Question about Sharper Image Ionic Breeze® Quadra® 4.0 Silent Air Purifier Air Purifier
Ionic Breeze Red cleaning light on after a few minutes of running
I have a Ionic Breeze S1637 unit. I cleaned the machine best I know how, I have no manual. Unit runs for a few minutes then the red light comes back on. Is there a reset switch or something special to do? Does anyone know where I can get a manual or some sort of operating instruction for this unit?
Many thanks in advance for any and all help!
  • 28 Answers
I have the same problem and haven't been able to fix it. However, others have had the same problem and have posted their solutions. The sizzling sound is caused by electrical arching between the plates and one or both of the two tungsten wires that are run parallel to the plates (if you turn off all the lights and wait for your eyes to adjust to the dark before turning on the Ionic Breeze, it's a pretty cool light show!) Here are things found by others to cause the arching and what they did to fix the problem:
  • --dirt, lint, or tiny hairs stuck somewhere (usually towards the top or bottom of the plates or wire, and maybe in the grid contact points). Clean it better. Using canned air can help blow out the problem.
  • --water droplets. Make certain there is no moisture anywhere when you put the grid (plates) back in. Using canned air can help dry hard to reach areas.
  • --burn marks or melted plastic. These indicates a short circuit. Says dnewcombe1: "There is a feeler bracket that guides the two rear thin wires while the cartridge is being inserted. This "feeler" can melt and become disarranged." You can't fix this issue.
  • --build up on the ionizing wires. Clean them. It's hard. I took mine apart and used steel wool.
There's a link to the manual here:
http://www.amazon.com/Sharper-Image-Breeze%C2%AE-Purifier-SI637BLK/dp/B0000AUTU3
Posted on Mar 09, 2010
Every time I turn on my Ionic Breeze the "needs cleaning" light comes on within a few minutes. I clean the grid but this keeps happening. What do I do now?
I have a ionicbreeze silent air purifier the "the cleaning light comes on within a few minutes . I have cleaned the grid but this keeps happening. What do I do?
Jan 27, 2010 | Sharper Image Ionic Breeze 3.0 Air...
MIDI Ionic Breeze quit working
Unit seems to need reset...To do this simply, with unit still plugged in, set to off by selecting on button until there are no high, med, or low lights on. unplug unit from wall for about 15 seconds then plug back into wall socket and select your favorite setting high, med. or low. The order in which you perform this task must be as stated above and the unit must be clean and the door and cleaning rod must be in home position. Hope this helps, mines working fine now but took a couple tries to find right order to reset.
Sep 16, 2009 | Sharper Image Professional Plus Ionic...
Ionic breeze quadra s1857 Red light continues to blink needs cleaning even after cleaning. not filtering. help
Mine is a Pro-series Quadra. It needed better cleaning.
The front and rear plastic grill scome off (release catch at the bottom of each), allowing access to the central core. I cleaned it with a damp rag (let it dry before you turn it back on). Be very careful of the two wires running the length of the unit -- if you break these it will not work. I did, however, gently clean them.
When I restarted it there was an unusual smell for a few minutes, but all is working well again.
Apr 13, 2009 | Sharper Image Ionic Breeze® Quadra® Air...
Ionice breeze quadra Model # S1637
had the same problem with ionic pro ca500. i took the unit apart and found a fuse that was blown and it works now. sorry but i don't know if there is any repair shops.
Aug 02, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Red Cleaning Light won't turn off
After cleaning the unit, replace the grid into the unit. Hold upside down for at least 30 seconds to reset.
Jul 19, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Where can I have a Ionic Breeze Quadra Model S1637 repaired?
Try this link, pair for $10- http://breezerepair.com/parts.html
Jul 16, 2008 | Sharper Image Ionic Breeze® Quadra® 4.0...
Ionic breeze Quadra S1637
What is a grid and what is a grill when referring to the Ionic Breeze Quadra?
Jun 26, 2008 | Air Purifiers
Ionic breeze quadra s 1837
I had a problem with my Ionic Breeze Quadra. Green light would only blink for a second then the red light stayed on. I cleaned unit very good but problem came right back. I blew out the breeze with an air compressor. Not much came out, but now I am green and back in action. I used about 75 psi to clean out.
Mar 23, 2008 | Sharper Image Ionic Breeze® Quadra® Air...
Sharper Image Ionic Breeze® Quadra® 4.0 Silent Air Purifier Air Purifier Logo
317 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
