Question about Asko W6021 Front Load Washer
I have no manual so Iam not sure how to get started.
  • 502 Answers
    Scholar:
  • 90 Answers
You can download the manual at this link:
http://laundry.manualsonline.com/manuals/mfg/asko/w6021_w6441_w6761.html
Posted on Oct 04, 2009
I need printable instructions on removing and
sorry iam in spain and have no access to this sort of information,but if you ask a local mechanic iam sure they will do it for you with no need of a manual
Nov 02, 2013 | 2004 Ford Taurus
Hi....KIA Sedona will only start if I take the large pipe off of the intercooler (the one toward the radiator) if I try to start it with the pipe on, the engine turns over but doesn't start? Any help...
Sounds like ablockage somewhere down the line but where and what i have no idea here sorry and without my head under the bonnet ? from afar iam useless i know but iam sure their is a dead mouse or something shutting off the air supply to the engine
Jan 31, 2013 | Cars & Trucks
Engine hunting
what a lovely car -if it was a manual ,i have a diesel manual one and its a flier ,as for this iam not sure so try reading the codes but if this is a gearbox related fault car then its the scrapyard as this car has no value in the UK but if stuck for spares look here in spain as no end of these cars running around and well appreciated here they are as well .This hunting when cold is the puzzle as it could be gearbox related whereby the gearbox computer is operating the engine RPM idle to stop creep but iam just not sure as i never see any autos of rover just manuals
May 08, 2012 | Cars & Trucks
A light appears on my dashboard with a car skidding. Now my Engine and ABS has started to flash. Don't if this has anything to do with it but my car wouldn't start one morning and i thought...
vauxhall or opel it doesnt matter if this is a astra or a zaffiro petrol then i would expect this but the diesel version iam not sure about but i would suspect the ECU for this as the petrol versions are prone to the ECU going wrong with a jump start but if you have siemans unit then this iam not sure about but ?? as havent had problems with diesels as YET mainly vehicles around 2002 onwards of the petrol type then yes lots of problems
Feb 27, 2012 | Vauxhall Astra Cars & Trucks
My 1994 Jeep Wrangler runs fine.....until it warms up. Then it loses power and starts to sputter. I have replaced plugs, wries, air and oil filters, cleaned distributer ....no improvement.
1994?? older vehicle and iam not sure here but i think your autochoke temperature sensor is not working and its staying on choke ,now where it is and what it looks like i cannot help you with iam afraid as i have never worked on one
Jun 14, 2011 | 1994 Jeep Wrangler
When i try tostart my 99 jeep cherokee limited with the 4.0 noting happens not evena click from the starter. i have had the starter tested along with the battery they all tested good.iam getting spark to...
There are 3 metal contacts on the front part of the starter, if you use 2 long screw drivers you can make contact to 2 of the contacts with one screw driver and use the second to connect the 3rd contact to the 1st screw driver (currently laid across 2 contacts) If the jeep starts it means that your alternator has gone bad and will not take over for the battery.
Before trying this be sure the key is in the ignition and it the run position.
Also be sure to use a screw driver with an insulated handle( do not use a bare piece of metal!!!!!!)
On another note if your dash lights are not coming on, you may have blown an interior fuse.
May 20, 2011 | 1999 Jeep Cherokee
What are the nubers for in an automatic gear shift
do you have a driving licence ?? wasnt you taught correctly ?? Do you drive a manual change or rather can you drive a manual gearbox car because i have heard of -------++--- but do you honestly mean to say you have no idea of the gearlock capability so when you have a load on the vehicle and your going down a long hill you change down to a lower gear so the engine acts as a brake and your brakes do not get hot --- iam absolutely flabergasted you were not taught this ,iam sure this question is a wind up
Dec 27, 2010 | 1999 Volvo S80
When trying to fax, iam getting a fast busy signal, this problem just strated
This could be related to the fax machine, but more than likely it's a phone line issue. Try sending a fax manually by using the fax machine's speaker or "on-hook", then manually dial the number. Listen carefully as the machine dials and make sure it's even dialing out. Do not hit start until you hear the other fax machine pick up. If the "fast" busy signal occurs before dialing is complete or right after, have your phone line checked.
Aug 29, 2009 | Office Equipment & Supplies
Asko W6021 Front Load Washer Logo
207 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
