Question about Sony BRAVIA KDL-46W3000 Television
My tv is bleeding...half of the screen is affected...usually it stays like that for about an hour but now it could stay like that for more than 5 hours...is that repairable? I'm really worried cause my warranty is expired..plz help
Did you try eplacing the power supply board
Posted on Oct 30, 2009
I have a Panasonic 46" flat screen plasma tv that will stay on for as long as you want, but when turned off, will not come back on for hours
If the set is a few years old you might want to look at the caps in the power supply--not unusual for them to be puffed up and hence cause issues like this.
May 26, 2012 | Panasonic TH-46PZ80B 46 in. Plasma TV
Vizio lcd flatpanel tv with dark background
If half screen is affected it will be either a board (LCD and Plasma have different names) but in those one board drives each side of the screen unit--worst case is the display panel itself which is fatal from a cost point of view.
May 25, 2012 | Vizio VT Televison & Video
Sound stays on, but no picture- goes black and stays that way.
This unit should still be under warranty and should be taken in for warranty service. Any attempt to access the interior will void the warranty. It is important that a complete description of the problem like you entered here be taken along when you bring the set in for service. This will insure that the servicer be able to reproduce the problem and resolve it.
From your description (and as a servicer), I would be looking for a component that is heat sensitive. These types of problems are fairly easy to locate and resolve.
Please take this in for warranty service and update this when you find out the details.
Thanks,
Dan
May 04, 2010 | JVC LT-26C31 26 in. LCD Television
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have an old tv, a small one, that works OK when you first turn it on, then after 5 or ten minutes the picture goes black. But, the picture will come on briefly if you lightly tap on the top of the TV (or...
Hi
There's a solder connection, probably on the CRT board that s going bad. It's an easy fix but if you're not trained to be working on CRT tvs I suggest finding someone who is. Good luck
Mar 05, 2010 | Zenith Televison & Video
TV set keeps turning off and back on for about a half hour
i would keep it. you will have to replace a few components on the power board but, its not very expensive to do so.
Mar 11, 2009 | Televison & Video
BLACK AND WHITE SCREEN AFTER AN HOUR
This is usually caused by the tuner which loses the chrominance part of the NTSC signal. Your did not say how you have it connected but it you try using a composite video input (yellow jack) and get the color OK than it must be the tuner which is not cheap but is worth having replaced.
Hope Ya Fix it!
Dec 28, 2007 | RCA 27V530T 27" TV
Sony BRAVIA KDL-46W3000 Television Logo
292 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
