Question about Nokia 6070 Cellular Phone
My phone is having a problum that, I am not able to call STD Land line. I am not able to hear the ring sound and nothing is heard from there. But they are picking the phone there. My amount is deducting from the account.
  • 111 Answers
There should be a problem with your network.
Posted on Oct 04, 2009
Why dont telstra ring me on my land line is it to hard i have rang my member in parliment she said if i dont hear by monday to ring her back
Sadly this type of question is not what FIXYA handles . we have no control of what a parliment member does or doesn't do in regards to a phone call . it certainly has nothing to do with fixing a car/truck
Oct 28, 2017 | Cars & Trucks
Phone rings answer phone can't hear
I would GUESS that you have VoIP and the problem is with the provider. If you have one, plug in anon-battery hard wired land line style. If you don't, get one. If cell towers go down, you might still have service. Put it on a shelf until it is needed.
May 29, 2017 | Answer Lands Phones
I canot hear it ringing when anyone calls. there is a dial tone,and i hear it ringing when called from another line but no ringing on my end
Because you said you have a dial tone I'm guessing that this is a land line (home) telephone. Make sure that the ringer volume is turned up. You may have to search for it but it is located somewhere on the phone. Plug another phone into the same jack and if this unit work replace your phone(very cheap). Still not working then you may have a defective phone cable which must be replaced.
Hope this help with your problem.
Jan 07, 2011 | Cell Phones
Can't be heard
Sounds like you have a defective microphone in your handset. Maybe caused by dropping of phone or water damage. Try land line phone not cordless. Just to ensure that you can hear the caller and can be heard over your phone line.
If you can complete a call successfully go and purchase another cordless phone.
May 29, 2009 | Vtech IA5854 5.8 GHz Cordless Phone
PIXMA MP780 will not receive fax with Verizon DSL connection. Before unit was ok with comcast cable, Note: I'm able to send fax. RBRANT
Solution: Contact local phone company to check the telephone wall jack for low ring voltage.
Ring-in Voltage Facsimile equipment?(fax machines), like other telephone anwering devices, require ring voltage at a telephone jack to answer automatically.? The ring voltage is one of the services provided by the local phone company.
  • Low ring-in voltage can cause short bursts of ring tones at the phone jack.
  • Callers may hear one or two ring back tones and then ringing will stop and nothing else will be heard.
  • Inside the home, the called party will hear a brief ring and then nothing else will be heard. If the telephone handset is lifted, the caller may be on the other end.
To check if the fax will not answer due to low ring-in voltage, do the following:
  1. Disconnect the fax at the telephone wall jack.
  2. If an answering machine is available, connect it directly to the telephone jack. If an answering machine is not available, connect a telephone to the telephone jack.
  3. Dial the fax line and see if the answering machine answers the call, listen for uncommon ring tones inside the home or check for similar symptoms as described above. If any of the above symptoms occur, please contact your local telephone company.
May 05, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Ringing sound on a Toyota Land Cruiser SX 2L Turbo 1991 Model
noise producers on vehicles include the worn brake pad indicator that rubs on the disc when the pads are dangerously low , loose seal shields on the diff pinions , tail shaft noise from failing bearings , "U" joints , center bearing supports and shields for that bearing touching the support bracket from failed bearing rubber mount
if is only heard when moving ,what I am suggesting that everything that turns has to be carefully inspected
for example a bit of rock stuck between the diff flange seal shield and the diff housing will create a noise that is amplified by the tail shaft
Jul 18, 2017 | 1992 Toyota Land Cruiser
I just bought the Linksys CIT310 IP Wireless phone
Hi
On the phone menu, select "Base Settings" then click on "ringer type". The volume there has 1 - 5, try increasing the volume.
Jul 29, 2008 | Linksys CIT310 IP Wireless Phone
Cant hear nothing!!!
Yes the problem is coming from the speakers , so take the phone to a repair center and have them replace the speakers for you.
Jul 09, 2008 | Sony Ericsson W850i Cellular Phone
Missing calls
I had this problem once and on my phone I would get one ring and then it would stop. Checking the phone I saw I missed a call. I live in the mountains of Puerto Rico and I believe what is happen is the network plays the rings for the caller but the phone isn't doesn't get the signal or start ringing until 3 or 4 rings later. In other words the caller has already heard 4 or 5 rings and has given up. While you have heard only one ring and when you got to the phone you already missed the call. I told my friends to let it rings more then 5 times before giving up and that worked.
Dec 08, 2007 | Kyocera Oystr KX9 Cellular Phone
Nokia 6070 Cellular Phone Logo
56 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
