Question about Actiontec (GT704WG) Router
Quickconnect is not connecting and it says that I can't connect and that I should contact qwest about it
  • 404 Answers
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Oct 04, 2009
I have DSL through Qwest and can connect to the internet, but the modem will drop internet connection then come back on then drop again. I will unplug the modem and restart it; it will connect then drop...
check the configuration of the modem if you can. I do not know the exact model of the modem, could you post it? then with the exact model of the modem you could google it for a Manual, Handbook, or simply good configurations. If the configurations are good, then could be the firmware that is not updated, or in the last case ask Qwest to change your modem for one that works.
A piece of advice don't open it or modify it because you could void the warranty, in case of a change.
Hope this help you!!!
Aug 20, 2010 | Actiontec (GT701) Modem
Kodak ESP 7 WIFI problems
The ACTIONTEC GT124, M1000 and PK5000 Routers are not compatible with wireless-enabled all-in-one printers. These routers cannot connect to your all-in-one printer because they do not support the multicast protocol. Contact your router supplier for additional assistance and to determine if your router will be able to support the muticast protocol in the future.
Feb 26, 2010 | Kodak ESP9 All-in-One w/USB Cable & 4x6...
Acer laptop not connecting to QWest PK5000
check your internet settings on the PC....
Jan 31, 2010 | Acer Aspire 5315 Notebook
Verifone 3730-trouble staying connected over Qwest TDM network
In the verifone file groups you have to delete *ZT and *ZRESP fields add *ZB Value is 1000 and *ZINIT Value to AT%C1\N3\V2.Let me know if you need help.
www.greenlightpayments.com x 105
Mar 25, 2009 | VeriFone Omni 3700
Belkin DI-604 router connection problem
Change the router's IP address to 192.168.10.1, The Qwest modem like Action Tech have the same IP address with the router.
To change the router's IP address you might needing to access the configuration page of the router, then proceed to the LAN settings.
Mar 24, 2009 | Belkin (F5D5231-4) Router
Telephone turn-on
Red and Green Wires. Often in the box there is a phone jack connection you can tie into without having to strip wires too.
Apr 25, 2008 | AT&T 1855 Phone
We recently got high speed internet from Qwest. It will not work. It keeps saying that the can't "ping" it. All light are green; power DSL, and the Ethernet. The internet is not. I have...
The DSL router/modem will receive an address from your ISP (Qwest) and will assign an address to the connected PC.
There should be a cable that goes from your DSL modem to your PC. It'll either be a USB cable (flat rectangular plug on the PC end), or a RJ45 (looks like a wider telephone plug).
If there is neither connection between the DSL modem and your PC, then the PC can't "talk" to the DSL modem, so it's not getting an address from the DSL modem.
Apr 06, 2008 | Computers & Internet
Actiontec (GT704WG) Router Logo
66 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
