Question about Oregon Scientific Complete Carburetor for Stihl 4122 Brush Cutter and 4226HS Hedge Trimmer
Instruction on how to rebuild Stihl FS85 carburetor
  • 148 Answers
The FS 85 was produced in HUGE quantities over a number of years. Several different carbs were used during production and Stihl has several proprietary carbs in use. You will need a Rebuild Kit (NOT just a Diaphragm Kit) for this particular carb. On the carb body you should see a Series and a Model identification.
Example: If this is a ZAMA carburetor, the C1U-S66 might have been used on your trimmer.
Get that info off the carb body and ...
For ZAMA carb lookups click HERE.
For WALBRO carbs click HERE.
Hope this helps.
Posted on Oct 04, 2009
Hard to start..will not rev. up
STIHL TRIMMER-WEED EATER REPAIR: stihl carburetor ...
? 6:55
www.youtube.com/watch?v=vK6MsQalprY
Sep 16, 2011 - Uploaded by JEREMY FOUNTAIN Here is what I did for my fussy Stihl FS 250r trimmer....this after sitting all ... STIHL FS80 FS85 FC85 HS80 CARBURETOR ASSY 41371200614 ...
Aug 07, 2015 | Stihl FS 85 Weed Eater
Stilt fs85 cannot start, what may be the cause of it?
First check your muffler's spark arrestor to see if it is clogged.
If not clogged try adding a little fuel mix introduced into the carburetor throat. If starts then you have carb problems.
If it don't start then you may either a compression problem or ignition problem.
Dec 26, 2014 | Stihl Fs80 Fs85 Fc85 Hs80 Ing Coil Assy...
Stihl fs85 gives off white smoke while running
change to stihl ultra oil and make sure you ratios are correct. also replace spark plug and spark arrester.
Oct 07, 2012 | Stihl FS 85 Weed Eater
My Stihl FS85 runs good for about 20 seconds and then shuts completely off. I have replaced the Plug, cleaned out the fuel system and it still does the same thing. Could it be the coil?
Sounds like the main jet or the diaphrams in the carburetor are deteriorated. Remove carb and soak in a good carburetor dip style cleaner and rebuild with a new kit. Also replace the fuel line and filter and use a fresh gas mix.
Sep 17, 2012 | Stihl FS 85 Weed Eater
Stihl diagram parts list for fs85
your local stihl dealer can email you a parts diagram...
Aug 28, 2012 | Stihl FS 85 Weed Eater
ZAMA CARBURETOR REBUILD
Unless you really know what you're doing i wouldn't advice it be carried out by a novice. Carbs contain small one way valves that can get damaged. Avoid using airlines to clean and blow out carbs as these can damage the valves. Diaohrams, gaskets and needles are pretty straight forward tho.
Jun 14, 2012 | Stihl Trimmer Zama Carburetor...
I need a carburetor diagram/schematic for Stihl FS85 trimmer
call the company that you bought it from or the manufactor might have it yet so they can send it to you.
Oct 07, 2011 | Oregon Scientific Complete Carburetor for...
Need repair Manuel for Stihl br-550 blower
A shop like www.arcolawn.com can get you Stihl tools and parts.
It sounds like your carburetor is not meetering the fuel properly. A rebuild may work but the carburetors on many machines have fropped in half in the past 2 years.
You may have a bad seal on the crank shaft or an air leak somewhere. If you take it to a dealer most shops charge less than an hour time to perform a full check on the machine and you can do the work.
Good luck
May 30, 2010 | Oregon Scientific Complete Carburetor for...
I need to rebuild the carburetor on a Stihl Model 025 chainsaw. An exploded view diagram would help.
I don't have a diagram or the part numbers to the minor and major repair kits, but a Stihl dealer should be able to help. Tell him you need a kit for a ZAMA C1Q type carb. The exploded view should be with the kit.
May 19, 2010 | Garden
Oregon Scientific Complete Carburetor for Stihl 4122 Brush Cutter and 4226HS Hedge Trimmer Logo
7,191 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
