Question about LG WM2688HWM TROMM SteamWasher
Water doesn't drain from liquid detergent tray.
  • 50 Answers
There must be some dust stuck in the drain provision clean it properly.
Posted on Oct 04, 2009
Liquid detergent doesn't dispense
There is a valve that releases water into the detergent tray when the washer is started. The water hose for that may be cracked, loose or the valve for that might not be working.
Mar 02, 2014 | GE WPGT9360EWW White Profile Harmony 4.0...
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Bosch Axxis WFL2060 stopped working on a wash cycle. The first time I used liquid HE detergent. I am sure I put too much in and the interior foamed up, the detergent tray foamed up and came out underneath...
water in base after overfoaming has leak detection if you can tip machine back this water will run onto floor allowing unit to rest, make sure you put down some rags towel etc to trap water there will be up to a pint of water.
Jan 29, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Clothes stink on top load model
Continually washing with cold water and liquid detergent can cause a buildup of undissolved detergent between the inner and outer tubs (unseen). This buildup of detergent feels like grease and will pick up dirt from each load and hold it on the grease surface. Over time...the dirt held in the greasy detergent can give off an odor.
This problem may be able to be cleared up by running many loads of hot water (to dissolve the detergent) with no clothes or detergent. Switching to powder detergent will also keep the liquid detergent gel from forming. If you like liquid I recommend using hot water for ALL your white loads. This should make every third or fourth load hot and help dissolve buildup from previous loads.
If you are not in the habit of using cold water and liquid detergent consider other sources of the odor. Some typical examples are sewer or septic backup through the drain and into the machine between the tubs where you can't see it. Also, the laundry is usually in the basement if you have one. The basement is the lowest part of the house drainage system and if you are developing a slow drain you may find some dirty water backing into the machine if it can't go down the drain quickly enough. Usually these drainage issues show up as a floor leak when you drain the washer in the spin cycles...but not always.
Good Luck.
Sep 17, 2009 | Kenmore Washing Machines
Detergent dispenser tray not draining water after cycles
I have the same problem and sometimes water stays in the detergent tray as well. I don't have a solution other than to remove the whole tray and drain in the sink after each cycle.
Sep 09, 2009 | LG Washing Machines
Water remains in the liquid detergent cup
This is by design. Water flows in and forces the detergent out. There will almost always be a little water left in the cup after a wash routine.
Jun 15, 2009 | LG WM2487H Front Load Washer
Water is pouring out of deteregent tray on fill up
inside the washing machine there drain from the detergent tray to the washer, it is plugged by a piece of clothing. remove the clothing and all should be fine.
Jan 01, 2009 | Kenmore 43142 Front Load Washer
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
134 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
