Question about Sony BRAVIA KDL-40V3000 Television
Cannot get the TV to Power On
I just took my new Bravia out of the box, and when trying to turn it on for the first time it will not come on. The green power light comes on for about 1 second and then the red standby light flashes repeatedly. I tried plugging and replugging but that does not help. Any thoughts?
  • 1 more comment
  • kawasaki Mar 05, 2008
    the stand by flashes 13 times
  • TERESAIJONES Mar 02, 2009
    SETUP MY NEW BRAVIA AND WHEN I TURNED IT ON IT TURNED RIGHT BACK OFF 3X. NOW IT WILL NOT POWER ON AT ALL
  • Carl Manaloto
    Carl Manaloto May 11, 2010
    First, when you say flashes repeatedly, are you sure? Count the blinks and see if it stops in intervals. Those number of blinks is an error code for the service technician.
    C-Dog
Check power bord fuice power bu
Posted on Mar 23, 2008
Sony bravia klv40v300a lcd tv 6 time led bilink.what is the problem
It sound like it took a power surge. suggest you either have it serviced or replaced the tv itself. Frankly if it is not under warrenty then it is time to purchase a brand new tv.
Feb 20, 2015 | Sony KLV-40V300A Multi-System BRAVIA LCD...
Hello,my Sony Bravia HD TV (LED & LCD) we suspect that it was struck by lightning,but my other appliances connected on the same power cord as my tv are working fine,so i'm confused..
The power surge from lightening can come in thru the antenna or cable box. Also just the proximity of lightening can damage one item and not another. An ic chip can be destroyed from the charge in the air.Likely took out power and main brd both.
Mar 19, 2014 | Sony "KLV-40BX400 40"" 1080p Multi-System...
TV does not turn on
hello,
Ensure that the TV plug connected firmly to the mains power supply, if nothing happens,
It is require of you to open the cover of the TV to check for blown fuses, if found, do replace with a new one of the same current rating.
if otherwise your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power suppply board just have dead leakages gases capacitors.These capacitors alway bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole rerfurbish power supply board for the replacement.
May 31, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
52'' Sony Bravia will not turn on
Its fixable problem like power supply board replacement will solve the problem.
Unplug tv from wall socket for couple of minutes, replug back in and turn it On.
If problem still exist then most likely power supply got fired and will be replaced, local tv repair shop will help you to replace power supply board.
Thanks.
May 02, 2010 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
Sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Oct 07, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony Bravia KDL-46Z4100 Standby light flashing 13 times
This sounds like a power source problem! (faulty transformer) I would pack it up and take it back for a new one!
This is a problem you can not fix yourself unless your a pro!
Please rate my response!
Jan 15, 2009 | Sony BRAVIA KDL-40V3000 Television
Closed Caption on Sony Bravia
Try a master reset on the TV. With the TV powered on, prss and hold down the up button on the remote (there are 4 buttons grouped together for up down left and right) and while holding down the up button, press the power button on the TV. The unit should power off and then turn back on and ask you to select a language. Let me know if this helps and be sure to rate this solution. Thanks!
Nov 11, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Oct 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony Bravia LCD TV is tripping the fuse in the house
These things draw a huge surge current when turned on. What size fuse are you blowing? These things can surge 10-12 amps on turn-on. What about a fuse with a reset button. They will take alittle more surge before they go. Don't matter about the insignia working before because the cheaper sets tend to stay powered up more when off....thus not surging on from a dead start. Could you try a different plug on a different circuit/fuse? and see if that makes a difference. If you have a 15 amp fuse, then your pretty close with other stuff plugged in. What size is your service? Do you still have an original 60 amp box with screw in fuses? Is it an old house?
Sep 08, 2008 | Sony Bravia KDL-40S4100 40 in. LCD TV
Remote Codes for new Sony Bravia
I plugged this code in and it worked:
10000
Good Luck
May 12, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony BRAVIA KDL-40V3000 Television Logo
277 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
