Question about Toshiba Televison & Video
TV on/off button keeps blinking/TV won't turn on
I have the same problem, started yesterday. TV shut off by itself and the on/off button started blinking. When I unplug it it trys to go on but shuts off agan. Model# 61H70.
Does anyone have any suggestions on how to fix this, sounds like its a common problem?! HELPPP! :(
    Problem Solver:
  • 15 Answers
Try muting the sound on the tv, if it is a loose circuit the sound vibration can jiggle a connection and cause the tv to turn off as apart of its safety feature.
if the tv functions correctly while in mute then you now know it is a loose circuit.
if the tv continues to turn off even while in mute it is shutting down by the main power stand by safety feature, it may need a new main transformer.
if the muted sound solved the problem then unplug the tv and look in the back for the main transformer, the manufacturer usually places the main board on the box of the main speaker, the speaker could be vibrating a circuit loose from direct contact, the main transformer is heavy and would cause issues over the long run with high fadelity sound systems on big screen tv's. check solder points on main board.
Posted on Oct 04, 2009
Just shut off and now no power going to it., unplugged and try powering it up with button on tv not remote and still nothing.
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears ... If you are using the TV as a monitor and the Stand-by light only blinks ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I just watch your video my tv won't stay on it keeps turning off I have a ... My Samsung 55" Smart tv suddenly turned off and won't come back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Samsung PN64 just started randomly shutting off and on usually with ...
Samsung Smart TV turning off - Forums - CNET
Jan 05, 2016 | Televison & Video
Power button won't turn tv on. light keeps blinking on and off
Main board to your TV is faulty. Check the chroma and video processing section. In most cases, it will be due to an IC fault.
Jul 23, 2012 | Curtis-Mathis Televison & Video
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
When I turn the tv on, either manually or by remote, the power stays on for just seconds then shuts itself off.
hello my is rico, check your lamp, lamp cover, fans. second power on the tv when it shuts off itself hold buttons menu and input or device, it will start blinking , it will blink 1 or 2 and then its gone pause for a second andthen will start blinking again count the blinks like, 2,3 -2,2 it means code 23 or 22 and then needs call misubishi for the codes means. if you need more feel free to call at 602-810-7149 at anytime i live in mesa az
Dec 30, 2010 | Mitsubishi WD-57733 57" HDTV
TV shuts itself off..red light blinks 7 times.
the only way is by bringing to a tech.i think there is no need fro self-fixing with problems like this.try tapping the tv several times then turn it on.
May 28, 2009 | Televison & Video
TV turns on but turns itself off after short amounts of time
This set is equipped with LED diagnostics. Once it shuts down on the front of the set hold down the MENU and INPUT, (sometimes labeled DEVICE) buttons until the LED starts blinking a 2 blink sequence. For example one blink pause two blinks long pause and then repeats is the code for no problem. All of the fault codes begin with two blinks and then one through 4 blinks. I suspect that yours will be a 2 - 4 code because of loss of vertical sweep. Which is bad solder connections on the deflection yokes. A common problem with these units.
May 02, 2009 | Mitsubishi WS-55511 55" Rear Projection...
The tv keeps shutting down
i unplugged the tv , turned the lamp switch to off . I left it unplugged for a few hours . I then plugged the tv back in , hit the reset button , located on the front bottom left . I waited for the timer light to stop blinking , then turned the lamp switch to the on position . I turned the power on to the tv . i heard the fan kick on , this time there was not a dragging sound . the screen lit up and i have not had a problem since yesterday . i think that the problem started because the tv had been left on for too long , I know that what i have done is only a temperary fix . but as long as I dont forget to turn the tv off , i should not have a problem
Mar 25, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Open Questions:
I was given a 2007 Toshiba Regza LED television ( I believe it to be LED just because of the Year 2007.) I have the television plugged into the wall standing alone with nothing connected to it no wires no cable boxes nothing. When I push the power button on the side it goes on because the green light is on the bottom it's not flashing but it is on okay. Now what's happening is I'm not getting any picture and I went on to shop Jimmy's and they recommended that I contact you. The back lights are on as I can see through the slots on the back of the television that there is light coming from there. The thing I'm trying to find out if I did the flashlight cuz I couldn't see any picture whatsoever and I don't know I turn the volume up as much as I possibly could through the side and also with the remote. I change the batteries in the remote of course to see make sure that they were working and I shine a flashlight on the screen I could see no picture whatsoever no menu picture no nothing and no sound. So my question is to you, after following shop Jimmy's recommendations it said that if you have your back lights working but you still have no sound or picture then you would need to replace one of two parts or both. I'm not sure what those parts are called I forget but my main question is how much is it to even get those parts and can I still get them. Like is it really worth doing that or should I just go and buy another television. Mind you to see me was given to me at no cost so that is basically the question would it be worth buying those two parts that they recommended and putting them in one at a time or should I just go get a whole new television remember I'm not which call Rich either so... If you could contact me with an answer that would be great please be specific as I am not what you call text Abby okay? I thank you in advance for your time patience and cooperation and helping me to answer this questions. I look forward to hearing from you! Respectfully, Stephanie Whitman PS can this television only be controlled by the remote. There are buttons on the side but to truly get the best quality of the television I would need to use the remote correct?
Jun 14, 2018 | Toshiba Televison & Video
Televison & Video Logo
85 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
