Question about Homelite 'Yard Broom' Leaf Blower
Homelite yard broom starts a clicking noise then power loss. Power may come back for short bursts and clicking ceases during these times.
  • 8 Answers
Sounds like the piston rod assembly is failing and needs to be replaced.
Posted on Nov 30, 2012
I had this same problem with a Homelite leaf blower. To take Dolfoff's solution a step further I would like to add the following.
It was not the blower fan, but rather the flywheel which contains the magnet for the magneto which was loose. The flywheel has a cast in place key which is soft aluminum, this key was worn away completely on my unit.
I carefully re-installed the flywheel using Loctite® 660™ Quick Metal® Retaining Compound. Extreme care must be taken to assure that the flywheel is correctly oriented on the output shaft to establish correct ignition timing.
After reassembling, the blower runs fine now.
Posted on Nov 25, 2009
  • 148 Answers
Suspect the blower fan is loose on the crankshaft.
Open the housing on the fan side and check mounting nut. If this is the case, remove the nut, apply one or two drops of Loctite-Thread-Locker (in the blue package) to the crankshaft threads and reinstall the nut.
Hope this helps.
Posted on Oct 04, 2009
My homelite yard broom is hard to start and stay running
check the scrren inside the carb to see if it is ditry or needs replacing.
Jul 16, 2012 | Homelite 'Yard Broom' Leaf Blower
I have a brand new yard broom 2 (homelite) and it fires but won't start as though the timing is off. Could this be the issue? It hits now and then but will not run.
there is no timing on a single cylinder engine. it could be old gas, try spraying new gas into air intake until it runs on it's own
Apr 15, 2010 | Homelite 'Yard Broom' Leaf Blower
I have a homelite yardvark blower and I want to change the fuel filter. How do I change the fuel filter? Yardvark runs fine at beginning, but begins to run eradicatly after a short time. What's the...
could be fuel lines, fuel filter, or your carburetor needs to be rebuilt. The carb has thin rubber diaphragms that get hard over time, hot weather, or stale gas. Need more assistance,
email desertairrepair@aol.com.
Jan 31, 2010 | Homelite 'Yard Broom' Leaf Blower
Homelite gas leaf blower losing power
There might be a small screen in the exhaust (it's a spark arrestor) that gets plugged with carbon. Will cause loss of power and eventually the machine will not run. You can just take the screen out and it will run better. Check the exhaust ports (look into the cylinder area after you take off the muffler) and see if it/they are plugged. If so, use only plastic or wooden items to clear the carbon out. Be careful not to get any in the cylinder. If you do, pull the starter rope several times to blow out the carbon.
Otherwise, some fuel line cleaner would be a good try to assist in the problem.
Dec 28, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite 2 yard broom 170
You have found the HI and LOW settings. The idle wouls be set by starting and warming the unit up. After warm up, take your screwdriver and turn the LOW screw OUT until the engine starts to lose RPM's. Turn the screw IN until it starts to lose RPM's. Once you have those two points, back the screw about halfway between. You can do the same for the HI setting if you need to. Good luck...Lee
Aug 23, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite back pack leaf blower
Close both the high and low speed air screws (clockwise). Reopen each 1 1/2 turns
Mar 20, 2009 | Homelite 'Yard Broom' Leaf Blower
Leaf blower
One suggestion, unscrew the spark plug and reconnect the high voltage wire. In a very dark area move the plug so that the plug thread touches some metal on the engine. Pull the starter cord. If you don't see a spark, remove the two screws on the handle and see if two wires are attached to the Stop Engine Switch. Remove one wire and bend it away from metal and try to see spark when pulling the start cord. If spark occurs, the Switch is shorted and needs replacing.
Oct 31, 2008 | Homelite 'Yard Broom' Leaf Blower
Homelite yard broom
I have lost my book on the homelite yard broom. can you tell me the ratio of gas and oil?
Aug 31, 2008 | Garden
Homelite 'Yard Broom' Leaf Blower Logo
237 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
