Question about Electrical Supplies
Have generators full schematics, want to upgrade socket just 10A
Manufacturer emailed me after phone call to tech support; they sent me the full schematics, service manual, and owners manual of a generator I'm looking at buying(used). They did this even after I told them that I wanted to make the 50A plug a true 50A plug instead of the labeled 40A they sold it as. It is a 2003 model genset if you look at northerntools site you can see a "modern version" BUT, it has a 50A breaker now... Item is a "Northstar" 8.5KW cont. 10KW surge 18HP B&S gas unit with a 50AMP 4 prog plus that only has a factory 40Amp breaker that *appears to be* inline for it as the "OEM sticker" on the plug that say's 120V/40A on the panel. HOWEVER, the first schematic shows that it doesn't appear to have a "40Amp" but has two 35Amp on each side of the plug's 4 prongs off the genset and then they are "Stepped down" for each successively smaller plug ins: 30A 220V; 30A/120V; 2 of the 20(or25)A 120 double plugins. The second schematic hints at(my assumption) the 4 prong plug is not actually breakered... I can offer up the pdf's *if necessary*. I just wish if there was a way to know if the size of wire from generator head to the breakers and then to the 4 prong "50A" plug is the right size to handle 50+amps without melting or IF it truly ius only able to handle"40A". AND if that's the case how can I findout the correct wire size? Then just get the genset and buy the wire and 50A breaker and upgrade the wires on the genset. After all it is truly OEM there is no **** electronics at all on this barely used unit. Too much info? sorry if so. Thanks in advance.
  • 1 more comment
  • electryc monk Oct 05, 2009
    Hey joecoolvette, I am no where near offened... :>) I will place my info/clarifiers after your comments...hope this is okay.
    Isn't too much info, and I appreciate your taking the time to list it.
    > (heavy sigh of appreciation) It is with all due
    > respect, that I feel no direct solution can be
    > offered to your query.
    > noted...
    The liability issue of someone posting how to change a manufacturers rated capacity, of an electrical generator's safety device/s, cannot/should not, be addressed by experts in this forum.
    You are asking how to exceed stated safety ratings, for breakers on a generator. The engineers that designed the generator, also took into account the rated safety load of the breakers.
    > exceed safety ratings? I'm not sure about this. I
    > hope i can give a link for the specific part:
    >http://www.northerntool.com/webapp/wcs/s...
    > if it get's edited out(sorry in advance) its at
    > northern tool's site and its under generators
    > /generator heads its like $800+ for this unit.
    > I don't believe its exceeding the safety standards
    > -correct me IF I'm wrong- but, from the techsupport
    > phonecall: The head unit's wiring/plugs is
    > supposedly the same setup as all the 18HP+ gensets.
    > So for a specific bit of tech data heres my art:
    >|------(35)----\ /-----(30)--\-------->
    >| \____/ . \
    | /---(30)-----/--->
    >|------(35)------------/
    (35 brkrs?) (4 prong) (1st 3 prong)
    It is my belief, that should you change any part of this system, you are liable for any occurrence thereafter.
    Good or bad.
    > of course common sense rules (ironic grin) "So does
    > Karma."
    Exceeding a 40 Amp load on a 220 volt line, and the safety device is too large, could be Very bad!
    > Part I. the crude text art above is trying to show the two pos. leads off each half of the windings are set with "35" breakers that each go to a prong of the NEMA L14-50R plug (which IS thee 50AMP plug I'm refering to as a a supposedly 40Amp plug on this one model. The wiring diagram then shows a jumper that continues again to the NEMA L5-30R plugs (one is a 120V the other is a 220V) then on to a pair of NEMA 5-20R 120V plugs.
    > Part II. IF I could then ask a theoretical question would that be more appropriate or is that just not a direction I could ask of this site?
    I hope I haven't offended you in any way, nor do I wish to incur your wrath. I truly wish I could help you in this endeavor, but I feel my hands are tied.
    > Again this has no wrath and is extremely appreciated! Honesty is a very valuable commodity(sp) on the 'NET. Don't loose it (thumbs up).
    -shade and sweetwater,
    steve
  • electryc monk Oct 07, 2009
    Oh shoot. I guess I forgot to clear up that little tidbit about toe 220V. Joecoolvette spoke on.... I DO NOT plan on using the NEMA14-50 plug (currently stickered @ 40A) for 220V. I ONLY want to use it for 120V/50A for our 5th wheel trailer. :>) seems with the second suggestion brought it up I must of mis-spoke in the initial posting? (sorry folks for any confusion this may produce)
    sincerely,
    steve
  • electryc monk Oct 10, 2009
    Avid101 ummm, I rooted around and came up dry with regard to finding your email info... do I offer up my email here like I saw someone else do in a posting(I googled and found some one did this) I'm just leary(sp) of doing something wrong by posting my email ID or the like... I am totally cool with sending you the stuff the manufacture sent me (their PDF's are 4 total(IIRC).
  • 5,660 Answers
It is with all due respect, that I feel no direct solution can be offered to your query.
Good or bad.
Posted on Oct 04, 2009
Testimonial: "honesty IS the best policy. Bummer I can't "Wax philosophical" with you outside this realm like a Mentor I have in the Subaru-forums (shruggs) :>)"
  • joecoolvette
    joecoolvette Oct 07, 2009
    I appreciate your kind comments, and value your opinions, although I feel they are overrated in reference to myself.
    I hope in the future if you have product questions, that you'll come back, and 'see us' at FixYa.
  • 3,600 Answers
The stated rating is covered by the manufactures 10% built in safety factor so even a 50 amp plug will work as the safety device will kick out if it goes over it's rated amperage by 10 %. Due to out put and the built in circuitry if you overload the 35 to 50 amp or the 40 amp to 50 amp it will not cause damage as the circuit breaker will kick off at it's rated amperage draw when at 100 percent plus 10 % of rated capacity it will not damage anything. so I don't see where your problem is but let me know if you need additional information on ohms and powers law to understand the problem.
Posted on Oct 06, 2009
Testimonial: "I still have the trusty physic's books from college... will try to refresh brain this weekend."
  • 2 more comments
  • Bruce Hathcock Oct 09, 2009
    If you don't mind and still want advise plese send me the PDF and I can help you some more. Basic thing is if you just replace the plug why not put in a inline braker at 40 amp and be done worring about it? if it's for a motor home the biggest pull is going to be the AC Unit. you can buy a slim line stab lock breaker box and run the wiers to the box and screw it on and have the wiers commin out of the box and hook the wires up using the two 40 amp breakes to the plug that way the 50 amp plug will be ok to use and gives you a better contact surface than 40 amp plug? Am I maiking any since?
  • Bruce Hathcock Oct 10, 2009
    send it here b123153h@yahoo.com I will carbon copy tothe company so I am covered.
  • Bruce Hathcock Oct 18, 2009
    I have found you a replacement Socket If you want it it's free but ya have to pay shipping. E-mail if ya want it.Give here the info and that we want you to recive it and she will tell me how to do it with her help, sorry so slow getting back to you.
    Avid101
    Avid101
A Vodacom upgrade contract that went horribly wrong?
SORRY BUT - You are on the wrong website for this type of inquiry. This is a community based self-help website for the repair and use of manufactured products made for consumer use...
Jul 10, 2017 | Cell Phones
I need a schematic for the fuses on a 2002 VW Beetle. can you help me?
1 - Heated washer nozzles, heated outside mirrors 10A
2 - Turn signal system 10A
3 - Illumination 5A
4 - License plate light 5A
5 - Comfort system 7.5A
6 - Central locking system 5A
7 - Back-up lights 10A
8 - Telephone system 5A
9 - ABS 5A
10 - Engine control, gasoline 10A
11 - Instrument cluster, shift lock 5A
12 - B+ (battery positive voltage) for DLC 7.5A
13 - Brake lights 10A
14 - Interior lights, with central locking 10A
- Interior lights, only 5A
15 - Instrument cluster, automatic transmission 5A
16 - A/C-clutch, electrical water pump 10A
17 - Door lock heater 7.5A
18 - Right headlight, high beam 10A
19 - Left headlight, high beam 10A
20 - Right headlight, low beam 15A
21 - Left headlight, low beam 15A
22 - Sidemarker lights, right 5A
23 - Sidemarker lights, left 5A
24 - Wiper system, washer pump 20A
25 - Fresh air blower, air conditioning 25A
26 - Rear window defogger 25A
27 - Daytime running lights 10A
28 - Fuel pump (FP) 15A
29 - Engine control, gasoline 15A
- Engine control, diesel 10A
30 - Sunroof 20A
31 - Automatic transmission 20A
32 - Engine control, injectors, gasoline 10A
- Engine control, injectors, diesel 15A
33 - Headlight washer system 20A
34 - Engine control 10A
35 - Trailer socket 30A
36 - Fog lights 15A
37 - Radio system 10A
38 - Luggage compartment light, central locking system 15A
39 - Emergency flasher system 15A
40 - Dual horn 20A
41 - Cigarette lighter, 12V power outlets 15A
42 - Radio system 25A
43 - Engine control 10A
44 - Heated seats 15A
Mar 18, 2017 | 2002 Volkswagen New Beetle
I have difficulty using my phone to get my emails. can some one help me out
There is one main reason why your experiencing this problem. 1. You need to configure POP3, SMTP IN outlook , express 2. Most email providers require that you have an upgraded account to allow email to be sent, recieved , forwarded to a third party for example, YAHOO requires a YAHOO PLUS account 3. Upgrading may allow you to send email directly from your desk top to include receive and send larger attachments such as photos, music, etc
Jan 21, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
My N73 always say memory full delete some data what is the solution for this?
Delete unused games/apps/ringtones from your phone or goto your local store and pick up a memory upgrade. You may need a tech to transfer your information over to the upgraded memory card :)
hope this helps
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
May 23, 2010 | Nokia N73 Cellular Phone
I have a blackberry storm its unlocked for tmobile....i was wondering how do i set up an email so i can get applications sent by mail to my phone...the cellphone ask for enterprise activation password and...
Hello
This unlock code provider generate full LEGAL unlock code direct from Blackberry server which wont void your warranty, & generate code based on your IMEI, means individual code for every blackberry set.
After unlocking from this provider's code your blackberry not only work with single network, you can use your Blackberry in any part of world with any network including your browser & MMS picture messaging to work, yes with just one time entering code from your keypad.
They unlock from network who locked your blackberry
This site will help you a lot & good email & 24/7 phone support
http://blackberryimeiunlockcodes.com
Apr 26, 2010 | RIM BlackBerry Storm 9530 Smartphone
Unable to save web settings
Delete all your previous settings and get new settings from your provider.......and u cant get full access memory of memory card it is allocated for mobile........if still problem there change to Airtel......which is the best 4 Internet access in mobile........
Nov 06, 2009 | Nokia 3110 Cellular Phone
I am looking for schematics to the mpr_m450. My
Hello slinger_101,
Even though schematics are not usually provided for car audio amps, the manufacturer would need to have them available to perform repairs. It's possible that they may send you a copy.
I'd try contacting Alpine USA direct and see if they would email a PDF. Here's the toll-free phone number: Audio Products Technical Support
(Alpine Electronics of America, Inc.)
(800) TECH-101 (1-800-832-4101)
If that does not work, you may have to send it to Alpine for repair.
Hope this helps.
May 04, 2009 | Alpine MRP-M450 Car Audio Amplifier
Iphone 2G stuck in headset mode= no sound
pls see the contact where the head set plugs in do u see rusty contacts otherwise u can change the headset socket or see it inside for rust for the schematics to dis assemble iphone 2 G see this video PLS RATE ME FIXYA for help
Video for Dis Assembly of IPHONE
http://www.youtube.com/watch?v=X1z0pw2VK7M&eurl=http%3A%2F%2Fwww.gethightech.com%2FMerchant2%2Fmerchant.mvc%3FScreen%3DPROD%26Product_Code%3DIP-2085%26Category_Code%3DIPHONE&feature=player_embedded
may be u need this part for ur IPHONE
http://www.bizrate.com/cell-phone-accessories/oid943283040.html
Apr 17, 2009 | Apple iPhone Smartphone
PT-40LC12 fuse problem
I went here for a tech manual for the Panasonic tv.
http://www.ManualsParadise.com
then ordered
Manufacturer: Panasonic
Part Description: FUSE
Part Number: LSJA0411-1
from PartStore.com
it was mounted to the case that holds the lamp. had to remove the back panel, etc. Also think I had to splice in the fuse or something. was a while ago.
mine is broken again. this is getting old between lamps and repairs.
Oct 24, 2007 | Panasonic PT-40LC12 40" Rear Projection...
PT-47WX49E - Looking for a schematic
GO TO THIS WEB SITE www.samsphotofact.com you will be able to find your schematic cost about $20.00 to $40.00,good luck greetings from belize
Mar 23, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Electrical Supplies Logo
547 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
