Question about Gateway ML3706 Notebook
I need to know how to get the bottom off my laptop so i can get to the power button and fix the sensor underneat it. i removed all the screws on the bottom yet it wont come off. myl aptop is a gateway ml3706
  • thisxorxt814 Oct 04, 2009
    is there a diagram or a sheet i can follow to do this?
    i really need my computer for school but the power button just stoped.
  • 416 Answers
The bottom doesn't come off......you have to remove the cover on the screen hinge and remove the keyboard and monitor to isolate the "bottom" of the unit. After you have removed the panel on the hinge, you can unscrew the keyboard and detach the screen. At this point the bottom can be removed by taking off the main boards and other connected components.
Good Luck and please rate this post
Posted on Oct 04, 2009
The power button in my Gateway laptop MT6451 got pushed it can't be accessed from the top. How can it be accessed from the button?
Quite easily Sergio
The plastic Power On button you see, presses against a carbon button Power On switch, below it.
I suggest removing the Switch Cover, and then you can access the Power On switch's carbon button, and press it down to turn the laptop on.
You can also, then see about repairing the Power On button assembly, or replace the Switch Cover.
1) Remove ALL power. Remove the AC adapter {Charger}, and Battery.
2) Laptop closed, laid on it's top; Bottom side up.
Turn it so you are looking down in the Battery Compartment, where the Battery was......
Down in the Battery Compartment are 4 Philips head screws to remove. You need the smaller No.1 Philips screwdriver, or the equivalent Jewelers screwdriver.
Here is the Base Enclosure, (Bottom Cover), not installed on the laptop,
http://www.ebay.com/itm/39MA7BATA10-Gateway-MA3-MT6451-Bottom-Case-Cover-39MA7BATA10-Genuine-/321101430142?pt=LH_DefaultDomain_0&hash=item4ac322fd7e
There are 4 views. The page automatically opens, with a Bottom view, and the Battery Compartment at the top.
SET, your mouse cursor in the middle of the photo. This allows the Zoom In feature.
Go to the top where the Battery Compartment is, and view the 4 holes going along the Top.
This shows you where the 4 screws to be removed are.
Same design, different Gateway notebook,
http://www.insidemylaptop.com/remove-keyboard-from-gateway-mt6704-model-ma7/
Go to the third photo down. Has two screws circled in Red.
I just want you to look at the Battery Compartment. (Not the red circled screws)
Look under the whitish - www.InsideMyLaptop.com -
You can see the first two screws pretty visibly. Almost make out the 3rd one, no to the 4th screw.
Once these 4 screws are removed, turn the laptop over.
Open the laptop.
Now you are going to remove the Switch Cover.
In the above link scroll down to the 5th photo, and 6th photo.
This video also shows you,
http://www.youtube.com/watch?v=KjOVOLOW1Hc
From 0:45 to 0:47
Please use care when removing, it is plastic.
The video has been sped up.
This is a look at the Switch Cover removed,
http://www.ebay.com/itm/8015907R-Gateway-CENTER-COVER-MT6700-MT6451-MT6821-MT6828-MT6452-MT6705-GRADE-A-/321068043361?pt=US_Laptop_Housings_Touchpads&hash=item4ac1258c61
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 04, 2013 | Gateway MT6451 Notebook
Touchpad click buttons sticking
Did you waste some sticky soda on the touchpad. Before you try taking the laptop apart just shut the laptop off and repeatedly hit the buttons to try and work them loose from sticking.
If you want to take the touch pad off, you will have to remove the whole palmrest. Get some cups and label them so you will know where the screws you removed go. Also a digital camera might help you. You will start by turning the power off, removing the power cord and battery. The remove the screws from the bottom of the laptop. Remove the memory, the hard drive, the dvd drive. Look inside each one of them and there might be screws to remove especially in the battery compartment. Make sure you look for screws that might have the icon of a keyboard next to it. They secure the keyboard. Then open the lid and remove the strip that is above the keyboard. Be careful because there might be a cable attached to the strip. One the strip above the keyboard is removed, you can remove the keyboard screws and gently lift the keyboard out because there is definitely a cable under it that you will have to remove from the board where it plugs in. Next you will have to remove the screw from the lcd hinge and lift the lcd off. You should be able to just disconnect the lcd cable and have enough room to sit the lcd right behind the base without taking the wifi antennas off. If not you will need to remove the wifi card and antenna from the bottom of the laptop. Next you can pry the palmrest off, but be careful and remove any cables that are plugged in before you remove it. There might also be some screws that hold the palmrest to the motherboard so check for them.
May 12, 2012 | Toshiba Computers & Internet
MBP screen hinge tightening
Hinges are located under the lcd screen and go into the bottom of the base or palmrest. You'll need to remove the strip that is right above the keyboard that normally houses the power button on most laptops. The strip might be secured by screws that are on the bottom of the laptop. Be careful removing the strip, most times there is a cable attached to it under the bottom. Once the strip is removed the hinges are exposed. Just take a phillips head screw driver and tighten them.
Mar 27, 2012 | Computers & Internet
Clothes stuk underneat. Have to remove the agitator.Need to know how.
GE washing machines have a top ( on the top of the agitator ) that screws off to remove the agitator
Feb 11, 2011 | GE Washing Machines
Mr.
There is no need to remove the bottom case.
There are screws on the back edge that fixes the LCD hinges to the base of the laptop.
Remove the plastic panel on the laptop between the LCD and the Fn keys/LED lights/push buttons. You most likely need to fold the LCD flat to remove this panel. This panel is cliped in place, take care to unclip it, start at one end and work along to release it.
There may be further screws that fix the hinge to the base. Also there are cables that connect the LCD to th motherboard, be careful to remove the cables before you remove the LCD.
Feb 26, 2009 | Compaq Evo N800c Notebook
Inspiron 1521 green screen problem
Either the lcd cable is loose on the inverter board, the lcd cable is going bad, or the inverter is going bad. Usually this can be fixed by removing the power button bezel and making sure all the cables are seated properly on their connection. Removing the power button bezel varies from laptop to laptop, sometimes there are screws on the bottom of the laptop that you need to remove and sometimes there are not, it just snaps into place.
Thanks and please take a moment to rate as fixya.
Nov 25, 2008 | Toshiba Tecra 8000 Notebook
Removal of cooling fan
You need to disable your laptop.
follow this step:
Remove harddrive.
1. on the back of laptop, there are 2 doors. open it all. 1 of them is harddrive.
2. remove harddrive.
Remove wireless cable.
1. open 2nd door on the back, you can see rams and wireless card. unplug wireless cable from wireless card.
Remove chassis
1. Remove 2 screws on the hinge cover, so you can remove the power cover (power cover is cover that have power button).
2. after you removed power cover, removed keyboard.
3. remove 4 screws that hold lcd from chasiss. you can remove lcd now.
4. remove 3 screws under keyboard.
5. remove all screw on the back of your laptop.
6. remove upperchassis.
7. remove 2 screw that hold motherboard from lowerchasis.
8. take motherboard out from lowerchasiss.
9. now you can see the thermal fan.
Jun 19, 2008 | Acer Aspire 5050-3242 Notebook
Acer aspire 5610 keyboard replacement
1. you need to remove the power cover (if you see the power button, that what i mean).
2. after you remove that cover, you will see 2 screw that hold the keyboard. Remove both screws.
3. Remove keyboard and replace it with new keyboard.
May 07, 2008 | Acer Aspire 5610-4648 Notebook
Right-click button has collapst on bottom side. have to click at top of button
To disable Aspire 5100.
1. remove battery, harddrive.
2. open all cover on the back of laptop.
3. removed wireless antena cable from wireless card.
4. remove power cover (power cover is cover that have power button)
5. removed 2 screws on the back that hold lcd.
6. removed 4 screws that hold lcd. (now you can remove lcd).
7. remove 2 screws on top that hold uppercase from lowercase.
8. remove all screw on the back.
9. remove heat sink, and remove 1 screw under heat sink.
10. that's all, you can remove uppercase and repair it.
i hope this help you. good luck
Mar 22, 2008 | Acer Aspire 5100 Notebook
How to change a power jack in laptop? Compaq Presario V2000
I did this myself with my HP laptop and after many tedious hours of work I was able to remove the motherboard, remove the dc jack, and resauder a new one on the board and it worked out perfectly.
If you feel comfortable doing the work yourself first start off by removing the screws on the bottom. You then should be able to remove the keyboard, look for a cable that connects it to the board. Now you should be able to remove the pieces of the case around the keyboard, look for the cable connecting the touchpad to the motherboard. After that you should be able to remove the LCD screen, look for the cable connecting it to the motherboard. Now remove the screws holding the motherboard in and remove the tiny bolts around the external monitor connector and the printer connector if you have one. Now you should have access to the DC jack. You will need to sauder the current one off the board and resauder a new one on. Keep track of the many many screws and try placing the components in the order they came out so will know which ones need to go back in in the proper order.
This is VERY tedious if you are not familiar with working on laptop hardware. You maybe able to find a local shop willing to do this or you can look online for a place that replaces DC jacks on motherboards.
Hope this helps!
Nov 29, 2007 | Televison & Video
Gateway ML3706 Notebook Logo
230 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
