Question about Alesis M1-Active MkII Main / Stereo Speaker
My alesis m1 active 620 monitors blue lite keeps blinking and duz not work
Thanks for following up...I took it to get fixed..$150.00 later it works..
Posted on Oct 08, 2009
Power Supply bad working. Blue led doesn't light.
Hi, I'm having the same problem with one of mine M1 Active 620. Please have you found out characteristics of D5 Zener diode, voltage?
Nov 13, 2012 | Alesis M1-Active-MK2 Powered Studio...
Alesis 620 M1 active no power no light
You just fix the power supply and Brige and check the transformer
May 18, 2012 | Alesis M1-Active MkII Main / Stereo...
Alesis M1 active 620 woofer problem
There clearly is a fault in the sub's amp section. It's probably the main part that does most of the work. It will need to be replaced.
Mar 07, 2017 | Alesis M1-Active MkII Main / Stereo...
Alesis M1 Active MKII Don't get power / Blue light is off
Sure they don't have power? Light breaks all the time on those things. If no power still, open it up and find out if there are any loose connections from the power leads. Bad power cable?
Mar 16, 2010 | Alesis M1-Active MkII Main / Stereo...
Alesis M1 Active 620 studio monitor cutting out
I see from the manual there are several controls on the speaker that could affect the sound in the way you describe (gain, hi- and mid-boost, acoustic space). Why don't you compare the actions of each control with the working speaker as the standard and a test tone or FM noise as the source? It might help you to identify a specific internal function that has changed. After that, someone's going to have to crack it open and do surgery.
You might also try using the opposite input (TRS vs XLR) than the one you're using. It might reveal something.
Mar 13, 2010 | Alesis M1-Active-MK2 Powered Studio...
Alesis 620 m1 active studio monitors sound cutting out
It could be a power problem, unless you have blown the driver ?, carefully pull out the power supply board, and look to see if anything looks melted, burned, or capacitors popped etc. Be carefull though as I do not want to be responsible if you get an electric shock, etc. preferably look and dont touch, just use common sense ;)
Feb 10, 2009 | Alesis M1-Active MkII Main / Stereo...
Alesis M1 Active MK2 Biamplified Reference Monitor not working
Hi Mate, This seems to be a common problem now, go here looks like you need a new capacitor or two, possibly a resistor aswell depending.
http://www.neufeld.newton.ks.us/electronics/?p=232
Jan 14, 2009 | Alesis M1-Active-MK2 Powered Studio...
ALESIS M1 ACTIVE MK2 CONE VIBRATION!
Hello!
my speaker Alessis M1 Active 620, with a roar is very strong in the speaker, the potentiometer does not attenuate, change the volume. Ja switched capacitor C8, based on my research of other users, but got no result. When you press the power button, the LED lights in blue, and even change the color to red, producing a noise (snoring) very strong.
help!
Please help me!
Mar 17, 2008 | Alesis M1-Active-MK2 Powered Studio...
Alesis M1-Active MkII Main / Stereo Speaker Logo
765 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Gil Shultz
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
