I loved this monitor up until about a month ago, now I have the same problem as you guys. If I repeatedly turn the power button off and then on again, I eventually get the display to stay up. I expect I'll have to buy another monitor soon and it sure won't be a Sceptre.
My Sceptre Komodo 19 would turn on for less than a second than turn off. Eventually, I could get it to stay up. But after a month, I couldn't get it to stay on anymore.
I found the solution on this website. There are some bad capacitors... 4 of them for about $2 worth. I replaced all four and the monitor works fine again. They are soldered in. They are polarized; they need to be installed the right way.The white stripe goes towards the “wall”.
2 are 470uf 25v and 2 are 1200uf 10v.
I ordered mine for about $10 with shipping from Mouser.com 661-EKZE250ETD471MJ1 and 647-UHE1A122MPD
Was this helpful?
Yes
No
Popular Solutions for Sceptre X9G Komodo IV 19 in.
Monitor has no power (ie. no light). Has integrated pwr/aud/logic/inv board. No visible signs of any...
(More)
Monitor has no power (ie. no light). Has integrated pwr/aud/logic/inv board. No visible signs of any problems. Only have 1.6v at pwr switch, and 5v going to logic side of board. Board is model 490491200100R, can't find any information on this board.
hello. how did you reset the eprom on the lcd monitor? my monitor turns on for 2 seconds then shuts...
(More)
hello. how did you reset the eprom on the lcd monitor? my monitor turns on for 2 seconds then shuts off. i took it apart and when i lift the glass and put i flashlight behind it i can see that the monitor works but the bulbs are not turning on. is there a way to apply separate power to the bulbs?
just like antdotwhat my monitor started doing the same thing as theirs on the same date. I turned...
(More)
just like antdotwhat my monitor started doing the same thing as theirs on the same date. I turned on my computer and the on light flashed on and of constantly this time with a black screen. I turned the computer off and back on and the monitor started working properly. This morning I turned it on and same thing. I tried turning the computer off and this time it would not work. I tried this several times. I think the monitor is no good anymore.
