Question about Nikon Coolpix 3200 Digital Camera
After downloading images from the camera to the computer the ON/OFF button is pressed but no action takes place, that is, the shutter does not close ( the "nose" does not withdraw and the shutter wil not close as it normally does)
Why does the camera lag when i take pictures?
The camera has to do a lot of work between the time you press the shutter release button and it takes a picture. It has to determine what the subject is and acquire focus, meter the light to set the exposure, and reconfiguring itself internally from displaying the image on the screen to saving it into memory. More sophisticated (and larger and heavier and more expensive) DSLRs alleviate the problem by throwing more hardware at it.
You can reduce the shutter lag by anticipating the action. Press the shutter release button halfway to make the camera focus and meter. Then, when the action peaks, press the shutter release button the rest of the way to take the picture.
Mar 25, 2013 | Kodak EasyShare M552 Digital Camera
There is a delay between the time I press the button to take the picture, and when the picture actually is snoapped. Can I make this delay a shorter time?
This is a common situation with many compact point&shoot cameras. The camera has to do a lot of work between the time you press the shutter release button and it takes the picture; set the focus, meter the light and set the exposure, switch from showing the real-time image on the LCD to capturing and storing a single image, and more. Larger, heavier, and more expensive DSLRs have additional hardware to reduce this "shutter lag" to nothing, compact cameras don't.
There is something you can do to reduce the time, however. If you know where the action is going to happen (a kid getting ready to blow out the candles on a cake, for example), press the shutter release button halfway to focus and meter. Hold the button there until the action happens, then press it the rest of the way. This lets the camera get most of the work done before taking the picture.
Jul 04, 2012 | Kodak Easyshare M753 Digital Camera
I press the button to take the picture but it takes about 5 or more seconds before the camera snaps the shot
That's about par for a moving subject. After you press the shutter button, the camera has to focus, meter the exposure, estimate the color balance, and more. You can reduce the so-called "shutter lag" by anticipating the action, pressing the shutter button halfway to focus and meter, then pressing the button the rest of the way when the action peaks.
One of the myriad advantages of higher-end (and higher-cost) cameras is the speed with which they respond.
Feb 12, 2010 | Samsung SL30 Digital Camera
Camera works but the screen went black A640 except for video and color swap. Did I press a button? I was shooting in cold weather.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
But if you've already tried this, have you also tried downloading any of your photos taken with the black screen to your computer? Are the photos also black? If so, you might instead be experieincing a stuck shutter (possibly due to the cold weather).
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jan 03, 2010 | Canon PowerShot A640 Digital Camera
Mt camera will not show a picture to take the screen is blank when you turn it on
If that didn't help, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Dec 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Camera shows no image through the viewfinder or on the lcd screen.pressing shutter button will actuate the camera, but only image is of a black box.using the display button to turn off the lcd does not...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Dec 18, 2009 | Canon PowerShot S3 IS Digital Camera
My canon powershot SD1100 IS camera lcd screen isn't working. Its black when i try to view the picture and take the picture
You may have just accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the screen on and off to save batteries. You would then use the optical viewfinder in its place. Press the DISP button once with the camera turned on to see if that corrects the problem. If this doesn't correct it...
Jul 30, 2009 | Canon PowerShot SD1100 IS Digital Camera
Screen is black on camera Cannon PowerShot SD750
Am assuming that you've already tried pressing the DISP button, and that didn't fix it. Have you tried downloading the photos since this occurred? Are they also black? If so, then you're likely experiencing a stuck shutter.
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 03, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Shutter stays closed on bronica 645 etr medium format
Have the electronic shutter checked by a repair shop. Sounds like your Seiko electronic shutter has died or there's a short somewhere between shutter and lens. Hope this helps.
Fotobean
Jan 15, 2009 | Bronica ETR-Si Medium Format Camera
Miss all the action shots with this camera
The longest part of the shutter delay is caused by the autofocus mechanism. Most cameras will let you press the button half-way down and wait until the autofocus is locked. Then wait for the action to occur. When you press the button the remaining distance, there will be a shutter delay of about 0.2 seconds before the picture is taken. Using that technique will let you capture action shots. There is no way to improve shutter delay on any particular camera. The newer digital cameras are showing improvement in this area. Some are achieving autofocus lock in 0.4 seconds and shutter delay of an additional 0.1 seconds.
Sep 06, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Nikon Coolpix 3200 Digital Camera Logo
37 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
