Question about Canon PIXMA MP620 All-In-One InkJet Printer
Changed the ink cartridges but the colour wrong
I have changed the ink cartridges but the colour is not right. How can I fix this. I have run the cleaning program. There does not seem to be enough red in the print.
    Sergeant:
    Novelist:
  • 191 Answers
Check the ink wells are installed in correct order. Next, do a nozzle check (same place as the cleaning). This will have you print a pattern and ask you if it looks normal. If yes, you are good to go. If not, you may need to align the print heads. This can also be done in the same place as the print cleaning and nozzle check. Hopefully that will take care of the problem. Next step is print head replacment.
Posted on Oct 04, 2009
Started with out of colour ink - changed coluor ink cartridge. then came up with out of black ink - so changed the black ink cartridge now sais scanner failure when run through procedure to align...
"Scanner failure" basically means buy a new machine. Once the scanner fails on an all-in-one it will refuse to do anything. Replacing or fixing the scanner will cost much more than buying a new machine.
Sep 28, 2010 | HP PSC 750 All-In-One InkJet Printer
Hi The colour is wrong - the yellow does not seem to print although it is not empty. How can I fix this? Thank you susanne
Sometimes the ink cartridges go bad before they run out of ink. I've had this problem and the vendor I get my ink from let me trade it for a new one. Try changing the ink cartridge and see if that fixes it like it did on mine.
Sep 20, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Printer HP Deskjet D1460 prints pink"..Instead of Black
The printed colours are an "additive" mix of the "primary" colours in your printer.
So, when the colour ink-jet cartridge is "out-of-ink" on one (or more) of its colours, the "mix" will be off, and the "wrong" colour will be the result.
Change the colour cartridge.
Before changing it, run a "deep-cleaning" cycle, using the HP Support software that was installed when you installed from the CD-ROM that came with the printer, to "clean" any/all "clogged" ink-jets -- i.e., a clog could be preventing one colour of ink from being sprayed onto the paper.
Apr 08, 2010 | HP DeskJet D1460 InkJet Printer
Dont know how to change colour cartridges
Turn the printer on and open the lid. After a short while, the printer carriage unit containing the print head and ink cartridges will stop right in the middle of the printer, so you can easily replace the ink cartridges. After replacing them and ensuring they're fully seated, simply close the lid. The printer will run a few quick self-diagnostic checks and run a purge cycle, and it'll be good to go.
May 16, 2009 | Canon Office Equipment & Supplies
Printer won't recognise new colour cartridge
I got a new print head @ "staples" office supplies. It didnt cost me anything!!! Kodak had probs with the head, & gave a bunch to staples.....i changed the head, put in new inks, again...got a calibration to run...& things printed np!!!
Apr 14, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
The Colour is not turning out properly when printing.
You should open the software that came with the printer, there should be a head cleaning option,or a maintenance option, repair option, it just sounds like there is some dry ink in the cartridge holder
where the ink comes out of the cartridge. Try the cleaning option then if it does not work,try this 2-3 times, then remove the cartridge and take a q-tip and clean the metal strip that is on the cartridge
and the place where the ink comes out and the place where the ink comes out and comes in contact with the holder, if it is dried ink, you can put a little rubbing alcohol on the q-tip and clean them with it.
If this does not seam to work please post back with any more info and we will try to help.
Mar 25, 2009 | Canon BubbleJet i550 InkJet Printer
Have changed Ink Black and Colour... Stil getting error Message.
Make sure the tape covering the hole on the bottom of the black cartridge is removed. and then go into the printers folder and right click on your printer icon and go into the properties of that printer and there should be something in there to tell it that you changed cartridges and you can also print a test page as well.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Jan 08, 2009 | Lexmark X5150 All-In-One InkJet Printer
Wrong colours!
Hi Dannydoda,
I understand that, you are using different compatible ink cartridges and having problem with colors.
HP printers has a small built in firmware, which can detect the original ink cartridges and the ink level.
Using other compatible ink cartridges may damage the print heads of the printer.
I suggest you to replace the ink cartridges with original or Genuine HP cartridges.
You can also try some of the steps to fix the issue as given in the web link.
please click on the web link given below and perform the steps carefully.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042885&cc=us&lc=en&dlc=en&product=79499
This should fix the issue.
Have a great day!
Mar 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
Canon PIXMA MP620 All-In-One InkJet Printer Logo
144 people viewed this question
old marine
old marine
