Question about Sony Cyber-Shot DSC-S40 Digital Camera
I have a DSC - S40 model. When I open the camera the screen gets white and does not work operate
Bogdan
  • 198 Answers
SOURCE: User manual for digital camera
Hello, Try this link and select download on top of page. Hope this helps. http://www.retrevo.com/search?q=Sony+DSC-S40&terms=review+manual
Posted on May 02, 2007
  • 3 Answers
SOURCE: flash does not work
try going to the user manuel to see of to turn your red eye reduction on and off turn of then reset your flash it should work then
Posted on Dec 16, 2007
SOURCE: Sony DSC-S40 White LCD Screen - Permanent Fix
Needs a little brute force. Release all screws you can find. At the bottom above the o of the word Sony is a plastic lip (or clip) which you cannot see, but holds the camera together.
Do be affraid to pull a bit and it will come off.
Posted on Jan 10, 2008
SOURCE: Still have a white LCD Screen!
Muccione - you are a star. Just saved me buying yet another digital camera afetr my second Sony developed this White Screen problem. Your solution worked brilliantly. Thanks. IanMo
Posted on Apr 13, 2008
  • 36 Answers
SOURCE: shutter of camera not opening up .sony camera model no DSC -W130
You may be need to replace lens cover (barriel block) in this camera.
let me know if you have camera repair experience to provide you further info.
Posted on Feb 10, 2009
Sony cybershot dsc-s40 lcd screen is all white
okay the lcd being white means its replacment of lcd time and not the camersa itself. But to rule that out try taking a pic if you cannot you might got a shutter issue as well.
Thanks hope the information helped
Sep 17, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony DSC S40 screen turnes WHITE in few seconds.
Try pressing hard just under the bottom right hand corner of the screen with your thumb (and second or third finger on the top). Squeeze hard! it works every time for my camera. Good luck.
Jul 12, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
White LCD is displayed on my DSC-40?
turn off camera tap camera a few times on the palm of your hand .this should work
hope this helps you . jada
Jun 15, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
My sony dsc-s40 has only a blank white screen does not work properly
Happy New Year!
My Mom had this same camera and had -what sounds like- the same problem. I found that the connection to the screen was loose. Take apart the camera- you need a tiny philips. If I remember there are only three screws you need to get to. One near the battery compartment. one near the tripod mount (bottom) and one just inside the memory stick slot.
Jan 03, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Blank screen Sony dsc s40
I have sent the solution to you. But take care of your camera if you are going to open yourself. I am not responsible for any damage.
Dec 04, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Blank Screen
I have been facing the same problem with same model and this is permanent problem it seems with this model (Sony Cybershot DSC S40). It causes because of the following:
SYMPTOMS
LCD display is either blank or WHITE. When the cabinet is opened or LCD flexible cable is
touched, the symptom disappears. This is caused by connection defect or poor contact between connector and LCD flex cable due to the pressure or stress created by the rib in the front cabinet
to the connector.
Send me a email and I shall send you the solution (two files) received from Sony authorized person. You have to open the camera to solve this. Do not open the camera . Just get the idea about where the problem is. I never opened the camera even after seeing this solution 2 yrs back. However, I have a plan for going to service centre with this solution. I hope they can open the camera and solve this. But not getting time to go there in service centre.
I used the following temporary solution and it works to get LCD in its normal condition:
LCD looks like a rectangle is not it? Hold the camera in its normal position as you are going to take a picture (camera is switched on and you are not seeing anything in the LCD, which looks white or dull). Now GENTLY PRESS by the thumb of your right hand at a place near to LCD at the BOTTOM RIGHT CORNER of the rectangle (remember not on the LCD (rectangle) but just outside of it) until you see the normal colour of your LCD. Do few times starting with less pressure and then slightly increase it untill you see a normal LCD. I have been following this procedure for the last 2 yrs and not feeling to go for serving. (This solution I found in a forum only).
(mondal_ashok (at) rediffmail.com
Nov 16, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Screen is white and doesn't display area being photographed. Can take pictures.
From camerahacker.com:
1. Hold camera firmly in left hand.
2. Smartly rap front of camera with knuckles of right hand on the "Cyber-shot" logo.
Worked for me :)
// Maxim
May 29, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
View screen is white
go here
http://www.fixya.com/support/t228735-bright_white_screen
make sure you read to the bottom, where the solution is!
May 04, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
DSC-S40 images in open and close area
Sound to me like the shutter assenbly is worn, this cause ventian blinds to appear in you shots and incorrect exposure times. sorry their is no cure
Aug 30, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
