Question about Samsung HC-P4363W 43 in. TV/DVD Combo
My TV is not working! Please help!
I have a Samsung HC-PA4363 TV and it is not working properly. Recently it started having a blue line on the left side of the screen and yellow under it. The commercial's letter has a shadow of blue around the letters. I am not sure what is going on but I want to try to troubleshoot to save me a bit of money. Thank you so much.
    President:
  • 4,402 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Posted on Jan 25, 2008
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Problem with the Samsung HC-P4363W 43 in. TV/DVD Combo TV shows partialy double vision in blue color.
The tv have a problems,known as a convergence problems,it is dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D picture look alike?Yes.The tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
May 25, 2011 | Samsung HC-P4363W 43 in. TV/DVD Combo
Samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Dec 23, 2008 | Televison & Video
TV problem
It sounds like there is a fault on the chroma panel of some kind.
Jul 23, 2008 | Samsung HC-P4752W 47" Rear Projection...
Can't adjust blue lines on grid for convergance
I would take a look at the entire circuit board the STK chips are sitting on... I have the same problem with a sony KP-57wv700 and it turned out to be the high voltage controller for the crts got fried... part # BA9759F and it can not be replaced as the entire circuitry around it got toasted also... I just ordered entire circuit board. mine was the D board in this case...
BTW, did you check or replace the pico fuses? 3 orange ones on each STK circuitry. Check their resistance with an ohm gage should show continuity. My case they were 3.15 A each...
Jan 14, 2008 | Samsung HC-P4752W 47" Rear Projection...
Screen Issue when HD Satellite Receiver is set to 1080i
these tv's are absolute garbage. Ours does the same thing with hi def.
never again for a samsung
Nov 03, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
Seperated colors
this is a common problem you have bad solder connections on the convergenc ics solder them back if this does not fix the problem then replace them k
Samsung HC-P4752W Blurred
im sorry for this not being a solution, but I have the exact same issue Jose. It just happened 3 days ago. When I run auto focus it says check factory default settings. Will replacing the 2 CI's help cure this problem.
Jul 28, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4363W 43 in. TV/DVD Combo Logo
104 people viewed this question
Jerry Greenberg
Jerry Greenberg
