit board. It can be replaced by soldering - an old-timers trick is to get a new fuse (with pig-tails) and just solder in parallel with the old - no removal needed.
Jan 31, 2010 | Lite On LiteOn 150W LPX Power Supply...
Turning on a Liteon power supply without being hooked up to compu
On the main plug there are several black wires(ground), and one green wire. Jumper any black wire to the green wire and there you go.
Dec 13, 2009 | Computers & Internet
Hooking up a Liteon 24X DVDrw burner
The SATA drive is to be used with a motherboard that supports SATA 1 or 2.
If you have a board that supports SATA, you should also have a power supply that supports SATA.
The 7 pin connector is for data. the other connector is for power.
Hope this has helped you.
P.S. Their are conversion kits for the power supply if yours does not support SATA but your board is something else all together.
Get back to me with the make a model number of the PC and I will check if you want.
Sep 15, 2009 | Lite On LITEON 8X DVDRW +/- Burner
Acer aspire computer with liteon power supply PY300B00153201AA6E
power supplies are easy to replace. usually 4 screws. open the pc. remove the screws and unplug it from the motherboard. a replacement costs 40-60 dollars. plug it into the same place(s) you unplugged the original pwr supply. replace the screws. replace the cover and thats it.
Jan 08, 2009 | Lite On LiteOn 204Watt PA-4022-6B Power...
Computers & Internet Logo
1,483 people viewed this question
David Payne
David Payne
