Question about Sony KDF-E60A20 60 in. LCD HDTV
I have a Sony KDF-E60A20...it blink red 5 times and video or audio. It happen all of a sudden...what could be the problem?
  • 115 Answers
5 is a bad lamp ballast . but you should check the lamp first. those tv's don't always detect ballast trying to start the lamp correctly. especially if its even been repaired before . most service poeple dont put the hv detect wire back in the correct place so when the lamp goes bad the tv thinks the ballast is bad. listen for a little short buzz or crackle noise from the back of the tv when you try to turn it on . the buzz noise last about 1 second and should happen about every 30 secoinds 3 times . if you hear it only the lamp is probly bad. or its a bad ballast
Posted on Oct 04, 2009
6 blinking red light sony kdf-e60a20
Six blinks is a Low B error, B_12V is not supplied, GT board problem.
Aug 23, 2017 | Sony Televison & Video
I'm having the same problem with my tv (wega sony kdf e60a20) just like a few other people here, with the sensor cutoff fuse, how do you replace this item?
If you mean the thermal fuse, the set should have a red blink code of 5 blinks. The thermal fuse is way inside on the frame of the lamp housing but can be tested with rear cover removed.
If you have one bad the red blinking light will have to display some code.
Dec 22, 2012 | Televison & Video
The unit turns on and off every 40 sec. or so. I have turned the unit off and on and I get a red light blicking 5 times on and off. this happened about 4 to 6 mo. ago and it is happening again...
Below info are related to Sony KDF-E60A20 lcd projection tv.
5 times red light blinking indicates problem with lamp drive circuit (ballast supply board) that is not producing high voltage for lamp to generate high bright white light.
Check/ replace ballast supply board in above mode tv to solve this problem.
If you tv model is different, let me know to provide you related info.
Thanks
Jan 17, 2011 | Sony KDF-E60A20 60 in. LCD HDTV
Sony kdf e60a20 red lamp lights blinking
I do know it is important to know how many times the red light blinks.
Nov 27, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Sony 60 model kdf-e60a20 wega
is the led blinking anything? When was the last time you replaced the lamp? A bad lamp can cause this kind of problem.
Dec 01, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDFE60A20 TV turns off and on with Red light blinking 5 times
Same problem here. 5 blinks is video related. I've been told to clean the screen by the lamp, as they could be clogged and causing it to over heat. Going to give thet a try first. I'll post what happens...
Oct 07, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Kdf-e60a20
do a google, Sony 4 red blinking lights, there is lots to read. Read it all. We had 6 blinking lights and it was at $20 thermal fuse that we reinstalled ourselves and saved lots. It was past warranty. You can also put a message out on the blogs. But do your homework, it's worth it. Good Luck, Kim
May 20, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
KDF-E60A20 Red Light Flashing 6x
My TV KDF-E60A20 is now Fixed. My tv was overheated and Thermal Fuse Located bottom of the lamp burned. I replaced a different Thermal fuse part from 191000644 to 191002393
at www.partstore.com
search for part number. thank you for the review it's help me a lot
thank again
May 07, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-E60A20 60 in. LCD HDTV Logo
1,106 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
