I was given a Scrittura Mosaic B/W ball point pen as gift; I got curious about replacing the ink cartridge, which should be simple enough to do; but there doesn't seem to be any way to remove it. Is this type of pen sealed, so that once the ink runs out, the pen has to be discarded? Help!
  • 624 Answers
SOURCE: Black ink print failure after cartridge replaced
The Edge, -Clean the electrical contacts on the printer where the cartridge connects with alcohol. After it dries clean the same contacts with a regular pink, non-abrasive pencil eraser making sure you remove all the debris when done. -Its also possible there is an air bubble preventing the flow of ink. You can try inserting a full cartridge of ink in the printer and letting it sit overnight then running a nozzle clean job or two. Another alternative if you have a syringe you may want to try gently forcing ink into it. If you?re really desperate you can try drilling a small hole into the cartridge to give gravity feeding a hand. BE WARNED the air hole will let ink flow pretty well and you run the chance of making a mess. Before you pull the cartridge out of the printer make sure you cover the hole with tape so the ink doesn?t make even more mess. -Check the cartridge alignment making sure the contacts are mating to the printer. -If it still doesn?t work I would try cleaning your nozzles. Even though I doubt you have clogged nozzles its worth a try because of the following: If you search the Internet you?ll find that this specific model is know for failing to print some or all colors after about 1 ½ to 2 years of use, even with Epson inks. Most of the posts I?ve seen blame it on clogged nozzles but I suspect a good number of them, like yours, have another explanation for their failure. Ink jet printers use resistors to create heat to create a bubble in the ink to eject it out of the nozzle (Bubble jet) or in the case of Epson, vibrating crystals push ink into and out of the nozzles (piezoelectric). We?ve already cleaned the electrical contacts and cleaned the nozzles so what remain are defective nozzles, short between the nozzle and the controller board or a defective controller board. Since the printer is only worth 1 or 2 hundred dollars repairs at a shop or buying these repair parts can easily exceed ½ its cost. Hope something here works for you, I just recently had to toss a great printer too. Let us know what happens and please don?t forget to rate the posting.
Posted on Jan 20, 2007
  • 60 Answers
SOURCE: black ink replaced, but no black letters or words
Seems like the ink has dried in the print head or the control circuit to make the black ink print, is not working.
See my other post in the ip3000 section re. cleaning the print head and give that a go. I have got a print head doing that right now. If I can't ink to go thru the head thru either warm water washing - next step is to drop Video Head Cleaning fluid ( Iso Propyl achohol) onto the tiny screens on the print head to see if that will works its way through.
If you get ink coming thru the print head, and it still wont print black, then it may be an electronic problem. Other than cleaning the gold contacts on the back of the print head, there probably is not a lot more you can do other than look for a working secondhand pprinter - I love mine ( when its going)
Posted on Feb 22, 2009
jumptrout51
  • 3361 Answers
SOURCE: How to remove ink from dryer
None of the chemicals you describe should be used. The heat or spark from the motor could cause a explosion.
Put some old laundry material in there and run it multiple loads with no heat it will eventually wear it off.
Posted on Apr 06, 2009
websnail
  • 419 Answers
SOURCE: Epson Dx5050 blocks any printing once it has
Unfortunately you cannot override this behaviour without installing a valid cartridge in the printer.
Epson printers do not have this sort of functionality as it would leave the printhead open to damage and foam clogging.
Sorry to be the bearer of bad news.
Posted on May 19, 2009
  • 174 Answers
SOURCE: trouble removing cv axle from 1999 pontiac grand prix
you will need to take the two bolts out of the strut that connects to the spindle backing plate.this will let the backing plate pull out enough to pull the cv axle out.
Posted on Jun 12, 2009
The black ink does not work even with a new one.
Dear friend., This is tricky model printer.. U re just replaced the ink tank, not print head. Seems Print head was clogged..
For example 1. suppose you filled ink in fountain pen, if nib is faulty pen wont write.. 2. If you are using ball point pen, replacing the refill again it will work. We can say your printer as same as fountain pen. Only way is go to the nearest service center ask them to clean the print head nozzles, there is no other alter because, to reach print head lot of mechanical parts has to be removed which i can't suggest you to do so & there is no replaceable print head in side., sorry no help from my side..
Mar 13, 2014 | HP Photosmart 3110 All-In-One InkJet...
Writing tip on pen will not come out when I twist the bottom
Pull up the top of the pen (with the clip). Remove the refill cartridge and examine it. If it is not damaged put it back in and fasten it in place by twisting. The cartridge comes with a colored plastic top. The cartridge must be inserted with the plastic on.That top must not be removed.
Nov 09, 2013 | Cross Century II Classic Ball-Point Pen
Do digital pens have other colors of ink or are they all the same?
You can buy replacement ink cartridges for your digital pens, but while you are writing you can only have one ink cartridge in the pen.
Sep 30, 2013 | Computers & Internet
My HP D1560 Deskjet Printer keeps blinking and computer says Cartridge Problems but I have refilled my ink cartridges like I have in the past---what do I do ? It won't let me print ? Ahhh Help
First of all understand what is cartridge the you can solve your problem your self in future if related same: The cartridge contains two parts 1. ink tank, 2. Pen(electronic nozzles controlled by mother board).. Ink tank contains ink & main source to pen to write,.. if ink is over you wont get any image.Ink is there but pen is not writing then no use..both conbination has work to gether to create image..As you said ink is there, but pen is not working due to ecetronic nozzles are faulty & this information with mother board, that's why its indicating that replace the cartrdige..And we can't repair it because of micro technology.
See fig: 1. Container, 2.Nozzles. 3. Electronic contacts to control nozzles..
Just replace the cartridge....
Feb 04, 2012 | HP D1560 Deskjet Printer InkJet
Pen won't write though plenty of ink
There are a couple reasons a pen refill won't start writing right away. The first thing to check is the tip--often there is a bit of glue or plastic over it in order to prevent leaking.
If that doesn't work, then try one (or both) of the following two methods:
1) Place the refill (but not the tip) in some warm water. Heat will allow the liquid in the gel pen to become thinner and flow more naturally.
2) Hook a rubber band around the middle of the pen, using tape to ensure safety, and wind the pen while holding the rubber band on either side of the pen. Make sure the cap is on the pen. When the rubber band is tight, when you pull straight out on the rubber band from both sides of the pen, it should spin very quickly. The centripetal force will cause the liquid in the pen (at least half of it) to move toward the tip.
Make sure you fasten the rubber band to the pen with tape or something similar; otherwise the pen may go flying off at someone nearby. Also, again, make sure the cap is on to prevent any ink spraying out--this is unlikely in a gel pen, but it could happen.
Jun 13, 2011 | Sanford UniBall Gel Impact Rt Retractable...
How do you refill the black HP 940 ink cartridges? Where is the hole?
While "Solution #1" is true for the older cartridges like the 96 and 57 (I have filled many), the 940 is completely different.
First of all you turn the cartridge upside down, cut the label in between the 940 and the colored rectangle. This simply allows you to pop the cover off (it will still be held by the back label).
Once open, you will see a stem with a silver ring on top, an oval black rubber plug, and the refill hole with a very small rubber ball plugging it. To refill the cartridge you must get this small rubber ball out. You can you a sewing needle or some other sharp object. Be careful not to damage the plug too much - you must put it back in and it can not have a hole throught it. You fill the cartridge through this "port" once the ball has been removed. Then you put the rubber ball back in - use a ball point pen to push it in so you do not damage it.
If you damage the ball, you can purchase more, but obviously you cannot use this cartridge while you are waiting to get a new ball.
May 24, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Can I refill the original ink cartridges on my HP Officejet Pro 7500 Series Regards Dontacho
Step 1) Put the cartridge on some paper towels in an area where you can tolerate a spill such as a sink. Be sure that you are wearing old clothes, since the first time you fill the cartridge, you will probably get some ink on your clothes and hands. You may wish to wear rubber gloves if you don't want to stain your hands. I also don't recommend refilling as a family project. Step 2) Look at the cartridge. Near the bottom of the cartridge you will see a horizontal break line in the plastic where the two parts of the cartridge snap together. Step 3) Using a sharp knife or scissor blade, cut the label on the front of the cartridge along the line where the two parts of the cartridge come together. Step 4) Using a knife,screwdriver, or just your hands pry the cartridge open along the line. Let it hang by the backside label. Step 5) The exit port is the point where the ink comes out of the cartridge. It has an obvious stem. Place this stem to your right. Step 6) You will also see a rubber oval-shaped bulb. To the left of this bulb is the fill hole. You will see a small ball in this hole. Stick a pin or the end of a sharp knife into this ball and pry or lift it out of the hole. (Saundra recommends a sharp steak knife. (*** Don't stab or cut yourself!***) Don't lose the ball! Step 7) Fill your syringe bottle with the appropriate ink. You'll need about 30 ml (1 full syringe bottle) for the regular cartridges, about 75 ml (2 1/2 syringe bottles) for the high capacity black cartridge. Step 8) Insert the needle 1/4 to 1/2 inch (5-10mm) into the fill hole. Be careful not to puncture the bag, especially if you have a sharp needle. Step 9) Inject the ink into the opening. Step 10) Tilt the bag so that the opening is at the top. This will let the air bubble up and out. Step 11) Using the syringe, suction about 1 ml (1/4 teaspoon) of ink and air frothy mixture out of the top of the bag. Step 12) Inspect the ball. If it has been damaged, you should use a new ball or the damage may cause a slight leak. (We have additional balls for sale.) Step 13) Replace the ball in the cartridge. Saundra says, "The tip of a retracted ball-point pen is ideal for this." Step 14) Turn the cartridge upside down (stem down) and gently squeeze to check for leaks.
If you see a leak there are three possible problems.
1. The bag inside the cartridge has bursted or is punctured. There is no fix for this: the cartridge is dead.
2. While refilling you allowed ink to escape and get on the white collar surrounding the exit port, bulb and fill hole. The ink has now leaked between the bag and the sides of the cartridge. Even though this is usually only a small amount of ink it will act like you poured an entire pint in there! The solution is to remove the bag. Please do this over the sink. As you are looking at the cartridge you will notice that the sides are long ovals. Hook your thumbs inside the ovals and pull as if though you are going to pull the cartridge apart. You will see two plastic tabs. Release one and then the other. Using the bulb frame as a gripping point, pull straight up and lift the bag. This will be messy. Rinse the outside of the bag and the inside of the cartridge shell. Try not to get water on the copper chip while you are working. Using an old towel or a paper towel, dry off the bag and dry out the inside of the cartridge.
3. You have not pushed the ball into the hole securely. Push it in again and wipe up the excess ink. Squeeze the cartridge to make sure you have it sealed tightly before putting it back in the printer.
If there are no leaks insert your cartridge into the printer and print.
The light on your printer warning you that the ink is low will remain ON. This is normal. Do not panic: just see if it prints
Apr 23, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
My Cross pen fell on the floor and won't work
was it a ball-point or ink pen tip???
if it is ball-pint. then all you have to do is get a refill cartridge from any of the office supply store or specialty shop.
if it is a fountain pen tip, then you have to send it back to cross for repair.
Feb 09, 2009 | Cross Pen Computers & Internet
141 people viewed this question
jasbo
jasbo
