Question about Akai PT46DL10 46" HDTV-Ready Television
Was watching started to raddle and color got weaker
Why does my KD-32FS170 32" Sony Trinitron screen have blue hues
If you turn all of the color out of the TV, the picture should be black and white. If that picture is not a true black and white picture, the TV will produce a color picture that has that behind it. It takes the proper mixture of red, green and blue light to produce white. This is something that is done inside the glass picture tube.
In your case, one color (blue is stronger) and the others are weaker.
It probably had not been used for a while. SOMETIMES, the weaker colors will get stronger with use. Adjust the brightness and picture controls to get the closest you can to a black and white picture, and then add the amount of color that seems right to you. Use the TV and hope for the best. It will improve, but 2%, 10%, or 50%; I do not know. The proper repair is to replace the glass picture tube, which is not an option at this time. So, turn it on, play games, and HOPE for the best.
Dec 04, 2014 | Sony Televison & Video
Why does the car raddle when i press the gas peddle on a 1999 chrysler sebring
check your exhaust system it might be the source of the noise
Jun 16, 2014 | 1999 Chrysler Sebring
My hitachi ultrascan hd tvs color is fading ?
Sounds lamp in TV getting weaker and soon it will be replaced.
When dlp tv start showing darker picture then its time for new lamp to get back vivid picture.
Dec 17, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
2005 crf250r trans oil and funny noise
The water pump seal is maybe gone.This would allow water into the trans.Get it checked and also that the bearing hasn,t spun in its location.This may cause the color change.Being a grey color,it may indicate aluminium in the oil.This may be the spun bearing turning in the housing.With what you wrote,I would get these things looked at.I hope this helps you
Nov 03, 2009 | 2005 Honda CRF 250 X
A/C and heater raddle/vibration when fan control turned on
That vibration is caused by something lying in the fan. This causes an imbalance in the fan that gives off the vibration. You will have to remove the blower motor in order to get to the fan and clear the fan of whatever is stuck in the fan.
Oct 06, 2009 | 2004 Chevrolet TrailBlazer
Just bought 2004 accent used.
dear friend-you will have to remove the vent and look for something inside as kids like to push things threw the vent.
Jul 28, 2009 | 2000 Hyundai Accent
Oil pressure
does the engine make any raddle noise when you start the engine. if not may just need oil presure sensor.
Jan 01, 2009 | 1998 Ford Explorer
I would be great full if someone can help me pick a high end tuner from the vintage sansui line. 70's to 80. And where to buy or search for a good Receiver/tuner.
i use to own an old vintage tuner, i still remember the model number its a Pioneer SX-727 for an old tuner it can raddle some windows just google search it you can look at image to view it its silver with wooden top with a vent on the top rear an it glows an amazing blue color witch is really sweet chech it out
Oct 14, 2008 | Sansui Audio Players & Recorders
Akai PT46DL10 46" HDTV-Ready Television Logo
12 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
