Question about Bernina Artista 180
Bottom thread on sewing is looping - Bernina Artista 180
    Problem Solver:
  • 5 Answers
When I was taking sewing classes, this would happen every now and then to one of the class members, including me. My teacher told me that the looping on the bottom thread is generally caused by the machine being incorrectly threaded on top, which therefore wont let the bottom thread go into the stitch properly and causing it to loop.
We were told to basically follow these suggestions in order to reduce chances of this recurring & to date, I still refer back to it when I forget myself, especially if I have been off my machine for a few weeks.
1) Machine should be clean and free of lint within machine and in and around bobbin casing.
2) Correct and sharp needles correctly inserted.
3) Threads will generally feed better from the vertical position so a vertical thread stand/ attachment is recommended.
4) Before beginning to thread the machine, check that the pressure foot is in the up position, the feed dogs are engaged, the thread take up lever is in the uppermost position.
5) As you begin to thread ensure that the thread is fully engaged into the tension disks.
6)Once machine is threaded and both threads are visible (i.e the lower thread has been brought up from the bottom), slowly sew a few test stitches on a scrap piece of the fabric you intend to sew, to ensure your tension is correct. This saves time as you havent sewn a length of fabric only to find all of the bottom thread looped (experienced in that one!!)
7) If all this fails, it could be a timing issue of when your needle thread is contacting with the bobbin thread, which only a service person can fix for you, sorry.
Hope this helps you, or someone out there.
Posted on Oct 04, 2009
SOURCE: Thread looping onto itself
when i try to pick up the bobbin thread it does not pick it up at all i even try threading it all back over many times can yuo help me please
Posted on Oct 06, 2008
  • 69 Answers
SOURCE: Singer Touch & Sew won't loop bobbin thread
I believe you have a broken gear. These are difficult to repair on your own.
Posted on Feb 12, 2009
louislevel_2
  • 374 Answers
SOURCE: Thread loops
Proper set of bobbins and tension set up vs. fabrics will sew you satified.Also incude regular maintenance cleaning of the feeds dogs with a brus,also the shuttle assembly need sometime to clean.Some threads and fabrics chips accumulates in the feed dogs and shuttles assembly.In setting up thread bobbins the thread should be clockwise direction as you pull out on slot coming out to the bobbins (as you shown in my inserted image manual).The loop thread should be propely in the sequence position same like in the image refer to it.If you use cotton/ polyester fabric in the begining of trial set tension dial to No.3 and stich to No. 8 to 12 any convenient to you Use needle No. 14 .Posible make a record if you are sewing different types of fabric mostly silk fabric is hard to sew adjusting to lower stich can posible sew satisfactory.
Posted on Mar 10, 2009
Mimito7
  • 128 Answers
SOURCE: Top thread stitches correctly but bottom thread loops.
FYI---- Loops on the bottom-- problem is in the threading..
Loops on the top--- problem is with the bobbin.
Posted on Apr 19, 2009
sew dutch
  • 24 Answers
SOURCE: Thread looping on the bottom
Thread looping on the bottom means you have a problem with the top thread. In your case there is no tension on your top thread. Take all the thread out of the top and start threading over. Make sure you follow the correct path and make sure the thread goes through the tension discs. Then at the time of sewing, make sure your foot is down (this closes the tension discs and gives the thread the tension.) You may have worked on the tension setting while not realizing the thread was not in between theses discs, so also make sure the top tension disc setting is in the average before sewing.
Good luck.
(If you see loops on top, it means you have a problem with the bottom thread)
Posted on May 25, 2009
When I finish to sew the end of string does not lacks it self and when you pull the bottom of the string everything opens
If the upper thread is looping on the bottom of the fabric as you sew, the upper tension is too loose. It could be threaded incorrectly, the upper thread may not be seated in the tension disk properly (be sure to RAISE the presser foot BEFORE threading the upper thread), or the upper thread tension is set too loose.
If you have checked everything and it is still looping underneath, the bobbin tension may be too loose or the bobbincase needs replacement.
Sewing Machine Thread Bunching Up Here Why
Oh You Crafty Gal Sewing Lesson 10 How to Fix Tension on Your Sewing...
Understanding Thread Tension Threads
Dec 20, 2015 | Janome Sewing Machines
The thread for the top needle just sews and loops onto the lower thread
I think you are saying that there is a loop showing on the bottom of the lower thread stitch. If the lower stitch looks correct and not bunching, you will need to change the tension on the upper stitch. Make sure that your threads are firmly inserted within the discs also before adjusting the tension. It doesn't take much to change the tension so take it slowly.
Dec 31, 2013 | Sewing Machines
Singer 301a...sews on top of fabric nicely...bottom is just loose loops of thread...it's like the bobbin is not sewing...I put 2 different colors in to see...top is perfect...on bottom of fabric I see the...
This is a tension adjustment problem. It's good to use two different colors of thread, like you did. From your description, the top thread (needle thread) tension needs to be tighter. As you tighten the tension of the top thread, you'll see that the top thread pulls the bobbin thread up into the fabric so it's no longer laying loose on the bottom of the fabric.
You'll need to have the pressure foot down when you tighten the tension. Tighten it a little, sew a practice seam, check to see what the stitch looks like. Tighten it a little more, sew, check, etc etc--until both top and bottom look the same--you shouldn't see much (if any) of the bobbin thread color on top of the fabric or the top thread color on the underside.
Let me know how this works for you, ok?
Robbie
Jan 25, 2010 | Singer Sewing Machines
Thread loopy on top
General rule of thumb::
loops on the bottom, problem on the top.
loops on the top, problem on the bottom.
It sounds like your bobbin thread is not thru the little tensioner in the bobbin compartment.
May 28, 2009 | Brother LS-2125 Mechanical Sewing Machine
Good luck.
May 25, 2009 | PfaFF Tiptronic 2040
Loose bottom stitch on brother se 350
Hi, general rule of thumb:: loops on the top, problem on the bottom.. Loops on the bottom, problem is on the top.. When threading your machine, stop just before you thread your needle, put the presser foot down. Try pulling the thread. If it pulls easily, the thread is not thru the tension wheel right. If it pulls hard, you got it right.
May 12, 2009 | Brother XL-5700 Mechanical Sewing Machine
Bottom thread is looping.
If the thread is looping on the bottom, then your problem is on the top. Pull the thread out of the needle and and put the presser foot down. If the thread pulls thru easily, then you need to rethread your machine making sure the thread is thru the top tension wheel correctly.
Rule of thumb::
Loops on the bottom, Problem on the top
Loops on the top, problem on the bottom.
Apr 26, 2009 | Brother SE-270D Computerized Sewing...
No tension on my Singer 6212C sewing machine
Take the thread completly off the machine and rethread it making sure it goes thru the tension wheel properly.
FYI Loops on the bottom-- Problem is in the threadding.. Loops on the top, problem is with the bobbin.
Apr 10, 2009 | Singer Sewing Machines
Bottom thread is very very loose during stitching, looped up
Looping on bottom:
Great description, that helps a lot. Big loops are actually easier to solve usually. 1st know this: Loops on bottom means the top is too loose or the bottom is too tight. With loops that big its probably the top is too loose. 1st look in tension disks, there is likely a chunk of thread in there. A toothpick is handy to dig it out (the flat kind) 2nd make sure that the thread is getting between the disks when threaded. 3rd Make sure the thread is in the take up lever (the thing that moves up and down in front and not the needle bar or any part of the needle bar.) If neither, then the bobbin case could have a burr on it and the thread is hanging on that burr. Also the bobbin case may be in wrong. I hope this helps
Kent581
Mar 03, 2009 | Husqvarna Viking 1
Sewing Machines Logo
320 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
