Question about Lands Phones
When i press menu, it goes to the messages directly.
  • macgivor May 11, 2010
    You need to give more info. What name and model phone; is it a cell phone or a home wired phone ? Did it come in contact with water or was it left near damp are such as a shower? Was it in a very cold area then brought into a warm/normal area ? How old is it and how much use has it gotten? Are you able to make calls and is there any other function affected or other cross signaled occurrance ? Hope you can supply this info for the best diagnosis. Wait to hear, Macgivor.
    Problem Solver:
  • 10 Answers
You might have it set to that in your Settings.
Posted on Oct 04, 2009
HOW DO I CHANGE ANSWERING MACHINE MESSAGEV ON PANASONIC KX-TGA642C PHONE
The KX-TGA642C is a handset for the KX-TG6421 series phone system. (These are sold as the KX-TG6422 or KX-TG6424, depending on the number of handsets in the initial package.) To record a greeting message, make sure that the phone (all handsets) is in standby. Then press Menu on a handset. Press # 3 0 2 (or use the Up/Down arrow keys to navigate to Ans Device > Greeting > Record Message. Press Select to each menu/sub-menu section.) Highlight Yes and press Select. After you hear the beep, speak your message clearly. Press Stop to end the recording. (The maximum greeting length is 2 minutes.) Press Off to exit the Menu system. If the answering system is on, this message should play.
The manual for the KX-TG6422 has the full directions to change the answering machine message. The direct link to the manual is https://panasonic.ca/PCS/OperatingInstructions/KXTG6411-12-13-14-OI-Eng.pdf . See page 33 for the directions.
I hope this helps.
Jul 03, 2016 | Panasonic Lands Phones
Monitor display says OSD Lockout /no signal input how to fix this?
This document pertains to LCD monitors .
One of the following messages appears on the screen (over the items being displayed).
OSD Lockout
OSD Lock-out
... or similar message.
This message occurs when the Menu button on the front panel is pressed for more than 10 seconds. OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
NOTE: The button may be different and the procedure might vary on some monitors. Please check your monitor User Guide to find the exact procedure if this procedure does not work.
To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
Aug 31, 2013 | Dell Computers & Internet
Power button lockout is on how do I turn it off
to remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away.
== see if this helps==
Feb 02, 2012 | HP W2338H Monitor
How do i put a signature on a pantech link
Text message signatures are the post scripts at the end of text messages. Some people use text message signatures to provide an unrelated, off-top status update to the recipients of their text messages. Other people use text message signatures to attach a favorite quote with every outgoing message. If you own Pantech's Link handset, you use the device's messaging templates to attach a signature to your text messages.
steps:
  • Press the right "-" button to access the Link's menu. Use the handset's directional pad to navigate to "Messaging" option in the menu. Press the center of the directional pad, the "OK" button, to select the "Messaging" option.
  • 2
    Select the "Templates" option from the "Messaging" menu, using the directional keypad. Select "Options" from the "Templates" menu, using the left "-" button and then select "Add New."
  • 3
    Key in your text message signature using the Link's QWERTY keypad. Select "Options" with the left "-" and then select "Save" from the "Options" menu.
  • 4
    Press the red "End" button to exit the "Templates" menu. Press the right "-" button to return to the Link's main menu. Select the "Messaging" option from the menu.
  • 5
    Select the "Create Message" option in the "Messaging" menu. Compose your message with the Link's QWERTY keypad.
  • 6
    Select the "Insert" option before sending your text message. Select the "Templates" from the "Insert" menu. Select your text signature from the list of available templates and then select the "Send" option to transmit your text message.
  • Dec 02, 2011 | Pantech Link P7040 Black Rubber Feel Hard...
    How do I change my original message on the answer machine?
    Which Uniden DECT 6.0 phone do you have? Uniden makes several models.
    For one Uniden phone that I know (DECT-1080), first make sure that the answering system is on. If needed, at the base press Ans On/Off. From a handset, press Menu/OK and use the redial and Phone Book keys to navigate through the menu to AM Operation. Press Menu/OK and navigate to Ans Settings. Press Menu/OK and navigate to Answer On/off. Press Menu/OK and then choose On and then Menu/OK again.
    To set the Out-Going Message, again go to the Ans Settings submenu at the handset, and navigate to Record OGM and press Menu OK. Select OGM 1 or OGM 2 and press Menu/OK. Record your message after the tone. To select the OGM message to be heard by incoming callers, navigate to Select OGM, press Menu/OK, select the message and press Menu/OK.
    Please note that you also need to make sure that the system isn't set to Announce Only in the Message length section. Enter this submenu from the Answer Settings as above. The choices are 1 minute, 4 minutes and Announce Only.
    You can also do set the OGM from a touch tone phone remotely. Press * as the OGM plays and then enter your PIN. Press 06 and then 1 or 2 to select the OGM to edit. Then press 9 to return to the main menu.
    However, on the DECT-1480, you set the OGM from the handset but in a different combination. Press Messages/Mute then 5 (or wait for the announcements to end). Press 8 or press the Caller ID/right arrow to navigate through the menu to 8: Record New Greeting. Press Menu/Select. Wait until you hear "Record greeting" then speak your message normally. Press 8 to end and listen to the playback of the greeting. Press End to save the message. (Select the desired greeting by pressing 6 instead of 8.)
    Most Uniden DECT phone manuals are available from the product page or this list: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl .
    If you provide your model number in a comment, I'll be glad to give you the specific directions for setting the OGM on your phone.
    I hope this helps.
    Aug 08, 2011 | Uniden DECT 6.0 Cordless Phone ID
    I do not have a manual for directions on recording a personal message
    For most of the Uniden DECT phones, you set up the outgoing message from the handset. Make sure the answering system is on. For the DECT1480, press Messages/Mute on the handset when the handset is in standby to enter the answering system menu. Then press 5 (or wait until the current message ends). Then press 8 (record new message). Wait for the prompt and then speak your message. When finished, press 8 again. Then listen to the play-back of your message. Press End to save and exit the menu. Alternatively you can scroll through the list of commands and press Menu/Select to enter the sub menu or command.
    There are several models of Uniden DECT 6.0 phones. If you have a different phone, you should check your manual. The entire list of Uniden phone manuals is available here: http://www.uniden.com/scat/cordlessphones_mnl . Scroll down to your product and click on the version in your language.
    I hope this helps.
    (most of the Uniden phones that I know have the same set of directions for the answering system outgoing message.)
    Jul 07, 2011 | Uniden DECT 6.0 Cordless Phone ID
    Hi there, my business uses Panasonic KX-T7431 Digital Super Hybrid System and we have several lines. when nobody is available to take the call it goes directly to a company message stating are names...
    The introduction message is usually setup as a custom service menu. You need to determine if this is the case by logging into the message managers mailbox and listening to find the current greeting. To log into the message manager mailbox, call voicemail, dial #6 then *98(for 2 digit mailboxes) or *998(for 3 digit mailboxes) or *9998(for 4 digit mailboxes), enter password followed by #. Once in the message managers mailbox, press 5 to record messages. Your introduction message could be the company greeting or a custom service menu. Press 1 for the company greeting and follow the prompts to listen to the greeting. Press 3 for the custom service menu, then enter the custom service number 1-100( in your case start with 1 until you find the current introduction message) and follow the prompts to listen to the message. Once you have found the current introduction message record your new message and save.
    Dec 28, 2010 | Panasonic KX-T7431 Corded Phone
    The language for messages on my new Digimate monitor seems tobe french. How can i change it to english?
    L-1718 press menu on the screen,press + 3 times,press menu again and keep pressing menu until English is highlighted then leave the buttons alone until the menu goes off the screen
    Sep 21, 2010 | Computers & Internet
    V-chip activated
    Hit the Menu button on the TV. 2. 'INPUT SECRET No.' should appear. 3. Press and hold both VOL (+) and CH DOWN (9) on the TV set simultaneously until the message 'INPUT SECRET No.' disappears. 4. The vchip settings should be disabled now and the Parental controls menu should be presented, 'disable' Status if need be.
    Mar 14, 2010 | Sharp 32C-240 32" TV
    Can't turn off the answering machine on the RCA 25205
    it is simple. press menu and hold and it will most likely give you directions, step by-step. there should be on/off switch
    Jul 31, 2009 | RCA 25205RE1 Phone
    Lands Phones Logo
    12 people viewed this question
    Top Lands Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a Lands Phone Expert? Answer questions, earn points and help others
