Question about Samsung SL201 Digital Camera
Camera is a sl202 samsung digital camera ,wont stay on beeps then goes off,it brand new.
SOURCE: samsung digimax s500/cyber530 won't start with new batteries
I have a samsung digital camera digimax cyber 530 - just replaced batteries and camera wont start, i get 3 flashes from the green light screen nw comes on then goes off & the lens wont retrack back in the camera
Posted on Jan 17, 2010
  • 11967 Answers
SOURCE: samsung sl202 trouble!
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 03, 2010
Testimonial: "Thank you! Your advices were very helpful!"
  • 235 Answers
SOURCE: how do you charge the samsung SL202 camera
You charge the rechargable battery in the camera by turning the camera off and connecting to a USB port on your PC (not a USB hub). If the red LED is on the battery is being charged. If the green LED is on the charge is complete. If the red LED is flashing there is an error and you should check the seating of the battery. The USB port must provide 5V and 500mA for a complete charge. the manual for your camera is at http://downloadcenter.samsung.com/content/UM/200909/20090930164417500/SL202_English.pdf
Posted on Mar 03, 2010
  • 11967 Answers
SOURCE: my samsung sl202 is not working how do i get it to work?
Posted on Jul 06, 2010
SOURCE: my samsung pl100 wont turn
OK this might sound harsh but i just did this. I pushed in, gently with some force, on the lens while pushing the power button. It made a gawd awful crunch sound, but it worked. Good luck.
Posted on Dec 30, 2010
Wont trun on
Why does my DELL Inspiron 1525 not recognize
my Samsung SL202 ????
Dec 17, 2013 | Samsung SL202 Digital Camera
Tip
Samsung SL202 QuickStart Download Have you misplaced your Samsung SL202 Quick...
Have you misplaced your Samsung SL202 Quick Start User Manual?
Would you like a digital, searchable, pdf version of the Samsung SL202 QuickStart Guide?
Follow this link to download a pdf version of the operations manual / instruction guide.
I hope that helps.
_________________________________
SL202 User Manual here.
SL202 Yellow Flashing Light.
on Apr 18, 2010 | Samsung SL202 Digital Camera
Tip
Samsung SL202 Manual Download Have you misplaced your Samsung SL202 User...
Have you misplaced your Samsung SL202 User Manual?
Would you like a digital, searchable, pdf version of the Samsung SL202 Owners Guide?
I hope that helps.
SL202 QuickStart Manual here.
My samsung pl100 wont turn on. the lens is extended and its fully charged the green light comes on then beeps and shuts off. This camera is brand new ive only had it 1 week! how do i fix it?
Dec 23, 2010 | Samsung SL202 Digital Camera
It the lens slides out half way and makes a beep noise and goes back in
Hello
The lens gears might be damaged or out of calibration need to be handled by Samsung support nearest you or claim the warranty if it has.
Some time the low battery gives the same problem
Good Luck, and do rate the solution if helped
Dec 22, 2010 | Samsung SL202 Digital Camera
Samsung SL201 Digital Camera Logo
48 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
