Question about Kenmore 22422 Top Load Washer
Hot water reduced to a trickle. Warm is only lukewarm. Tried disconnecting the hot side hose, but there was no screen to clog. Mark
  • 1,165 Answers
Heater elements have worn out heater is probally full of rust debree
Posted on Oct 04, 2009
Only fills with cold water...when switch is switched to hot or warm it doesnt fill with water....or it barely trickles out with hot water....and if it needs parts can I find a parts book...I've lost the...
There is a small screen filter inside the connection for the hot and cold water valves. This screen helps prevent minerals and small contaminants get inside the valve and prevent it from seating and closing properly. If water is just trickling out, this screen could be clogged. You can remove the screen with a small pick or screwdriver and either try to clean it out or replace it.
Jan 29, 2011 | Washing Machines
Machine won't fill up with rinse water, it washes & spins but the water only trickles in the rinse cycle, i ahve been filling it up manually
Turn the water supply off.
Remove the COLD water hose from the rear of the washer.
Clean the silt out of the COLD water valve on the washer.
Re-attach the hose on turn on the water supply.
Jan 21, 2011 | GE WBSR3140DW Top Load Washer
Washer will only fill with hot water not warm and if I set it for cold the water just trickles out
Check the hose line filter on the cold water side remove from machine if clogged clean and replace if you don't have a screen filter in hoses and rust or iron gets into water valve you may have to replace valve
Dec 29, 2010 | GE WBSR3140DW Top Load Washer
Kenmore heavy duty 80 model 110. rinse cycle at cold is down to a trickle, and seems to be lessening. Takes hour plus for a full water load if mixed alright flow for warm and hot
Your cold water line is clogged, kinked or the water valve solenoid is not opening all the way. First check the hose, then the screen on the valve for clogs. If none then replace the water valve assembly.
Dec 15, 2010 | Kenmore Washing Machines
Cold water trickles in tub. Hot water fine.
remove the cold water hose from the machine that is your service line feeding into it.
a screen in the inlet were the hose attaches to is probably clogged up
May 28, 2010 | Washing Machines
Won't fill with hot or warm water . hot and warm only come out in a trickle. cold water is the water that works normally
Turn off water supply valve behind washer and remove the supply hose from both ends. Look for a screened washer in the hose, which can be removed, cleaned, and re-inserted. Also, look for a screen to do the same with inside where the hose screws onto the machine. Re-attact hoses and turn water valves back on. Make sure hoses are not kinked behind machine.
Feb 01, 2010 | Washing Machines
My Maytag Neptune does not dispense hot water. Just a trickle. Warm and cold are OK
I'm not a repairman, only a "doityourselfer". Try some or all of the following:
1. Check water valve to see if it full open.
2. Check the hot water hose inlet on the back of the machine. Look for a strainer that may be clogged in the hose inlet (turn water valve off first).
3. Check hose for kinking.
4. With the hose disconnected from the washing machine, try running some hot water through the hose into a bucket just to verify the water is available.
5. With machine set to hot water wash, start a cycle and listen for the hot water solenoid to "click" when the machine is started (some solenoids are louder than others so listen carefully). If water begins to trickle in when you here the click then the solenoid is probably working properly.
May 11, 2009 | Maytag Neptune MAH6500A Front Load Washer
Rinse water barely trickles out of my washer
Do you fill the machine with hot water only?
If so, this is what I suspect. The filters in the inlet hoses on the back of the washer need cleaning. Remove the garden hose connectors, remove filter, clean, replace.
When filling with hot only you get a lot of pressure thru one hose. When you rinse, the best you can do pressure-wise is cold rinse -- but the cold water filter is going to be more clogged than the hot so it delivers less water.
When you use warm rinse, you get mediium pressure thru both lines, again less water than al hot on filling the machine.
Apr 29, 2009 | Washing Machines
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Mar 03, 2009 | Washing Machines
Cold water trickle hot water runs good
turn off water valves at wall, disconnect the supply hoses from the washer. where the hoses connect to the washer, there is usually a stainless steel screen/strainer inline on both the hot and cold inlet. corrosion on the cold side is pretty common. Menards, Lowes Home Depot stores sell the replacment screeens.
Jan 25, 2009 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
