Question about Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator
Fisher and Paykel Freezer
My Fisher and Paykel Fridge has ice covering the rear internal wall of freezer. Is it ok to just defrost and keep using it??
  • Fisher and P... Master
  • 909 Answers
Very possible the door was accidently left open for a period of time. When that happens, moisture latches on to different areas which inturn creates ice build up. In short, do a good defrost and then restart freezer again.
Posted on Oct 04, 2009
Testimonial: "Thank you. Freezer defrosted and working again!"
  • marymac1000 Jul 03, 2011
    May be worth checking that the magnetic door seal is still good. They are easily and cheaply replaced, and will help to keep the door properly shut.
Hi my fisher and paykel upside down fridge freezer the fridge part is not cooling the freezer is working fine ,I've turned off the entire fridge on turning it back on , no changes to fridge .
one of two faults first is the fan that blowscold air from the freezer ro the fridge is not working a very common fault with them or the defrost element has blown and the airway is choked up with ice
Jul 20, 2017 | Fisher and Paykel Refrigerators
The freezer compartment of my F & P Model E522B Fridge/freezer leaks water but the seal appears OK. Why?
draining tube plugged which normally would drain defrost water to a evaporating pan under fridge
Jan 18, 2016 | Fisher and Paykel Active Smart E522B...
Why does my fisher and paykel have water on the bottom of my fridge on the inside all the time
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Feb 28, 2015 | Fisher and Paykel Refrigerators
Freezer working but not fridge
All cold air in fridge comes from the freezer behind the back wall. I'd first check to see if the fan is running and trying to circulate air to the fridge side. If it isn't then you'll need to replace evaporate fan. Fan is located in freezer behind back wall.
Note: If you have a bunch of snowy frosty ice buildup on the back wall in the freezer then you have a defrost issue and you should hire a professional.
Thanks and gl. Appliance Parts
Feb 04, 2015 | Fisher and Paykel Active Smart E522B...
Fisher & paykel active smart fridge not keeping cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
Both fridge and freezer are turned up to maximum cooling but they just aren't cold enough even though the weather is mild. Icecream is very soft - barely frozen and fridge temp is about 8 degrees...
Sounds like a failure to defrost.
Look on the freezer rear wall inside the freezer for ice bukdup.
If there is ice the defrost components ,must be replaced.
Dec 01, 2010 | Fisher and Paykel Active Smart® E522BR...
Ice building up back of freezer and fridge not cooling this is a fisher and paykel active smart fridge frezzzer
I dont work on that brand, however you describe a typical defrost problem, could be the heater t-stat or defrost control.
Oct 05, 2010 | Fisher and Paykel Active Smart E522B...
THE TOP PART (FRIDGE) IS NOT COOLING
Your defrost system may be out. There are 3 parts, the heaters, t-stat and timer. Hope this helps! :>)!
Aug 14, 2009 | Fisher and Paykel Active Smart E522B...
E372B FISHER & PAYKEL FRIDGE WARM
I'd say you most likely need a new defrost element and evaporator Chassis. You'll most likely find there's a big lump of ice behind the evaporator chassis in the freezer inturn blocking the fridge vent or the defrost element is burnt out icing up te Evaporator. It pays to replace both anyway you'll need to unplug the unit and leave the doors opens for 48hrs to defrost it first. cheers
May 16, 2009 | Fisher Refrigerators
We have a fisher and paykel fridge and freezer. The freezer section is at the bottom and it has started leaking around the bottom and I've noticed the bottom of the freezer becomes very icy very quickly. ...
not the seals. the drain is blocked. take the rear panel off inside the freezer and yoy will probably see an ice build up at the bottom. melt off with a hairdryer and follow up with hot water till water flows away freely. if you have ice build up all over the pipework, then you have a defrost system fault and get back to me
Jul 18, 2008 | Fisher and Paykel Refrigerators
Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator Logo
966 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
