Question about RCA CC6263 Camcorder
White screen it turns on but only shows white sceen. can't playback anything or view menu screen. only see white. please help
  • 3 Answers
Its time to show it to an approved repair shop, your display seems to have gone. I too had similar problem got it rectified at Service center.
Posted on Dec 22, 2007
Display does not show any view
You know you can change the monitor brightness? Check the manual (eventually online) to see how to change the settings. Please check if you can playback pictures you already shot, to make sure the display still works.
You also could remove the battery, charge it and then replace it. This acts like a cold boot from a computer.
May 24, 2014 | Olympus FE-210 Digital Camera
There is something wrong with my Nikon D3000. It turns on but doesn't show anything on the screen and when I look through the lens it's shows a grainy dark film. It can't be the lense because I...
There seems to be two separate issues here. I'm going to assume you have a charged battery pack in the camera.
First, the screen. Turn the camera on. Do you see the menu when you press the MENU button? Does the shooting info show when you press the Info button? Can you see previously taken photos when you press the Playback button? If none of those show up then something is wrong with the screen (or the battery is dead).
Second, the viewfinder. First, make sure the viewfinder in the back is clean. Now turn the camera on and look through the viewfinder. Do you see the eleven focus marks? Do you see the info at the bottom? Now turn the camera off and remove the lens. Don't touch anything inside the camera! Do you see a mirror at a 45-degree angle? Is it clean? Look at the focusing screen above the mirror. Is it clean? Now look through the viewfinder and point the camera out a window. Do you see a more-or-less white blob, or the same grainy dark film?
Apr 11, 2013 | Cameras
No view on screen of what is showing in front of lens. Menu and playback shows but nothing when i turn to camera mode or video mode.help!
CCD Failure !
Lucky u can get it repaired Free just call Sony in ur region see link
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
May 05, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
My Sony Ericsson W580 just shows a white sceen an i cant go to anything else
More than likely you will need to replace the display screen but before you do take the screen out and reseat the LCD connector. This will sometimes fix a white screen.
If not, a new LCD screen runs about 15 dollars shipped from eBay and is pretty easy to replace.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony Ericsson W580i LCD Display Replacement
I hope that helps you out
Mar 22, 2009 | Sony Ericsson w580i Cellular Phone
Touch Screen bad on a XL1000
I have posted the answer to this problem if the sceen is misaligned just turn off the machine and hold down the frist to buttons turn the machine back on the singer sceen shows up touch ithe sceen it should freeze and then a small black box should show up touch the box and it should move to a differant spot touch it four times and then rub you finger accross the stright stiche white button at the bottum of the sceen this saves the changes.
Nov 08, 2008 | Singer Quantum XL-1000 Computerized Sewing...
LCD screen flashing
Hi!
This is a feature and not a defect of the K100D. You can turn this off by going to the menu and going into the second tab (playback menu). Once there, go to preview display, where you will have 3 options - off, histogram and brighten areas. Set this to off (your camera is set to brighten areas, that is why the white parts of your photos appear to be blinking).
Hope this helps!
Oct 27, 2008 | Pentax K100D Digital Camera
Playback
While viewing a picture, press up/down on the multiselector to change views.
Dec 19, 2007 | Nikon D80 Body Only Digital Camera
Turn on camera but the lcd sceen is black
Have you checked the display mode you're in? If you have the display set to off (to save power) and also the picture review time set to off, then you'll just see a black screen. Try pressing the 'Disp.' button below the screen when the camera is on - it should cycle through different settings with each press: Off, On, On with picture info. Similarly, in the playback mode this will show you more or less info about the picture you are viewing.
Even if the display is switched off, if you have your 'review' option in the menu set to anything other than Off (i.e. 2 seconds), then you should see the picture you've taken appear on the screen straight after taking it.
If it's not that, then I don't know the answer....
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Monitor screen lights up but no image or menu can be seen
If the screen won't show anything then you are going to have to send it in and have Casio look at it. More than likely the LCD is going out but just hasn't "gone" completely. Give them a call at 800-706-2534 and then option 2 and tell them that your lcd is going out and they'll tell you the closest place to send it.
Aug 01, 2007 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Shooting mode will not operate
Your camera has a defective CCD imager. Please return the camera to Canon in New Jersey and they will replace the CCD at no charge to you. This is a known issue and should be covered under extended warranty. Good luck my friend. Joe Weibel customelectronics.org
Feb 27, 2007 | Canon PowerShot A75 Digital Camera
RCA CC6263 Camcorder Logo
458 people viewed this question
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
