Question about Panasonic PT-D5500U Multimedia Projector
I have a Panasonic PT-D550U projector. We just
I have a Panasonic PT-D550U projector. We just moved it closer to the screen and in doing so, found that the only input that is working is the remote two in port. As part of the move, we had purchased two different adaptors to convert the signal so we could run it thru cata 6 cabling. One adaptor converts signal to BNC and the other converts to the remote two serial. We know the cabling and the adaptors work, as we hauled a different projector up to the site and everything works with that projector. Can anyone help?
Chuck Downing
First Baptist Church
Freeport, IL
chuck.downing@gmail.com
SOURCE: PT-LC50E LCD Projector
With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
I wish they could have stuck this in the operators manual.
Posted on May 27, 2008
SOURCE: panasonic pt l711u power will not stay on
That used to happen to my PT 711U until I put in a new air filter. After that, no problem.
Posted on Sep 20, 2008
SOURCE: Projector shutting down after 2 mins.
You need to send your projector to the Pasonic's repair center. The problem is the iris and should be replaced.
Posted on Nov 28, 2008
keithd2704
  • 56 Answers
SOURCE: Bluish image appearing on screens
It sounds like the projection lamp is beginning to show its age. How many hours of use does the unit have on the bulb? The bulb are typically rated for about 800-1600 hours of use before they go bad. The bluish image on the screen image is a typical tell-tale sign that the bulb is going to need replacing.
Most of your better projection units will have an internal time counter of the bulb life from the time the unit is first used or when a bulb is replaced. Check to see if your unit has this feature, if so it will show you on the screen display what is the total number of hours on the bulb and the estimated remaining hours of life.
Be aware that the replacement bulbs are NOT cheap and usually will cost you several hundred dollars, I have seen bulbs for professional projection units used for large convention/presentations have bulbs costing as much as $500.00 USD.
One other last thing to check is to clean the lens of the unit both inside and outside. To clean the inside, you will need to remove the bulb (be sure to wear a rubber glove as the oils from your skin will cause the lamp to blow, (causes a hot spot)). Then using a cleaning wipe, just as one used for cleaning microscopes or glasses, wipe the lenses. The discoloration might also being caused by dirt and oils on the lenses.
I hope this shed some light on your church's projection problem.
Posted on Sep 19, 2009
Testimonial: "I was hoping that it would not be a bulb issue. I do not know at this point how much age is on the bulbs, but I am going to check tomorrow. "
  • 3741 Answers
SOURCE: upgrade firmware of panasonic PT-AE700E projector
yes there is a cable available. you can get this cable from www.radioshack.com ------------ www.bestbuy.com -------- www.walmart.com ------ Note:-- Dont forget to mention your cameras brand and model number before buying this cable.because there many different types of cable available. This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Posted on Mar 18, 2010
How to do lamp reset on panasonic pt-lb50u projector.
To reset the lamp hours, turn on the projector. Then press Menu and use the Up/Down arrows to highlight Options. Press Enter then highlight Lamp Runtime. Press and hold Enter for 3+ seconds until the Lamp Runtime screen is displays. Press the Power button (any other button cancels the reset). When the Power button LED turns red, unplug the power cord to the projector. You can either use the remote or the controls on the projector. Reconnect the power cord after a few minutes.
The reset instructions are on page 62 of the user manual. The manual is available from Panasonic here: https://support.panasonic.co.nz/docstore/PT-LB50U%20Operating%20Instructions.pdf .
I hope this helps.
Jun 18, 2016 | Panasonic PT-LB50U Multimedia Projector
Tip
Panasonic TYLA1001 Lamp Reset Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66...
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Here are the steps to reset the Lamp Timer for your Panasonic Multimedia Projection HDTV:
  1. Plug your Television in.
  2. Press the POWER button on the TV or the remote control.
  3. Press and hold the VOL- button on the TV, while holding the 0 button on the remote control for at least 5 seconds.
  4. When the reset procedure is complete, a confirmation screen will appear.
  5. Release the buttons and the LAMP indicator will go out.
Download the TYLA1001 Replacement Lamp Installation Instruction guide here.
I hope that helps.
on Apr 11, 2010 | Panasonic TYLA1001 TYLA1001 Projector Lamp
Panasonic pt- ae3000e HDMI Inputs won't work
interface of the inputs is defective
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 17, 2014 | Panasonic PT-AE3000U LCD Projector
Panasonic PT-AX200U projector. input display flashes on and off.
It could be your source and not the projector. If it is a laptop then hit function four and change how it shares display. Over all I need more info as to how it is plugged in and what you are trying to view from.
Jan 08, 2013 | Panasonic PT-AX200U Projector
Panasonic PT LB50NTU - LCD projector need to connect to my IMAC - what cord do I need?
The Panasonic projector PT-LB50NTU or E have two type of data inputs.
One is RGB or VGA cable and second is VIDEO cable. If your IMAC have video or vga output than you can connect.
Two type of cables witch are using with projector good_help_0.jpggood_help_1.jpg
Jan 14, 2011 | Panasonic PT-LB50U Multimedia Projector
I have a Panasonic PT-AX200 LCD Projector. It is mounted on the ceiling. I need to know how to focus the screen without climbing up to the machine itself to do it. Is there a way to find the focu using the...
I'm afraid, no remote option available to focus image of this projector and has to do manually. Check projector Menu and select Test Pattern for optimum focus and it would be one time job if projector and screen distance has not been changed.
I'm not sure about the advice regarding "color management" as it has nothing to do with focus.
User manual link is also broken and take you no where.
Aug 11, 2010 | Panasonic PT-AX200 LCD Projector
My panasonic projector pt-ae3000u is not seeing my ps3
Should work right away, are selecting the correct HDMI input? (1,2 or 3?)
Do you have a way of checking the cable?
Jan 13, 2010 | Panasonic PT-AE3000U LCD Projector
Where can i find/purchase a remote control for Panasonic PT-L6510U
http://www.panasonic.com/business/projectors/ss_techsupport.asp
Go to Panasonics suportsite and white the a mail, the will inform you where you can buy it nearest you or if you can buy it from them.
Good luck
Dec 04, 2008 | Panasonic PT L6510U Multimedia Projector
Panasonic PT-L501U
Hi BEEZELLE
Does the VGA input work ?
If not then the Mainboard is at fault and will need either repair or replacement.
May 11, 2008 | Sony VPL PX31 Multimedia Projector
Panasonic PT-D5500U Multimedia Projector Logo
76 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
