Question about Microwave Ovens
KSRB22F Kitchenaid Sidebyside: Freezer isn't cold anymore, all food is thawing. Air is blowing out top vent of freezer, but is only a little cooler than room temp. Too early to tell if fridge has gone out too, but it seems like it probably isn't as cold as it should be. Might be my immagination. On the back of the unit, I see that a fan near the floor on the freezer side is running. I unplugged it for a minute or two and thought it sounded good when I plugged it back in. It is now making periodic clicks. Is there any thing for me to do? Switches to flip or buttons to push? I am not an electrician, but I am handy with a volt meter and whatnot.
  • kotefare Oct 04, 2009
    Thanks, but that doesn't really help me. That was pretty much the decision I had before coming here. By the way, I see I somehow posted this in the microwave section. There's no way for me to move it, right? I just opened a new one in refrigerators.
  • 521 Answers
Soounds like maybe the compressor has failed . Have a technician looka t it or just replace it with a new one**shrug**
Posted on Oct 04, 2009
Ge sidebyside freezes fresh food..replaced damper, thermostat,sensors...coils get frosty..now what
probably heating element in freezer is broken.
Remove power and defrost. Remove wall panels in back of freezer to Check heater element behind panels With ohm meter should read 20 ohms or less. You could remove it and bring it to a local repair shop and have them test it and if required order you a new one. If this does not work it may be the control board
Oct 14, 2013 | Microwave Ovens
Freezer has ice in it and the fridge isn't cooling
Hello Cass, being that you have a top mount, the vent in the freezer is what circulates air down to the Fresh Food section, making it cool. Here are a few simple troubleshooting tips that may help you resolve this issue:
First check clearances around your refrigerator. There must be adequate space around a refrigerator with a static condenser so that air can circulate properly. Proper clearances include 1" at the back and 3" on top of the refrigerator.
Examine your doors. If the doors have been opened too often or for too long, this may have allowed warm air to enter the refrigerator. Make sure to shut the door completely and be sure not to keep the door open for too long. Even leaving a door slightly open can allow too much warm air intake. Make sure refrigerator is level and keep food and containers from blocking the door closing.
Check the door seal. You do this by placing a dollar bill between the body of the refrigerator or freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet, double check to see if the door is being blocked by anything that may be stopping it from closing. If nothing is stopping the door from closing then replace the gasket.
Check to see if the condenser is dirty. A dirty condenser cannot release heat efficiently into the surrounding air. Cleaning the condenser may be necessary, more if you have animals in the house. If you have condenser coils, they should be wiped occasionally with a damp cloth to remove accumulated dust. The condenser coils should be wiped occasionally with a damp cloth to remove accumulated dust.
Check for any obstructions to the vent to ensure proper air flow. If the vent is blocked, the air in the refrigerator will not get cool.
I recommend to double check the freezer control. If the freezer control is set too warm, set freezer control to a colder setting and allow 24 hours for temperature to stabilize.
If these assessment measures prove to be ineffective, I would strongly suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair of your unit. You can often locate an experienced technician in your area by going to the manufacturer website.
Aug 18, 2013 | Electrolux Microwave Ovens
Frig or freeser not cold
If it is your freezer, check to make sure that the air vents inside the freezer are not blocked by food. Putting too much food in an blocking the air vents will prevent the freezer from freezing. Air needs to circulate inside the freezer for it to work properly. This can also cause excess freezer ice collecting on freezer or in foods. Dust and lint will collect under and behind a frig. Pull the frig out from the wall, unplug it. Check for lint under and on the back of it. If it has accumulated some, vacuum it all off and plug it back in and wait a while to see if it gets cold. The fan pulls lint and dust under the frig and it stops the cooling system. If this doesn't work, it may need the freon (can't spell it correctly) stuff replaced. If these don't work, you need to call
Feb 15, 2013 | Microwave Ovens
The freezer part is working fine ,it seems as tho the refrigerator part is warming instead of cooling
The freezer is actually where the cold originates and is passed through into the refridgerated area.
Open the fridge doors and check that the air passage is not blocked by something stored against it. It's probably on the top shelf and looks like a louvre vent. There may be another down by the crisper drawer
Aug 14, 2011 | Microwave Ovens
FRIDGE button is set on 3, red light flashes, air system works but it is not cool for at least 1 hour, Freezer set on 4 S and works.
Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section ( mostly on SxS refrigerators ). For many years the air damper was manually operated and now we have motorized controlled or temperature controlled or thermistor and electronic boards controlling air dampers, and if this device sticks closed the FF section will normally warm up. An example picture of "one" style and an air damper ( called a diffuser by Whirlpool ). Next would be to check the condenser tubing, a good place to start is to make sure the condenser coils are not built up with dust!! Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it. Then make sure all the vents are clear and not being blocked by food cartons. One new safety device added to refrigerators in the last few years has been a in-line fuse added to both sides of the defrost heater. If one of these fuses let's go, you must replace the whole defrost heater, as it comes as an assembly. If the defrost heater does not work, you should check for one of these fuses being open. Check it with a volt meter or ohm meter.
New link from Appliance Repair Aid on how the wiring circuit works for a frost free fridge, the link is here.
On a frost free refrigerator, the cooling coils should be in the freezer section. On a SxS style refrigerator the coils will be behind a cover on the back wall. On a freezer on top style the coils could be behind the back wall or under the freezer floor. Removing the cover and exposing the evaporator coils could be a valuable tool. Seeing what the cooling coils looks like may help split your not cooling problem. Totally covered coils with white snow is a frost free problem. and the rest are bare is an indication of a system problem
If you find this helpful, a vote with the thumbs up would be appreciated for the free advice
Jul 13, 2011 | Microwave Ovens
Freezer works but frig not cooling
if you were to reach your hand towards the rear inside the fridge area can you feel cold air blowing into the refrigerator side if not this could either be due to the fan inside the freezer area not working or there is a small door that is controled by a thermostat inside the ceiling of your refrigerator this thermostat when it reaches a tempreture that is to warm it opens a small door in the rear that connects to the freezer allowing cold air to come into the refrigerator side when the refrigerator becomes cold enough the thermostat then shuts the door. You could also have a defrost issue inside the freezer area in which u would need to remove the rear panel in the rear of the freezer in order to assure you did not have this issue. If you remove the rear panel and you see any ice build up on the evaporator coil (note this is also where the fan that blows the cold air into your refrigerator is located)you would have a defrost issue. If you remove that rear panel and find any ice build up message me back and il instruct how to fix but first check to assure you have air blowing into the refrigerator side. If you dont then you have to diagnose which is causing the issue either the fan which you could hear if you listened inside of the freezer area or the door itself is not opening due to a malfunction with the thermostat if you have any further questions message me back and please also remember when our chat has fully conlcuded to rank how this opinion has helped it allows me to continue helping others in similar situations Thanks
Rick
Jun 24, 2011 | Microwave Ovens
Freezer side of appliance is fine but the fridge side is warm
open your freezer and see if it's blowing cold air,or if it's just cold,if it's not blowing cold air it's probably the fan, u will find this right behind the vents in the freezer,remove vent in freezer there should be a fan if not running replace this should resolve your problem
Apr 03, 2011 | Whirlpool Microwave Ovens
I hope someone can help me. I have a Whirlpool Fridge Model Number WRN52HWG6 and we bought it from Fridge and Freezer City O'Connor Perth about 6 months ago and I don't have the owners manual for it...
If you turn the dial clockwise this will make it colder anticlock less cooler...Start by switching off for a few Hours leave door open to allow defrost...Turn the stat fully anticlockwise to almost off then put it to say 2 o clock position assumming that it will go from 12 to 10,this should allow food to remain cold without freezing.you are looking for about 3/8 Degrees c.....Buy a cheap thermometer this will help to keep you on the right track..Good luck
Mar 07, 2011 | Whirlpool Microwave Ovens
How do you defrost rfa52 polar white fridge freezer?
Switch off the power and place all the contents in a thick bage inside a large cardboard box, to keep it cold. Place a tray to catch the thawed ice in the apropriate place and wait.
When defrosted, wipe the surfaces down with an antibacterial liquid/spray of food grade quality and switch the power back on. Replace the frozen food, after checking the date codes, in the freezer
Jan 04, 2011 | Hotpoint Microwave Ovens
Microwave Ovens Logo
125 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
