Question about Motorola Mobility MOTOROKR E6
Broken side key (lock key)
Bharuch
  • 51 Answers
Try service centre if not under warrenty then try installing a software called qeilock on your phone
Posted on Oct 09, 2009
    Scholar:
  • 90 Answers
If its under warranty..u are better off giving to the service center, they replace the entire front panel..the touchscreen digitizer,LCD and buttons as to them it comes as 1 part. If u arent covered in warranty u probably have the digitizer cable unhooked...check if u can open it and hook it back.
If everything fails, just replace the digitizer.
There are soooo many problems with this product, you would be well advised to cut your losses and invest in something that someone in American can fix.
Posted on Oct 04, 2009
    Sergeant:
    Champion:
  • 203 Answers
Hey, if its already broken, you have to replace that part, you can find one in motorola service center, or other cellpnone shop that accepting repairs.:)
My 2000 Ford Explorer drivers side door will not unlock with the key fob, the number strip on the door, or with the key in the key slot. All the other doors will unlock using the key fob. What is th
Not sure if lock has solenoid or electric motor, but either way, can you hear clicks or any prominent sounds from the door whilst trying to unlock it? you may need to put your ear on the door, if no sound, then wiring needs to be checked, then motor or solenoid, if you do hear similar sounds to the other door then the mechanical part of the lock mechanism has failed and may require a kit or replacement.
Sep 29, 2014 | 2000 Ford Explorer
Tip
How to remove a broken key from your car's ignition lock
take a small thin wire (like a paperclip) straighten it out and, put a 1/8" 90 degree bend in the end of the wire. Slide the wire into the keyway next to the side of the broken key; when you reach the pointed end of the broken key turn the paperclip 1/4 turn clockwise to grab the end of the broken key then: pull the wire out bringing the key with it.
on Jul 15, 2010 | Cadillac Fleetwood Cars & Trucks
Why wont my drivers side door unlock with the key?
If it works from the inside but not with the key, it could be a broken link between the lock cylinder and the door latch.
Jul 26, 2014 | 2003 Toyota Avalon
How can I find a duplicate key that has broken in half?It has a number on one side CH751 and looks similar to a Master Lock key.
The fastest and easiest method to get this resolved is to use a locksmith. If you contact the manufacturer, they might not respond in a reasonable time or at all. Call around and see what a locksmith charges and what they recommend. If you have the broken key they might be able to cut a new one for you from the broken pieces. They may also be able to come out and pick it and then change the lock for you.
Jun 22, 2014 | Sears Craftsman LiftMaster Chamberlain...
Key snapped off inisde upvc door lock key snapped at collar
ok here's a try at getting it out.
Sol1
Take two sewing needles and slide each one each side of the broken key. Go into the sides at an angle to 'nip' the broken piece and gently but firmly try to pull it out.
Sol2
If you have super glue and the remainder key section you can try to reglue the ends back together. this will only give you adhesion to remove the broken part out not a permanent fix. put glue on part you have and never too much as to seal the lock.
Sol3
Try tapping the reverse side of the lock with short sharp taps to encourage the stuck part to dislodge out, enough to get hair tweezers to pul out the stuck part.
Sol4
You need to remove screws from handles and faceplates and remove to revieal the lock. dismantle parts and keep them in removal logical order. so they can be replaced back in reverse order.
AndystUK
Aug 30, 2009 | Kwikset Locks & Locksmithing
My side lock is broken can it be rectified
i have a motorola roker E6 molibe phone .in this phone side lock key is broken by when i used key lock. now this time my phone is lock .what can i do . what is cost of repair my phone
Jul 15, 2009 | Motorola Mobility ROKR E6 Smartphone
Unable to open drivers side door with my key on a 2003 honda civi
Remove the doro finisher of your door.
Wirth a light, you should see a loose link rod between the key-lock and the door-lock. Just click it back in place.
If it is a zamac lock link, that's broken, you should replace the system
Apr 02, 2009 | 2003 Honda Civic
I have a 95 Toyota Celica, and my locks automatically lock and unlock when I turn my car on and off and take the key out of the ignition. But recently the passenger side door wont lock from the inside by...
You might want to take the door panel off and check the metal rods that connect on the inside of the door to make sure that one of the plastic inserts hasn't broken. If you find that it has broken there are several different ways to fix that. Some use black tape, some use an epoxy. I don't recommend the epoxy due the the fact that that metal rod turns inside the metal bracket that controls the lock.
Mar 03, 2009 | 1994 Toyota Celica
Door locks wont unlock or lock
The electric door actuators are bad/broken so they need to be replaced its a common problem
Dec 14, 2008 | 2005 Ford F-150
Motorola Mobility MOTOROKR E6 Logo
178 people viewed this question
Top Motorola Mobility Computers & Internet Experts
Motorola Mobility
Motorola Mobility
AJMAL KHAN
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
