Question about Topeak Babysitter Child Seat
Not sure how the straps should be fixed around the bike rack and to connect the straps that secure the child to the seat. I was hoping to find a manual - but any help is much appreciated
    Problem Solver:
Here is the website. they have the manual. i just downoaded it. hope this helps
http://www.topeak.com/Service_and_Tech/Downloads?product_id=247&category_id=41
Posted on Dec 28, 2009
We bought a used Burley d'lite bike trailer and want to know what all the straps are for. There is no manual with it. Can we get one?
If you have the flatbed they are for securing the load. If you have the child carrier they are either the straps that act as cusions or the ones for securing the child. The straps on the outside are for starpping accesories and structure.
Apr 19, 2011 | Burley D'Lite Trailer
Gentlemen: I have the Graber mountaineer-rak What do i do with the ends of the straps that hold the rack onto the car tie them back onto the rack? and What is the best way to secure the bicycle...
Wrap the shock cords (or bungee) around the bike frame and back onto the rack. Buy a pedal sock, and extra bungees also. Tie the extra ends to the rack itself so that they are not flapping around. A bicycle dealer will be glad to teach you all about it.
Apr 11, 2011 | Cycling
Maxi-cosi tobi strap tensioner not working. able to tighten straps when child is in seat but when buckle is pressed to release straps and get child out, unable to loosen straps tensioner will not let go.
Hi, Make sure that when you go to loosen the shoulder straps that the **** strap is pulled toward you, otherwise you cannot make the shoulder straps loosen, this is a safety feature. Hope this helps.
Jul 28, 2010 | Maxi-Cosi Baby Gear
How do the straps go for the saddlebags on a 2003 Buell Blast?
I have a 2007 Blast. It really depends on the make of the saddle bags but assuming they are generic soft bags, here is the usual procedure.
Remove the seat. The connecting center straps for the bags will go under the seat and are held in place by the seat itself. Laying the straps over the top of the seat will allow them to shift and/or blow completely off the bike.
Adjust the straps so that the bags are as close to the edge of the seat while still hanging at a verticle angle. Too loose they hang too low. Too tight and they will compress around the bodywork of the tail section and reduce the usable space inside the bag or possibly damage the contents you fill it with. Once the seat is put back on that is usually enough to keep the straps secured from sliding front or back but depending on the placement of the bag straps you could place a strap behind a d-ring peg to keep the bag from sliding down towards the front of the bike.
Usually you need to nothing more to secure the bags but depending on the bag itself there may be a strap you can anchor the bottom of each bag to the passenger peg or a strap that connects the two bags across the bottom of the bags. Just remember to NEVER anchor the bags to the swingarm. It may seem like a no brainer but you'd be surprised at how many people don't think that far ahead and do it anyway. LOL.
Jun 21, 2009 | 2003 Buell Blast
Fitting a child bike seat to frame
Usually you need a rear bicycle rack of which the baby carrier attaches to.
May 16, 2009 | Cycling
HARNESS FOR FRONT FACING EVENFLO TITAN CHILD RESTRAINT
there is another thread on this.
Basically, locate the ends of the straps on either side of the seat. You can remove the plastic end thingy and take the strap out. Then re-thread the strap. Remember to thread it through the thin grey strap (which adjusts the tension of the main shoulder straps) as well as the little metal guide at the back of the chair.
Your problem may also be that the length-adjuster (thinner grey strap) is too tight. You can loosen it by pressing on the button located just in front of the main buckle and pulling on the shoulder straps. This is also how you tighten the shoulder straps - by pulling on the thinner grey strap.
Generally, the shoulder straps should come out around the childs shoulder level. Higher is ok. Lower is bad because it doesn't secure him in.
Oct 29, 2008 | Baby Gear
3 month old instep...strap broke
instep.com ...provided
Free seat and strap after discussed the problem with it
Jun 30, 2008 | InSTEP Ride N' Stride MK750 Twin Seat...
Nania Nuevo 3-in 1
hi,
i just had the same problem but there seems nothing out there at all, so i had to try myself and just succeeded there.
so a little step by step guide, i hope its clear enough.
1. i found taking the whole thing apart to be the easiest way. so take it apart, you should have two long straps, two metal buckles, and two plastics things you will need at the end.
2. hang the strap with the shoulder pads around your neck, the way it would lie if around your child.
3. note two whole, one on either side of the seat, inside, near where your childs bum would be. imagine the other strap, the long one coming from there(imagine we are starting form the right here), then it goes through the right buckle.
4. next it goes through the right shoulder pad
5. now in real life it would go thorugh the back of the seat, but its easier to leave this last, in case you pull it through lopsided somewhere, so you can fix it, anyhow....
6. the long strap now goes around your neck and through the other , the left, shoulder pad,
7, then it goes through the left hand buckle
8. lastly, it WOULD go through the hole on the inside left of the seat.
before you do that thought, close the buckle and see if everything is straight
9. now pick one end of your work and pull it through one of the holes in the back of the seat, once its thorugh one hole it should go through a thinner grey strap at the back, this is for tightening the whole thing at the fornt once your child sits in the seat, once thats done pull it back out front through the other hole.
10. lastly, pull the long ends of the straps through the two inside holes either side of the seat, they should come out at the bottom, the two plastic green things are then attached to the ends. there is a right and a wrong way here, one way you can pull them in tight, the other you cant
i hope this works for you and i hope i made sense....
Antje
Mar 22, 2008 | Nania Nuevo 3-in1
Missing Instruction Manual
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Aug 02, 2007 | Evenflo Embrace
Topeak Babysitter Child Seat Logo
213 people viewed this question
Top Topeak Cycling Experts
Michial Gueffroy
dante
jimmarmor_ma
Are you a Topeak Cycling Expert? Answer questions, earn points and help others
