Question about D-Link DIR-825 Wireless QuadBand Router
Wireless network OK, NO internet
I set up the wireless network and works fine. The only problem I dont have internet. My provider is Shaw cable. This is the second same type of router I'm trying and I have exactly the same problem. It is interesting,if I connect a D-Link DIR628. it recognizes automatically my cable modem and the internet wotks fine.
  • 404 Answers
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Oct 04, 2009
D-Link DI-524 works with desktop, but laptop can't get signal
Try opening internet explorer and typing in http://192.168.0.1 in the address box
If this doesn't work try http://192.168.1.1
For the username and password put admin for username and leave the password blank
Now look for an option for the Wireless Settings and change the channel from usually channel 11 to channel 4 your laptop may now see it. Otherwise try another, channels available in the uk are 1-12, I think it's 1 to 11 in USA
Feb 28, 2009 | D-Link AirPlus DI-524 Wireless Router
Computer says connected to internet,, wont display page
usually routers are setup using DHCP... on your second computer. try going to
start, control panel,  networkconnection,  "your LAN connection",\ properties Internet Protocol (TCP/IP) (should be checked)
Obtained Ip address automatically should be selected
Obttained Dns server automatically should be selected.
then click OK, OK to save settings...
if your router is not setup as a DHCP,it would require you to setup your ip address manually... let me know if this dont work, so  i can help u setup manually...
if it helps, try comparing the settings of your pc1 and pc2 (the network connection settings)
Feb 02, 2009 | D-Link DSL 604+ (DSL-604+) Wireless Router
DI-524 not working with Vista32 Dell M1330
make sure your wireless card is set to "obtain automatically an IP address"
Jan 25, 2009 | D-Link AirPlus DI-524 Wireless Router
Cant connect cable modem
If you have phone (DSL_ the phone must be connected to the modem of DSL, then connect the ethernet cable from the modem to the wireless router or router (use the jack WAN) and then from the modem (connect the cable into port # 1) goes to your PC into your ethernet card.
You have to access to your router and set your network (you have to put the data of your internet connection gave to you by your internet provider (usually is your email address and your pass)
You can get more help here:
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
If you have a wireless network Then do this:
Setting wireless network on Win XP
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
Nov 17, 2008 | D-Link DIR-625 (790069292637) Wireless...
Need to set up wirless router
Could you please provide the model of your router and your Internet Provider (Cable/DSL) so I could help you set it up.
Aug 03, 2008 | Computers & Internet
Wireless router, laptop problems
Try to delete all the prefered networks. Right-Click Wireless Network Connection, View Available Wireless Networks. Click on Change the Order of Prefered Networks. Remove all prefered networks there and click OK. Now try to View the available wireless networks again, reconnect to your own wireless network and see if it connects fine. Post your feedback.
Jul 12, 2008 | Linksys Wireless-G WRT54G Router
Laptop problems
Does this mean that its the laptop that can't get a wireless connection? Just want to clarify before giving out more steps that you can try.
Jul 12, 2008 | Linksys Ultra RangePlus Wireless Routr...
Validating identity
it is just that the network key which is stored in the computer is not working so the 1st thing u need to do is verify the network key for that go to 192.168.0.1 from internet explorer enter the user id & password of ur dlink ( default id: admin password : admin) the go to wireless check the WEP or security key which is present their. reenter that key the computer & try to connect.
If it didn't work then go to control panel >> system >> hardware>> device manager
look for the network adepter & unintall the wireless network card
restart the computer
once restart it will automatically reintall the wireless card driver
then go to control panel>>Network Connection
right click on wireless network connection
select view wireless network connect
select ur network name & connect it will ask for the key provide the key & once u do that it will get connected & work fine
if in case u have the same problem replay back & i help u out with it & also provide all the details like which windows & network card etc
May 25, 2008 | D-Link AirPlus DI-524 Wireless Router
Cable internet setup
No, you need to buy a wireless router and connect wireless router to cable modem. Non cable modems do not work on cabled wireless network.
If you buy cable router, buy either a router with no modem integrated or a modem/router for cable network, this last one may be best option, but it needs to be configured. Ask to retailer which models are ok with your broadband provider.
May 24, 2008 | Computers & Internet
I cant log in. PLEASE help me.
I guessing you live close to a neighbor that has an unsecured wireless network. It is possible that they changed their security settings to block out other IP addresses (meaning your PS3). The best solution would be to establish your own internet connection and/or wireless network thru a local broadband internet provider.
Jan 27, 2008 | Sony Playstation 3 (PS3) Console
D-Link DIR-825 Wireless QuadBand Router Logo
347 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
