Question about Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier
My Whirlpool Gold dehumidifier is making the circuit breaker switch off. I used the sweeper to clean all of the dust from the vents but it continues to make the breaker switch off.
  • 80 Answers
Take the unit outside and wash the coil out with a garden hose. Careful not to get water on the controls. Water will not hurt the motor or compressor as long as you keep it unplugged. Allow the unit to completely dry before running it again.
Posted on Oct 04, 2009
Whirlpool Gold Dehumidifier -The lights are all working, no fan? Is there a reset ?
You have what Whirlpool calls a Type 3 Control Panel. If you don't have the unit operating in Continuous Mode, the fan will operate only, when the compressor turns on to extract the humidity, based on the level of extraction you have it set on. If you haven't already,.set the control on Maximum and Continuous Mode.
If that doesn't solve the problem, turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes. After the time has elapsed plug the unit back in and turn the Master ON/OFF Switch to ON. Hopefully, the 15 minute timeout, allowed the unit to reset itself and revert back to the original factory settings. If so, you can set the controls as you like.
To further assist you, I have an included a link to your Owner's Manual, in case you have misplaced your. You can download and print it for future reference.
https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%201188826.pdf
I hope this helps you to further troubleshoot and solve the problem. Please let me know. Thanks.
Jun 21, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
I have had the Whirlpool GOld dehumidifier for 4 years. It was working great. Recently, I noticed that it stopped working. When plugged it, it trips my GFI socket. I have tried various outlets and checked...
Obviously, there is an electrical short within the unit. Should it be repaired? Yes, if you want continue using it. But, is the cost of troubleshooting, finding the necessary part and repairing it worth it? Most of the time, the cost to repair a dehumidifier is about the same, as what a new one would cost. Now, if purchased an extended warranty, when you originally bought the unit 4 years ago, then you're probably covered for the repair.
In the end, the decision is yours to make.
May 26, 2011 | Whirlpool Dehumidifiers
Unit will start and run for 5 seconds, then will blow a circut breaker on 20A. circut. This is a model AD75USTO Serial # QU2660438 AKA Whirlpool gold energy star
Hopefully, it's not a problem inside the unit that's causing the circuit breaker to trip. Is there another electrical appliance plugged into the same outlet or on that circuit that is ON and draws 15 amps of power? If so, that's the problem. If that's not the case, turn the circuit breaker OFF and remove the outlet cover, so you can inspect the receptacle and it's wiring. A loose wiring connection or a broken or cracked receptacle could be the issue. If you don't find any damage reassemble the outlet and turn the circuit breaker back ON. Instead of plugging in the dehumidifier, plug in a lamp or something similar and turn it ON. Leave it on for more than 5 minutes to see if the circuit breaker trips again. If it does, you'll know the problem is either with the outlet receptacle or the circuit breaker. If doesn't, plug in the dehumidifier (Make sure the Master ON/OFF Switch on the unit is in the OFF position, before plugging it in. Then turn the Master ON/OFF Switch to ON and set your controls. If the circuit breaker trips again, the problem is in the dehumidifier. You will need to call Whirlpool Customer Care, as it's an internal electrical issue.
In case you have misplaced your Owners Manual, I have included a link to it, that you can download and print for future reference. http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%201188927.pdf
I hope what information I have provided to you, will help you trouble shoot and solve the problem.
Apr 16, 2011 | Whirlpool 75-Pint Dehumidifier
I have a Whirlpool AD75UST humidifier that stopped running, almost like it blew a fuse or something. Does it have a fuse somewhere? Any other possibilities? Thank you!
Have you checked the receptacle it's plugged into, to see if it's still working? Use an electric lamp to check this. If the lamp doesn't work, the circuit breaker in the home's main panel has been tripped. Unplug the dehumidifier and reset the circuit breaker. Then plug the dehumidifier back in. If it trips the circuit breaker again, there's an electrical problem within the dehumidifier.
In answer to your direct question ... some dehumidifiers have a reset switch. It's probably on the back of the unit, above the water collection tub. if all else fails consult your Owners Manual's Trouble Shooting Guide. If you have misplaced it, you can download it from the Whirlpool Appliance starting at their home page.
Hope this helped head you in the right direction to solving your problem.
Mar 01, 2011 | Whirlpool 75-Pint Dehumidifier
I have a Whirlpool Gold dehumidifier with the hose set up for direct water release into a sink drain. I assumed once you hooked up the manufacturer hose provided it would be a direct drain process and...
I have a similar Whirlpool dehumidifier and a similar problem. Have you tried setting it to continuous mode? My understanding was that it would only divert the drainage to a side hose when in the continuous mode.
Jul 20, 2010 | Dehumidifiers
Dehumifier blows out my electrical switch in my electrical panel.
You definitely have an electrical short in the unit and should stop using immediately. Have it checked out by a licensed electrician. It is a very real fire hazzard.
Jun 07, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Circuit breaker trips when unit is plugged in
you have a dead short in the compressor.........SORRY
May 20, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Coils icing
the unit either has dirty evaporator coils and this will make them ice up,or the unit is low on refrigerant/freon,try cleaning the whole unit of dirt and dust first,then you may need to install a saddle tap on the sealed system and add some refrigerant/freon as these systems seem to leak more often than other sealed systems
Feb 06, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
AD50USR Whirlpool Dehumidifier trips circuit breaker
Not very likely check your paperwork what warranty did you get when you purchased this unit? you might have completed some papers and returned them to an address for the warranty to be accepted. It sounds to me like the unit is going straight to earth when switched on, this looks like a compressor fault, but would have to be checked to be sure.
Jul 20, 2009 | Whirlpool AD70USR Dehumidifier
Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier Logo
190 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Mike Squire
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
