Question about Sport & Outdoor - Others
Suzuki quadmaster 500 4*4 atv 2000 info please
When i press the gas on the atv it will seam to be in nutural till you get more rpms....Im not sure if it is belt diven or transmition ???????
thanks aTON
I had the same problem and all i did was remove the primary and secondary clutchs clean them with mag wheel cleaner and installed a new belt works good now.
Posted on Jul 10, 2010
    Problem Solver:
  • 8 Answers
If this is a automatic bike like mine the clutch will not be in oil...It will be like a skidoo clutch system....
Posted on Jan 29, 2010
  • 4 Answers
Hello, the 1st option, you will need to open up the oil plug, if it smells burnt you will need to replace the clutch fibers and steel plates at one time. When these clutch plates wear they will slip at low RPM or cold oil temperatures.
Posted on Oct 06, 2009
    Problem Solver:
  • 5 Answers
Did you add any oil to the engine? if you did and it was not specially formulated for an atv with a wet cluch system it will cause a problem with the clutch grabbing the flywheel. most atv's and bikes have wet clutches now,which share the engine oil with the transmission, not like the older harley's. if this is the case I am not sure what to do to fix it but I would start with changing the oil to one for a wet clutch system for an atv.
good luck
~John
Posted on Oct 04, 2009
Suzuki vinson swing arm bearing replacement how do I do it and do I need special tools
Hey Steve, This isn't hard,,, please get a factory service manual.. spend a little $$ and save yourself MANY HEADACHES!! The manual will give you all the info yo need to do the job right.. you will probably need a press to remove and install the new bearings.
Jan 22, 2017 | Suzuki 2005 Vinson Automatic 500 4X4
The digital display on my 2005 suzuki vinson 500 is flashing in and out
Sounds to me like a battery and/or charging issue. But could be a loose connection somewhere too.
Aug 16, 2016 | Suzuki 2005 Vinson Automatic 500 4X4...
Is a 2000 Suzuki LTF250 quad runner Ina 4 stroke or 2 stroke
Joe, 2000 Suzuki LTF 250 is 4 stroke. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2001 ltf250 oil change
Suzuki LTF250 Quadrunner 4x4 Oil Filter Replacement Oil Filters
2000 Suzuki Quadrunner F250 ATVs
Jul 10, 2016 | Suzuki Motorcycles
Starts and idles fine runs half throttle when fuel is applied
Harry, dirty carb or injectors.
Check the attached links,Manuals and guides, Good luck with your Bike
ATV TROUBLESHOOTING AND MAINTENANCE
ATV Service and Repair Manuals
http://www.carlsalter.com/motorcycle-manuals.asp
Jan 06, 2016 | ATVs
How to tell what year my suzuki quadmaster 50 is
LT50's are from 1984-87
LTA50's from 2002-05
May 12, 2015 | ATVs
Adjust clutch on suzuki 500 quadmast
you should adjust the clutch with eliment squro /// bult and turn on the bike and press the clutch and 1 gear then 2 gear 3 gear all gears are shifting your clutch is redy enjoy the ride
Dec 29, 2012 | Motorcycles
Suzuki Escudo Jeep High Rpm
I am not familiar with Suzuki's but the first thing to check is that the throttle or throttle cable or throttle peddle are not sticking. With the engine off, ask a friend to press and release the throttle peddle while you look at the throttle to see if it moves. If it doesn't then you need to check each item to see which one is sticking.
Jul 12, 2012 | 1991 Suzuki Sidekick
Sport & Outdoor - Others Logo
1,294 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
