Question about Palm LifeDrive Mobile Manager Handheld
Hello. My life drive is approx 3 years old. Today, for the first time, it went totally "dead", not even a soft reset would get it working. Back home, I put it in the cradle. Eventually (it took several long minutes) it came "back to life" and I even had a sync. However, when I took it off the cradle and tried to open a document it said something like "translation failed" and went dead again. Dead dead. Like before. I have it now in the cradle, it is "alive" again but I am afraid of doing anything. So it sits there. Anyone has any idea what should be my next step? I am not a technical guy, so please be patient. THANKS!
  • 1,606 Answers
That is your battery telling you it has had enough. Usually they last about 2 years. You can buy a replacement battery from about $15 and up. Usually these replacements have more capacity than the originals and so you get much longer usable run time.
You can send it in to get it replaced but it is a very simple job to do yourself. You just need a 5.5 torx screwdriver to take 4 screws out and open the case. Undo one connector remove the old battery and then put the cover back on and the screws back in. Carge overnight and you are up and running.
If you do a search on google or bing you will find dozens of places that sell the battery and/or will replace it for you.
If you look at this link it shows the battery and shows a video on how to replace the battery. Have a look at that and it should give you an idea if you feel comfortable to fix it yourself.
http://www.directfix.com/mm5/merchant.mvc?Screen=PROD&Product_Code=PA2030&Category_Code=LIFEDRIVE
Posted on Apr 13, 2010
The battery died in my 95 jeep grand cherokee laredo an now it wont hold a charge
If the battery is old(2 to 2/12 years) the battery is sulfated and worn out inside. Going dead is just the nail in the coffin. Plus, a discharged battery will freeze in cold weather, allowing the ice inside to bend and break the lead plates inside, causing shorts to occur and will drain the battery after charging. If it were me, I would bring the battery somewhere warm for 8 hours, slow charge it, then have it tested. If it's more than 2 1/2 years old, I would just replace it.
Jan 31, 2017 | Jeep Cars & Trucks
Where is the fuse for ge spacemaker jvm1320wb-002...the unit is totally dead...nothing works
It is time to replace the microwave oven, if the fuse is open you more than likely have a more serious problem that will be costly, companies only go back a few years when it comes to supply parts
Jun 16, 2012 | GE Microwave Ovens
Hello I've had my citizen Eco drive skyhawk watch for at least ten years now. I remember reading in my manual years ago that a battery needed to be replaced even though it's solar powered. My watch went...
There could be other issues beside the battery. My best solution would be to take back to where you bought the watch, or any other authorized Citizen watch retailer for repair.
This is Citizens web site:
http://www.citizenwatches.com.au/
Best regards,
Mar 16, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Two things....my approx.18 month old battery died and i bought a replacement yesterday. is this the normal life expectancy? 2nd. Today, with a totally charged battery, I took eight pictures. Later I...
To answer your questions, depending on how much use, (meaning how many snap shoots) will dictate whether your camera has reached its life expectancy. The proper procedure for long life with the battery is to have it totally drain out before charging it. If charged too soon the battery has a memory and will only work as long as the short period the battery was charged. It sounds like camera is worn out. Good Luck
Jan 07, 2011 | Kodak EasyShare M1033 Digital Camera
3 years old, totally dead dryer
remove the back panel look on the side of the heating element look for a small red button on the thermal fuse push it in.
Also look on the left side by the belt and motor you should see a black piece of plastic with small springs on it push it to the right to reset it if this has tripped,this is a saftey kill switch that gets activated by the drum belt if there if a sudden problem with the belt tension
Mar 15, 2010 | Bosch Nexxt 500 Dryer
Treo 650 freezing if idle for a few hrs
Maybe a button is getting stuck, or a component has stopped working.
Jan 01, 2010 | Palm Treo 650 Smartphone
Intermittent fuel problem with 1.9dCI Laguna
it sounds like a cracked diaphram on your fuel pump.have the pump checked.
Apr 06, 2017 | 2003 Renault Sportwagon
WILL NOT TURN ON
Possible solution.  So, my sansa express went dead after pluggin it in to my computer after a few weeks of use.  It was totally dead and unresponsive.  Didn't turn on at all.  Plugging it in wouldn't effect it and windows only recognized a malfunctioning usb adapter.  Thus, reprogramming the firmware was out of the question.
Solution: the soft reset actually worked.  You have to soft reset (hold down the grey center button and the volume up + key at the same time for a few seconds.)  Then plug it into the computer.  Voi La.  It came back to life.  The strange part was that it still wouldn't turn on after the soft reset.  It required me plugging it into my computer to revive the thing.
Dec 03, 2007 | SanDisk Sansa MP3 Player
Palm LifeDrive Mobile Manager Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
