Question about Samsung HL50A650 50 in. TV
I have a samsung hl50a650c1fxza that is less than two years old. I have replaced the bulb three times with a year. Whats causing this problem or I'm I just getting a bad bulb?
informatica
  • 1114 Answers
SOURCE: Three beeps and can't find the reset button
Try leaving the batteries out for a day or so, the camera should "reset" itself.
Posted on Jul 24, 2007
ctf1800
  • 4402 Answers
SOURCE: samsung HC-p4241w- replacement bulbs/screen
http://www.fixyourowntv.com/projectionclean.php
Posted on Jan 28, 2008
SOURCE: Samsung 306BHW-Error code 7E
I don't know what the problem is bUT I HAVE THE SAME PROBLEM TOO ON a machine 8 months old
Posted on May 02, 2008
SOURCE: Samsung SlimFit 30" high pitch whining noise
I have had the same high pitch tone problem for several months after about 20 minutes of use. It is so bad it's rendered the TV almost unwatchable. I contacted a repair place from Samsung's website. I was told that is likely the flyback transformer. I don't know what it is, but it sounds cool like a flux capacitator. I was told it would be about $100 to fix. However, I have had very little luck getting the repair shop to order the part and do the work.
Posted on Feb 01, 2009
Axle80
  • 73 Answers
SOURCE: Samsung DLP model hln617w won't turn on (not bad bulb)
Samsung is notorious for having bad color wheels in their DLPs. Well lets just say they are like toasters, they only last a certain amount of time. If the color wheel isn't spinning or is broken, the set will power down almost immediately after you hit the button, you may not even hear the entire fire up jingle. Check the wheel, if you can see the bulb light up for that split second. Actually, check it whether the bulb lights up or not.
Posted on Jun 29, 2009
2006 Trailblazer low beam headlights out high beams work.
Bulbs are like people - some last a long time, some croak early.
Meanwhile the part they plug into can be cleaned out and restored if metal is still there.
Aug 22, 2017 | 2006 Chevrolet Trailblazer Ext
Although the device does not turn on electricity, the supply may be the problem, how can I fix?
TV fails to turn on, like the many other Samsung TV owners my three year old Samsung TV began having delays turning on and then eventually failed to turn on all together. I was shocked and dismayed to find the high number of Samsung consumers with the same issues on the internet and frustrated as like myself most were way beyond the one year warranty. There are even several YouTube videos demonstrating how to replace the faulty capacitors causing the problem. I was ready to be done with Samsung but to my pleasant surprised after several phone calls to 1-800-samsung they offered to make a onetime repair at no charge. Samsung made the repair in less than 30 minutes with no questions asked. Samsung stood by the product and so will I.
Jan 01, 2012 | Samsung 50 in. Plasma TV
How long do bulbs generally last?
Generally, a DLP bulb lasts about 8,000 hours (if a TV is on 10 hours a day, every day, the bulb will last about two years). A bulb can last longer if it's used less frequently. Typically, a bulb in a DLP TV for household use should last at least three to four years before it starts to flicker and needs to be replaced.
Thanks!
Tim
Oct 02, 2010 | Samsung HL-67A510 67" DLP HDTV
No backlight on Samsung 710N LCD Monitor
No, it is not easy to change the backlight on an LCD panel. The backlight is an integrated part of the LCD panel itself. The backlight for LCD monitors is also model and manufacturer specific, so there's no easy place to order a backlight to do it yourself. The good news is that your Samsung monitor should come standard with a 3 year warranty, so if it's less than 3 years old, you can call Samsung and they'll repair/replace it for free. If it's over 3 years old, then you may need to repalce the monitor... or pay to have it repaired.
Mar 07, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
I have a samsung projection tv and it is starting to go dark on the screen could this be the bulb
There is a possibility it might be the lamp, if you've never replaced it on the TV it's better you replace it. It could also be a ballast issue, it depends of how old the TV is. for example if the TV is less than a year old, that would definitely not be your bulb. Bulb for Samsung are around 110 dlls and the ballast around 80 dlls, www.discount-merchant.com?Click=48427 they have very good deals. If you're going to purchase the lamp, remember that it's best if you go with the original Philips lamp, otherwise it won't last that ling.
Nov 03, 2009 | Samsung Televison & Video
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Says bulb has to be replace.
If your Tv is less than a year old you want to get ahold of Mithubisi NOW! There are two upgrades if you can call them that that adress the overheating and blocked airflow, And if the lamp needs replaced I'm sure you would rather have Mitshubishi pay for the 350.00 lamp than you
Feb 22, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Samsung HL50A650 50 in. TV Logo
724 people viewed this question
Henry  Thomas
Henry Thomas
