Question about Toshiba 50HX81 50" Rear Projection Television
Glitchy picture with lines across screen when turned on
When i turn on my tv it takes awhile for it to warm up and for the picture to become clear, before that it has a bunch of glitchy lines and it keeps getting worse and worse.
  • 115 Answers
I can give you detailed guide describing exactly wich capacitors to replace . Your tv really only needs maybe 5 dollars worth of parts. But you must know how to solder and take things apart . also you must be able to put it back together. if only there was some way you could paypal 50 buck to me.;(
Posted on Oct 04, 2009
When I first turn on the TV, and until it completely warms up, there are horizontal lines across the screen that roll so you can't see the picture. As it warms up, the lines slowly disapear until the...
You will need to remove the signal board. This is the board with the RCA jacks and RF connectors. On this board there will be many components that are numbered. You will be searching for two capacitors that are bad. These are the locations and values. The first is capacitor location, C2V29, which is 16 volts at 22Mf , replace this. The next will be C2P05 which is 16 volts at 100 Mf, replace as well. And if you do have the board removed, you should, as well, resolder the pins on the convergence ICs. These are ICs are mounted on large heatsinks. Inspect the board for any and all other bad solder grounds. Thanks for asking and show a few hands of support.
Dec 12, 2010 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-50707 screen is jittery when it first turns on
Sounds like the verticle circuit is failing a honest shop will take of this for you around 180-230 if you want to do yourself youll need a iron and some filters and an verticle ic
Sep 26, 2009 | Mitsubishi VS-50707 50" Rear Projection...
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Blue screen of death on a tv??
this could be three differnt things
1. the crt itself could be bad
2.the vertical ic on the crt board
3. the focus pack or focus block
Sep 19, 2007 | Sony KP-53V45 53" Rear Projection...
Toshiba 50HX81 50" Rear Projection Television Logo
150 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
