Question about Berkley Twist Lock Rod Rack
I can't get the light or the bell to stop flashig or ringing on the berkley pole tap.what do i do?
You MUST have the LED light facing down towards the reel when it is attached to the rod. If it is attached upside down with the LED facing up it will continue to flash or beep nonstop. The simple instructions for the Berkley poletap is -
1.Turn the unit to light or sound.
2.Cast your line,( it will blink or beep as you cast).
3. Set unit in rodholder or against chair,(Poletap will blink or beep about 12 seconds and then stop when still).
4. When a fish nibbles or strikes the poletap will alert with your setting of light or sound.
You may want to check out the new Berkley Poletap Pro, It has complete sensitivity settings for windy days and Tilt - angle for slow pull fish, high current and trolling mode.Awsome product!
Check it out at this Berkley site.
http://www.berkley-fishing.com/prod.php?k=299309&sk=299309&p=PURBAPPBA%20(11187809)
Posted on Oct 09, 2009
My car sounds like a bell!
I would suggest checking to see if you bent the exhaust when it hit the pole. The 1992 camaro has very little room for the exhaust system to run over the rear axle to start with it would not take much to make it hit under the car
Dec 05, 2013 | 1998 Volkswagen Jetta
Berkley poletap
Take a pet bottle of that size. Cut one side and put it around it and then make holes as requires and necessary
Jun 04, 2013 | Fishing
I have a belling 335 and both the oven and rear left hob ring have stopped working. what is likely to be the problem?
The thermal fuse inside rear is faulty. The grill also has it's own thermal fuse so make sure you change the correct one.
Sep 06, 2012 | Belling 335 Electric Kitchen Range
While driving a bell ringing happens when i make a right turn. sometimes the bell rings continually while i'm driving. what the problem?
Sounds silly but this is how i fixed my bell ringing. !st the ringing is the alarm when you open the door and the key is in the ignition or the car is running. I found the push switches that are on the side of the car and are operated when the door is shut have become loose. All you need to do is tighten them up a bit and the bell ringing will stop. When you make your right turn you probably push a bit on the door and that helps open the switch more. The switches are the contact switches that turn on the light as well as the warning sensors for open door. See if your dome lights flicker a bit as well.
Mar 05, 2010 | Hyundai Motor 2004 Sonata
Bell rings when I pull the key out and open the driver door
Replace the ignition switch or take to a dealer they may be able to repair the switch.
Oct 10, 2009 | 2006 Chevrolet Impala
The ignition bell wont stop ringing
You need to unplug the door harness one at a time to locate which door is causing the problem. Once the door is located, you can replace the switch which is located on the lock mechanism.
Sep 29, 2009 | 1994 Ford Ranger Supercab
How do u erect a lichfield challenger 5 tent ?
Peg out 2 back pegs of inner tent. Peg out 2 front then side pegs. Place smaller pointed pole through hole at bell end of inner tent from inside, longer pole through hole at front.Fit protective bases to each pole. Top pointed poles with separators. Assemble roof pole, put through loop and over separators. Throw outer tent over from bell end (needs 2 people) then carefully lead towards front til holes in roof match - back hole first. Fit rain hoods front and back. Peg outer tent from bell end first then back corners, front corners then sides. Place porch poles through holes at front of porch, zip door sides down with one person holding poles upright and taut and peg out door. Peg sides all along making sure they do not touch inner tent. Fix guy ropes.
Aug 06, 2009 | Sport & Outdoor - Others
Car started fine..stopped, no restart, no click, dead lights on.
try getting a boost for your car.... the battery may be failing. it doesn't take alot of power to turn on the lights... but a huge drain on the battery to start it. if it will not start with a boost i could very well be that the starter has failed. as you attempt to start it... have someone tap the starter with a hammer. if it starts... replace the starter.... if it starts normally with a boost you likely need a new battery
Mar 26, 2009 | 1988 Volvo 240
Car door bell won't stop ringing.
is there any type of check engine light on or any type of warning light is the sound of the bell the same bell sound when you open your door or seatbelt warning
Aug 28, 2008 | 1997 Plymouth Neon
Bell on ignition switch does not stop ringing on 1999 Dodge Caravan.
Locate it by sound & pull it out, and replace it. probably stuck relay inside it.
Aug 03, 2008 | 1999 Dodge Caravan
Berkley Twist Lock Rod Rack Logo
853 people viewed this question
Top Berkley Sport & Outdoor - Others Experts
Are you a Berkley Sport and Outdoor - Other Expert? Answer questions, earn points and help others
