Question about RCA TruFlat 27F520T 27" TV
Humming sound comes and goes. you can turn off the vol. and you can still hear it. picture is fine.
  • 403 Answers
More often than not humming and buzzing through your speakers is caused by a grounding problem. There are three main ground problems that cause problems in an audio / video system. These are ground loops, improper grounding and lack of a ground altogether. The other possible culprits that can cause noise are bad cables, a faulty piece of equipment or electrical noise from a lighting dimmer or electric motor. There are steps you can take to troubleshoot the noise and eliminate it from your theater or entertainment system.
The first step to is to find out where it is coming from. Disconnect your source and display equipment from your receiver or surround sound processor. If the noise stops, connect them back to the receiver or processor on at a time until the noise returns. When the hum comes back, you found where the noise is entering your system. Note that if you are connecting remote equipment, such as running the signal from your theater room DVD player to the TV in the bedroom, your chances to pick up noise increase dramatically. With such long runs, noise can be induced into the long cable runs from adjacent electrical wiring. It is also easy to create a ground loop, because the equipment is plugged into two different, widely separated outlets, on different electrical circuits.
If the noise is caused by a cable box, the noise is likely caused by the cable TV ground. To test this theory, disconnect the incoming cable TV feed to the rear of the cable box or TV while they are still connected to the rest of the system. If the noise is eliminated by disconnecting the TV cable , the problem is the cable TV ground. You can electrically decouple the cable TV feed from your system with a ground breaking transformer. These are available from many sources. Be advised that many newer, digital cable TV systems require any device in the signal chain to pass a full 1,000 Mhz. Some of the older ground break transformers will not do this. Be sure to check the specifications of whatever device you are purchasing to verify it will pass the digital cable TV signal.
If the noise is from your projector, TV, or monitor, it is most likely caused because the video display device is plugged into a different outlet than the other a/v equipment. It could be on a different circuit as well. These circuits may have two different ground potentials. That is, the resistance to ground is different on each circuit. A difference in resistance to ground from one ground point to another can cause the dreaded ground loop. If you get a ground loop, current flows between the two components. If the current flows through the components internal audio signal ground, you will get a hum.
You can use an isolation transformer, similar to the type used for cable TV ground problems, to eliminate the electrical connection from one component to the other. These transformers are inserted in line with the audio signal connection between the two components. If there is no audio connection between the components, the problem may be current flowing through the video portion. In this case, a video isolation transformer should be used to eliminate the ground loop.
Sometimes power conditioners will stop noise problems by placing equipment on different, electrically isolated outlets. This is done using isolation transformers. This can be ineffective however, due to the differences in internal construction of different power conditioning equipment. Some safety regulations, such as UL 1950, specify that an isolation transformer is only allowed to isolate the hot and neutral wires; the grounding wire must be passed straight through. If this is the case, the ground loop problem may still exist because many communication circuits are connected to the grounding conductor and not the neutral. In this case, the isolation transformer, or any power conditioner or UPS with an isolation transformer will have absolutely no affect on the grounding problem.
The noise may be generated externally, from a dimmer or refrigerator compressor for example, and coming in through the main power input on the audio video equipment . In this case, a high quality power conditioner may be effective in reducing or eliminating the noise problem. You may also find that one of the signal interconnecting cables in your system is faulty. This can also cause noise problems. Check for this by swapping the cables with one that you know to be good.
You can solve most noise problems in your home theater or multi room audio/video system by taking the systematic, step-by-step approach. Work your way up the signal chain, eliminating each piece of equipment as you go. If you have nothing connected to your speakers except the speaker wiring, and they still hum, the problem is noise induced into the speaker wiring from adjacent power cables. Other than that case, most problems are caused by ground problems, which you can find, and solve, if you take it one step at a time. Hope this helps. Let me know if I can help you with anything else.
JimmyC
Posted on Oct 04, 2009
I have a 50PL9220D DLP 50". Original problem was picture turned blue and had humming noise. Replaced lamp. Now have humming noise and picyure will come up fine for 5 sec then picture goes out. I have...
Sounds like the unit is going into a thermal protection mode. Probably something wrong with a transformer.
http://www.support.philips.com/support/service/service_page.jsp?userLanguage=en&userCountry=us
Jan 07, 2014 | Televison & Video
Humming sound
This type of sound can be generated by the back-light inverter board.
Jun 15, 2013 | Sony BRAVIA KDL-52XBR4 LCD TV
TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
Feb 09, 2013 | Televison & Video
There is a humming sound that is not coming thru the speakers
Your color wheel is failing. This will be eveident if you change your video inputs and you hear the tone of the hum change when the picture goes from light to dark
Mar 04, 2010 | Akai PT50DL24 Television
TV TURNS ON HUMMING SOUND FOR ABOUT FIVE MINUTES AND GOES AWAY
go in audio section and select mono instead of stereo or sap
Sep 18, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Loud buzzing/Humming noise.
I have a Amana ASD2622HRW Lately there is a loud buzz that comes and goes. We cleaned everything and blew it out under and behind the fridge. And it still is happening. Any suggestions? It still cools fine. But this Buzz is so loud that you can hear it through the house. Please help!
Apr 24, 2009 | Amana ASD2622HR Side by Side Refrigerator
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Deep Humming Noise
if the noise continues after you power down its the cooling fan
Jan 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a philips Matchline tv (29pt6361/79r) the tv works fine except it automatically turns the volume down without any buttons on the remote or tv being pushed
well depends on how far it turns the volume down as to what the cause is and if the volume bar on screen display comes on when the vol. goes down. if it just goes down a little you probably have the "smart sound" setting turned on in the audio menu turn it off and see if prob. goes away. if the vol. bar comes on the screen whenever the vol. goes down the you most likely have a bad button on your front panel and it doesn't have to be the vol. down button. it you think it is the button it would need solder work to be changed most likely shop job.
Mar 08, 2008 | Televison & Video
RCA TruFlat  27F520T 27" TV Logo
823 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
