Hi, my beosound 9000 6 cd player will not turn on. all other b&o items such as plasma tv and surround speakers all working, we had a power surge/cut-off yesterday is there a protection switch or device to reset. i looked at the manual on line and it states there is a mains power switch on the lower left side of the unit but i cannot locate this only the imput power plus on the rear lower left section. is there a way i can reset the cd player please it was working perfectly before the power surge yesterday or do i need to go into the remote and reset through pushing a series of buttons on the remote. thanks you kindly wayne klapko
  • 3,267 Answers
Each component, liek TV, Radio, CD player, CD Changer, etc operate on different voltages. When the power surge/cut off, you might hae been playing a music CD possibly, which means only that circuit was on. Since you are getting sound when using radio or TV, means the amplifier is also OK. This being a hardy set and can be used at any angle. Therefore the two things which could/should get any damage is the optical Laser unit and the CD Tray mechanism and/or the motor which spins the disc. There are fuses for each and are located in the control panel & since I can't predict the position/angle it was being used at I too cannot pinpoint which or both these circuits got affected. My recommendation is to find out same from any authorized service center technician for repairs. Only a trained tecnician will be able to find out which transisot, IC, resistor, etc, that has been affected by checking them out with the help of a multi-meter. However don't loose hope it could only be the inividual fuses or one particular component which is affected........................sodeep
Posted on Oct 04, 2009
Panasonic TV does not play through surround speakers
so it is a connections problem I think. Check if video and audio cables are properly connected. Use color codes as your guide. Also from menu check if all settings are ok. Good luck
Dec 01, 2013 | Panasonic DMP-BDT220 DMP-BDT220
How do I unlock B&O beosound 9000? Hi, have bought a beosound 9000 from a lovely gentleman who gave me a fake pin code and has since buggered off, not answered emails, or letters, or calls regarding...
You can only go to a b&o dealer to obtain a mastercode for the product, you can then change the pin code to one of your own.Proof of identity will be required along with the serial number and preffably the name and address of the original owner and where it was purchased.
Jan 10, 2011 | Bang and Olufsen Beosound 4000 Shelf...
Having problem linking my beo4 remote to my b&o beosound 9000. As soon as I connect other units to my 9000 like ny tv or ipod , i loose control of the remote operation right away
hi is your bs9000 connected to a b&o speaker? if not, ir wont work. b&o speaker wire or power link triggers the sensor once it is plugged to the bs9000. hope this help
Oct 11, 2010 | Audio Players & Recorders
Beosound 9000 scratching top cd
You have to look up in the manual which way the two arrows on the underside of the unit are pointing when the CD player is located on the far right. The arrows are screw heads which appear in two holes on the underside. If, for instance, you are playing the unit lying flat on a shelf or table top, if you flip it up and forward to get at the arrows, the two arrows should both be pointing left. If you are mounting it on a wall, it's a different arrow combination. I had the problem you describe and this fixed it for me.
May 21, 2010 | Bang and Olufsen Beocenter 9300 Shelf...
BeoSound 9000: Similar problem, AND no AM/FM/Aux either
sorry nothing straightforward springs to mind.A dealer repair seems the only solution.
Sep 16, 2009 | Bang and Olufsen Audio Players & Recorders
Connecting ouverture to penta 3 active loud speakers
what are the speaker connections for left and right out put on the Beosound ouverture tape cd player.   there are 2 x 8 pin din sockets on the back what are the pin numbers?
mick55kennedy@gmail.com
Apr 08, 2009 | Bang and Olufsen Beosound 2000 Shelf...
Setting up Surround SOund to LCD Television
All you have done is purchased the speakers for a surround system. So now you need a Surround Sound system.
The surround system, should have a power output no greater than 100 watts per channel. And be capable of connecting 6 ohm speakers.
The choice of unit will depend on price you can afford and the features you want. Check your TV to see if it has a Optical out socket. Or just HDMI sockets. If it has an optical socket, make certain that Surround unit has a couple of these. You will also need to purchase an optical lead, you can pick these up in cheap bargain shops. If you have a DVD or Blue Ray player, check them for the same. If one or more has co-axial sound output, make certain your amp or receiver has one. The more items you have connected to the receiver using optical out, the more sockets you will need. The more digital inputs on the unit the better it will be. The receiver should have at least Dolby Digital 5.1 settings and possibly DTS on it.
Mar 01, 2017 | JVC SXXSW6000 Speaker
Bang & Olufsen Beosound 9000 - CD does not play
gently open cd player clean laser with a cotton bud and wipe all round laser part and lugs at top and bottom of unit
Feb 15, 2009 | Audio Players & Recorders
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
