Question about KitchenAid Superba KSRS27CN Side by Side Refrigerator
Stinky water from frigidaire side by side.
The water coming out of my frigidaire side by side is stinky. Happened after I changed the filter the first time. If I run enough water (about 3 pints) the water is no longer stinky. Smell comes back in less than an hour. Not sure if it's the line or the filter.
  • 109 Answers
Check your outlet line, probably it is jammed. Thanks
Posted on Oct 04, 2009
Dehumidifier smells stinky
Have you read its manual? http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0220en.pdf
It says (p8):
Care and Cleaning
1. Filter
a. Remove the filter every two weeks based on normal operating conditions.
b. To remove the filter, remove Bucket then pull filter downwards.
c. Wash the filter with clean water then dry.
d. Re-install the filter, then replace Bucket.
2. Cabinet
a. Dust cabinet with an oil-free cloth, or using a damp cloth.
b. Vacuum grill using brush attachment.
3. Water Bucket
a. Clean bucket with warm water and detergent.
I recommend you to use a mix 75% water, 25 % vinegar. To clean its water bucket.
Oct 01, 2012 | Frigidaire FDF70S Dehumidifier
Stinky drip pan
Try vacuuming and cleaning the coils on the bottom of the fridge. The water is supposed to evaporate by the heat/air movement and if that is being slowed by dust and junk clogging the coils...it won't evaporate the water.
Jun 11, 2011 | Frigidaire FSC23F7D Side by Side...
STINKY, STINKY, STINKY It smells bad
check base for proper seal ie:wax ring and or caulk at base of bowl
Nov 01, 2010 | Saniflo 013/003/005 Sanibest Toilet with...
Stinky smell
the drains/vents need to be cleaned out with clorine bleach solution.(leave the doors open to dissipate the gas after)it is very common for the drain hose to get a black moss residue blocking it,and people pay a fortune for a callout to fix.lovely........
May 29, 2010 | Frigidaire FRS3R5EMB Side by Side...
Is there a filter on the model KSBS20QEBL0? The ice has a terrible smell - have cleaned with baking soda, with no results.
i stinky piece of fish or any thing stinky in the frig side will smell up the Ice. Dump all ice wash out the bin with bleach and water.
Some frig's have a filter , some do not.
Nov 21, 2009 | Ovens
Same problem. Stinky, moldy, gunky. Clothes won't clean.
First take a gallon o bleach pour it in on hot and run,then from know on after washing leave the door open so it can dry out and not mold between loads.
Nov 15, 2009 | Frigidaire GLTF2940ES Front Load Washer
Duet washer is stinky.I leave the tub door and the soap dispenser door open when not in use. Even so, epecially after doing several loads in a row I have a very stinky machine There is mold growing on the...
are you on a well??
do you use bleach in with your whites??
some well water untreated can cause exceptionally stinky machines, especially if no or very little bleach is used during white washing..
usually if you use bleach in with your whites in normal amounts and leave the door open in between uses there should be very little stinky odor or mold growth.
the mold growing on the gasket is a sign of to little bleach or none being used, and/or a really damp environment for the unit to reside in.
they do make several cleaners designed just for stinky front loader washers..
they might help..
i've been using a front loader for 13 years, leave the door ajar between uses, and use bleach in every white load and have had no issues with stinky unless i or someone else doing wash forget and close the door for a couple days, then it gets stinky but goes away after white load with bleach and hot water..
hope this helps,
best of luck,
ttfn
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stinky washer
you will always hear a bit of water in the tub after washing. buy a package of 3 tablets called AFRESH and follow the directions on the package. this product was designed specifically for the problem you are having. also, always leave the door open a little bit after washing. hope this helps.
Oct 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water will drain out
I had the same problem-you have to open up the bottom front panel and unhook the filter. (has two clips that you need to unhook before you remove it) (If you are a woman-find a guy to do this-I cursed on those clips for two days before I was able to get them back on!) Make sure to put a bowl or a towel underneath as all the sitting/stinky water in the filter that is stuck there will come out. I found a sock and pennies!
Apr 26, 2009 | Frigidaire GLTF2940ES Front Load Washer
KitchenAid Superba KSRS27CN Side by Side Refrigerator Logo
125 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
