Question about KitchenAid KSRB22FK Side by Side Refrigerator
KSRB22F Kitchenaid freezer not cold
KSRB22F Kitchenaid Sidebyside:
Freezer isn't cold anymore, all food is thawing. Air is blowing out top vent of freezer, but is only a little cooler than room temp. Too early to tell if fridge has gone out too, but it seems like it probably isn't as cold as it should be. Might be my immagination. On the back of the unit, I see that a fan near the floor on the freezer side is running. I unplugged it for a minute or two and thought it sounded good when I plugged it back in. It is now making periodic clicks.
Is there any thing for me to do? Switches to flip or buttons to push? I am not an electrician, but I am handy with a volt meter and whatnot.
  • kotefare Oct 04, 2009
    Thanks. It seems like it's getting colder since I unplugged/plugged it. But again, I don't have a thermometer that reads cold temps well, so it might be my imagination. It clicks every 10 minutes or so. It's currently making that "fridge" sound. At least it does until the click. Which is probably what you mean by the compressor overloading.
    Where do I get a new relay?
    How much will compressor repairs cost me if it is indeed the compressor? It's 7+ years old and I'm trying to decide if I should just invest in a new one.
  • kotefare Oct 05, 2009
    I was unable to find a relay locally so I ordered one of off ebay. Hope that fixes my problem. If not, it was $15 and a couple days down the drain. Along with all of my food. :( I did put bags of ice in the fridge/freezer to give us some extra time to use up what we could.
  • 4,059 Answers
The clicks, if coming from the back in the area of the compressor behind the cardboard backing, is probably the starter/overload relay. You can test it with an ohm meter. See how here> http://www.acmehowto.com/howto/appliance/freezer/check/compressorrelay2.php Part 15 here is your relay. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=KSRB22FGBL00&productCategoryId=0165000&brandId=0593&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00008&componentDescription=UNIT&documentId=O2027756&blt=06 If the relay is good the problem is with the compressor and will require a tech to replace which is not cheap.
Posted on Oct 06, 2009
    President:
  • 497 Answers
Sounds to me the clicking is the relay, which may be bad., I was have a pro come out and diagnose it and repalce it.,
Posted on Oct 04, 2009
  • Greg Mills Oct 04, 2009
    compressors can be pricy but cheaper than a new unit. It all comes down to whether or not you like your current unit. otherwise buy a new one.
  • 358 Answers
Most of the times the problem in Kitchenaid refrigerators when you heard a clicking sound it's the compressor trying to start and goes off on overload ,this could be , a bad compressor or a bad relay ,but 90% of the time is the relay that's bad .Try replacing the relay first (no more than $30) It is located on the side of the compressor behind the black plastic cover (the cover has a metal strip around and attached to the compressor) Once you take the cover off you'll see the relay (brown) and the thermal protector ,both are plugged in to the compressor.Pull the relay or both out (remember or write down where the wires go) and buy the same one and replace it, if still don't work ,the problem is with the compressor itself.
My freeser is working other side is not cooling the top vent getting air but not underneath
You need to thaw the ice which has clogged the passageway from the freezer to the refrigerator. To do this, you can turn off the whole unit for several hours and let everything thaw, or you can remove the panels and locate the vent(s). Melt the ice with a hair dryer, then reassemble the panels and restart the refrigerator. There is a small chance that the fan in the freezer has frozen up as well. When the refrigerator compressor runs, you should also hear a small fan in the freezer run. If not, you will need to do some investigating to find out why.
Apr 25, 2012 | KitchenAid Refrigerators
Not cool enough to freeze the food
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps.
Regards.
May 02, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer not freezing freezer compartment and cooler compartment not cold. frozen goods are all thawed. lights still operate when door opened
Fan Problems
One of the most common reasons for the freezer to start failing is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Other Causes
Hope this will solve the issue.
Have a good day! : )
Apr 21, 2011 | Kenmore Refrigerators
Freezer not freezing .. It's cold..
I hope this helps........
Take care.
Apr 12, 2011 | Northland Panel Ready Upright Built In...
Imperial commercial upright. Top shelf is icing and frezzing bottom is not freezing.
Good luck.
Apr 12, 2011 | Freezers
Freezer cold, fridge isnt. Vent issue. Please Help before thaw!
Is there any ice/snow whatsoever built-up on the rear panel of the freezer ????(very important to know this).
If so, you have a problem with the frost free part of your fridge,causing it to ice-up,
and blocking the air flow to the fridge section.
Repost, and we should be able to go from there.
Wigo.
Mar 04, 2010 | KitchenAid Refrigerators
Refrigerator not working but freezer is
You have two vents between the freezer and fridge. The one the cold air from the freezer comes through(blown by the fan) and the other vent is a return vent back to the freezer. On a side/side they're at the top and bottom. It sounds like the bottom one may be blocked by food or frosted closed by ice.
Aug 22, 2009 | Refrigerators
you may have defrost problem or check fan by compressor
Apr 04, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Kitchenaid KSRA25IL Freezer working Fine - Refrigerator not
many times when a unit has a defrost problem the coils freeze up and do not allow the fresh food side to cool properly...check for a build up of ice on the inside back wall of the freezer compartment. if there is a build up of ice, you have a defrost problem. Also, check to make sure the evaporator fan in the freezer is blowing the air into the fresh food side.
Dec 26, 2008 | KitchenAid KSRS25IL Side by Side...
KitchenAid KSRB22FK Side by Side Refrigerator Logo
96 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
